Blue Ribbon 4x4 Build Thread
Discussion in '2.5 Gen Builds (2014-2021)' started by BlueRibbon4x4, Jul 25, 2020.
  1. Jan 28, 2024 at 5:50 AM
    #1201
    BlueRibbon4x4
    BlueRibbon4x4 [OP] Let’s color match it
    Geno
    2015 Blue Ribbon 4x4
    Starting to pre assemble the air line stuff. I bought these last month for myself and all the guys on the jobsite. They kick ass! The jaws stay parallel and are smooth so they don’t mar the fittings. I also do a lot of plumbing it just looks nice when angle stops aren’t all chewed up from channel locks.
    IRWIN VISE-GRIP Adjustable Pliers, Plumbing, Tongue & Groove, 8-Inch (IRHT82635) https://www.amazon.com/dp/B07QM9L5VR
  2. Feb 4, 2024 at 1:26 PM
    #1202
    BlueRibbon4x4
    Geno
    Dang, I deleted my compressor line post to edit it and forgot to do any of that.
    I have the Smittybilt 2781 under the hood. My old setup just had a 1/4” line going to the rear bumper with a quick connect. From there I had a four-way hose to fill the tires all at the same time. Fill up from 15psi to 38psi was about 10 minutes, not including wrestling the damn 50-60ft of hose to the tires and roll up.
    So in interest of giving the compressor a break and not have to push all that air in a 1/4” line to fill four tires, I upgraded to a 3/8” nylon hose to a splitter next to the windshield washer reservoir. In-line is a 70-100psi pressure switch to shut off the compressor and not blow the line.
    In the splitter is an air pressure gauge, a valve for the inlet, two 1/4” outlets, and one 3/8” outlet. The two 1/4” outlets go to the two front fender liners. The 3/8” outlet goes to the rear crossmember in front of the spare tire. There, I installed a second splitter, holding three 1/4” outlets. These go to each rear fender well, and the rear bumper quick connect.
    When I originally built the four-way hose, I bought a 100ft air hose. So with the leftover, I made four-five foot hoses with closed air chucks.
    Now I can hit the compressor button in the truck, and it fills the line to 100psi. I attach the four hoses from each fender to tire, then open the valve to the first splitter. This starts to fill the tires and activates the compressor to do it’s job. When the pressure gets close to 40 psi on the air pressure gauge, I just close the valve and the gauge gives me an accurate psi measurement on the tires. The pressure switch cuts off the compressor, the air chuck lines get disconnected and I’m on my way.
    I’ve tested it twice so far and I can’t believe how much faster the entire procedure is compared to the 4 way line. Actual fill up time is now approximately 7 minutes, and the compressor sounds much smoother and quieter. One day I’ll upgrade to a dual compressor and that time will shorten, but for right now I’m super happy with this new setup.
    Patch999, Mater, TRDFerguson and 3 others like this.
  3. Feb 4, 2024 at 2:09 PM
    #1203
    BlueRibbon4x4
    Geno
    In hindsight, I should have put one 3/8” line from the rear splitter to the rear quick connect, instead of the 1/4”. But that can be remedied.
    HulkSmurf14 and RobertD like this.
  4. Feb 25, 2024 at 4:50 PM
    #1204
    BlueRibbon4x4
    Geno
    So the wife is out of state for a month, and I have a few things I’ve been procrastinating on. I’ll have time to do them, hopefully. If I post this here, I’ll be holding myself accountable for getting them done.
    I have the materials for all these mods, as they’re just sitting on my bench.
    1. Paint brake calipers with Por15
    2. Raptor line front bumper
    3. Suede headliner
    4. Black accompanying plastics to headliner.
    5. Change headlight color
    In the meantime, I’ve been bombing around my whereabouts.
    IMG_9917.png 824BF674-F6CD-4180-B67F-F5EA798D6B3E.jpg IMG_9668.jpg IMG_9654.jpg IMG_9495.jpg
    ElNopal, TreeCat, Patch999 and 4 others like this.
  5. Feb 25, 2024 at 6:13 PM
    #1205
    RainMan_PNW
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    The headliner project has me interested…
  6. Feb 25, 2024 at 6:29 PM
    #1206
    BlueRibbon4x4
    Geno
    I’ve done a ton of homework, I have the suede, I just gotta commit!
  7. Feb 25, 2024 at 7:21 PM
    #1207
    RainMan_PNW
    Casey
    Clark County, WA
    I want 1) black and 2) something patches will actually stick to.
  8. Feb 25, 2024 at 7:58 PM
    #1208
    Mater
    Mater New Member
    SD
    2016 MGM Platinum
    They sell it in 60” too
    Patch999 and BlueRibbon4x4[OP] like this.
  9. Feb 25, 2024 at 8:19 PM
    #1209
    BlueRibbon4x4
    Geno
    I see a bunch of people with patches on their headliner, I just assumed they stick. I guess I was incorrect, I wonder what they use.
    Patch999 and Mater like this.
  10. Feb 25, 2024 at 9:25 PM
    #1210
    RainMan_PNW
    Casey
    Clark County, WA
    I don’t want the headliner to look like public hair… :rofl:
    they kind of do, but it takes some mashing and then hoping/praying no one touches them or looks at them sideways.
