  1. Mar 1, 2024 at 7:43 AM
    it’s getting tuned Monday to delete the DOD commands in the ecu and fix the throttle / fuel mapping tables for an L8T cam in an L86 motor. Till then, she rests. We’ll finish burping the cooling system, check the trans fluid level and finish bleeding the brakes. Battery is on the trickle charger too. Gotta be honest, it had a nasty tick on #3 when it first started up and I was worried, even though I figured the lifter just hadn’t pumped up yet. It went away around 3-5mins and my sphincter relaxed. Running butter smooth now.
  2. Mar 1, 2024 at 7:44 AM
    FishNinja
    FishNinja HIDE YOUR DAUGHTERS
    Lee
    TEXAN....big surprise
    06DC2wd
    bmf4069 and BroHon like this.
  3. Mar 1, 2024 at 7:47 AM
    Mr.bee
    Mr.bee King Turdra
    '02 AC TRD
    that truck have lsd or are you gonna have to pull the abs fuse?
  4. Mar 1, 2024 at 7:47 AM
    FishNinja
    Lee
    06DC2wd
    weld the ️spider gears
  5. Mar 1, 2024 at 7:48 AM
    Mr.bee
    Mr.bee King Turdra
    '02 AC TRD
    Lincoln locked.
  6. Mar 1, 2024 at 7:52 AM
    bmf4069, txagg, NUDRAT[OP] and 6 others like this.
  7. Mar 1, 2024 at 7:54 AM
    It’s a Z71 6.2 SLT higher optioned model. Not sure if it’s got LSD or not. Have to check for the G80 or L90 code or whatever they use these days in the glovebox
  8. Mar 1, 2024 at 7:55 AM
    Mr.bee
    Mr.bee King Turdra
    '02 AC TRD
    Photoshopped.
    bmf4069 and KNABORES like this.
  9. Mar 1, 2024 at 7:56 AM
    Yes. That is a photo. Of a shop…..
  10. Mar 1, 2024 at 7:59 AM
    BroHon
    Bro
    2000 SR5 AC 4x4 4.7
    Tundra2 and KNABORES[QUOTED] like this.
  11. Mar 1, 2024 at 2:09 PM
    My parts finally showed up. It's concerning that they have two different customer names on them that aren't mine... I hope the bagged parts are correct.
  12. Mar 1, 2024 at 2:13 PM
    The Black Mamba
    Snek
    DFW
    Black 00 SR5 AC 5VZ PreRunner
    Imma keep it stock
    It's common to see that. It could be who originally ordered the part and cancelled the order or it's that name of the warehouse employee who ordered it for you order. I wouldn't let that bother you.
  13. Mar 1, 2024 at 2:16 PM
    The Black Mamba
    Snek
    DFW
    Imma keep it stock
    If you zoom in on my pic, you can see names on my parts too.
  14. Mar 1, 2024 at 2:42 PM
    scooterprint
    scooterprint Idiot with a wrench
    Jeremy
    Conway, AR
    ‘04 DC 4x4
    NO WAY? JAKE? FROM STATE FARM?
  15. Mar 1, 2024 at 3:48 PM
    Good deal. Thanks. I've ordered a lot of parts but this is the first time I've noticed other names.
  16. Mar 1, 2024 at 4:07 PM
    I’ll take that pvc valve grommet.
  17. Mar 1, 2024 at 4:12 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    PCV is super easy on the 5vz. Why's it such a PITA on the 2uz? I should probably do mine.
  18. Mar 1, 2024 at 4:26 PM
    The wire harness gets in the way. I need to cut mine to get good leverage and pull it out. Just need to find the appropriate tie wraps to replace the originals with after doing it.
  19. Mar 1, 2024 at 4:51 PM
    ToyotaDude
    ToyotaDude Member
    2003 Tundra AC V8 4x4
    So recommendations on new NSK vs SKF wholesale closeout rear wheel bearing from Rock Auto?
  20. Mar 1, 2024 at 5:55 PM
    BroHon
    Bro
    2000 SR5 AC 4x4 4.7
    Side damage, and a little skritchy sratch on the hood, shit'll buff right out, $1400. Retail 10,300! :rofl:
  21. Mar 1, 2024 at 5:59 PM
    Azblue
    The Dirty T ( ^_^)_且
    :itllbuffout:
  22. Mar 1, 2024 at 6:06 PM
    But the frame is mint, right?
    artsr2002, BroHon[QUOTED] and Azblue like this.
  23. Mar 1, 2024 at 6:13 PM
    BroHon
    Bro
    2000 SR5 AC 4x4 4.7
    Better than mint, heat treated :thumbsup:
  24. Mar 1, 2024 at 6:22 PM
    khooiii
    khooiii 80HD
    DK
    DFW, TX
    03 Tundra AC 4WD
    Forgot how bright these things were. Fog lights blow out the colight led projectors and this pic doesn’t even do it justice. @Baja Designs FTW
    bmf4069, des2mtn, artsr2002 and 4 others like this.
  25. Mar 1, 2024 at 6:48 PM
    Damn. You could blind someone from 1/4 mile away.
  26. Mar 1, 2024 at 6:55 PM
    FishNinja
    Lee
    06DC2wd
    hmmm maybe I should aim mine a bit higher……
    artsr2002 and khooiii[QUOTED] like this.
  27. Mar 1, 2024 at 6:59 PM
    BroHon
    Bro
    2000 SR5 AC 4x4 