  11. Feb 26, 2024 at 4:37 AM
    #1211
    TRDFerguson
    Jake
    Southeast Greater Basin, AZ
    2018 MGM CrüeMax
  12. Feb 26, 2024 at 11:59 AM
    #1212
    Kgfit85
    Kgfit85 MR MRPH
    Kevin
    Jacksonville, TX
    2018 Tundra TRD Sport 4x4
    4” RC lift 35” Toyo 18” KMC Air ride bags for towing
    Well Geno, can’t believe I’ve never came across your thread, my apologies for the bombardment of “likes.” But geeze, this is awesome! I literally read your whole thread today from the time I got to work…. Hopefully I have a work order to bill my time too for work lol.
    Great work man. Love it!
    BlueRibbon4x4[OP] and RobertD like this.
  13. Feb 26, 2024 at 12:06 PM
    #1213
    GODZILLA Ask me about my hot doc
    Just use work order B@D@$$-B1U3-B!U1D and you'll be fine. :D
  14. Feb 26, 2024 at 12:19 PM
    #1214
    Kgfit85
    Kgfit85 MR MRPH
    Kevin
    Jacksonville, TX
    I’ll send it in to get that WO added to our tracker! Lol
  15. Feb 26, 2024 at 12:22 PM
    #1215
    :fistbump:
    BlueRibbon4x4[OP] likes this.
  16. Feb 26, 2024 at 4:11 PM
    #1216
    BlueRibbon4x4
    Geno
    Thanks Kevin!! I really appreciate the compliments!!
    Patch999 likes this.
  17. Feb 27, 2024 at 5:10 PM
    #1217
    BlueRibbon4x4
    Geno
    The beginning…….
  18. Feb 28, 2024 at 6:07 PM
    #1218
    BlueRibbon4x4
    Geno
    More pieces removed, adhesion promoter and SEM black going down. Headliner out!!
    GAknight, ElNopal, Sean492 and 6 others like this.
  19. Feb 28, 2024 at 6:25 PM
    #1219
    RobertD
    Robert
    DFW, Texas
  20. Feb 28, 2024 at 9:58 PM
    #1220
    BlueRibbon4x4
    Geno
    Kinda late night, getting things done before the weekend.
    Friday will be sound deadening.
    Saturday will be the headliner glue up. Sunday everything will hopefully be reinstalled.
    Wondering-anyone ever used fabric spray paint? I’m trying to avoid reupholstering the sun visor. IMG_9945.jpgIMG_9946.jpgIMG_9947.jpg
  21. Mar 1, 2024 at 6:44 PM
    #1221
    BlueRibbon4x4
    Geno
    Sound deadening done, I was afraid to cover the crossmembers. I’m unsure the headliner will sit properly if I wrap over them. Looking at the back of the headliner it looks to be ok, but wrestling with this thing by myself, I don’t want any issues when it comes time to reinstall. I thumped on the ceiling and there’s a huge difference. I’m mostly trying to deaden road noise.
    GAknight, biebs96, RobertD and 4 others like this.
  22. Mar 2, 2024 at 10:15 AM
    #1222
    BlueRibbon4x4
    Geno
    Almost ready for the glue-up. Everything is painted, I’m not 100% happy with the sun visors. One of the warning stickers wouldn’t come off, so it ended up glossy. I’ll be covering it with a decal. We’ll see what happens.
  23. Mar 2, 2024 at 3:12 PM
    #1223
    BlueRibbon4x4
    Geno
    Black. Suede. Headliner.
  24. Mar 3, 2024 at 4:54 PM
    #1224
    BlueRibbon4x4
    Geno
    Headliner done. The sun visors got black American flag decals to cover the old decals. Took about three hours to put everything back together. This was a pretty fun project, once I was brave enough to tackle it. It’s hard as hell to get good pictures of black headliner dammit.
    IMG_9997.jpg IMG_9996.jpg IMG_9991.jpg IMG_9990.jpg IMG_9981.jpg IMG_9979.jpg IMG_9975.jpg IMG_9976.jpg
  25. Mar 5, 2024 at 6:49 AM
    #1225
    BlueRibbon4x4
    Geno
    Update: there’s a huge difference in road noise in the truck. The sound deadening material took a lot of the echo and “snow” noise. Stereo sounds thumpier. I never had rattles, all the doors had sound deadening already, but definitely less resonance in the cab. The roof definitely is a weak point for good sound from your stereo, but my goal was road noise. I was always reminded of it when I drive my wife’s Acura, which is almost silent. As soon as I had everything installed I hit 70mph nearby and the difference was amazing. Very happy with this install.
    GAknight, Cthulhu, BillyB and 11 others like this.
  26. Mar 8, 2024 at 6:21 PM
    #1226
    BlueRibbon4x4
    Geno
    Just a small upgrade. New NVX 12” dual voice coil subwoofer and NVX NDA102 amplifier. Really cleaned up the wiring and upgraded the power lead and ground to actual 4 gauge. The bass is so much cleaner and I can really crank it now. I need to do some tuning but that will be for tomorrow.
  27. Mar 8, 2024 at 6:35 PM
    #1227
    HulkSmurf14
    2014 Tundra Limited
    Tastefully enhanced...
    I mean, you HAVE to with all that sound deadening you upgraded with!! Looking good as always!!
  28. Mar 8, 2024 at 6:38 PM
    #1228
    Helpers are helping as usual I see. :rofl:
  29. Mar 8, 2024 at 6:42 PM
    #1229
    AZBoatHauler
    So.Arizona
    Looks so amazing!! No black headliner in the 2.5 gen has been one of my biggest gripes! Thanks for being the example to show our wives there is someone more dedicated to their truck than the rest of us.
    :hattip:
  30. Mar 8, 2024 at 6:55 PM
    #1230
    BlueRibbon4x4
    Geno
    Thank you sir!!
    HulkSmurf14[QUOTED] likes this.
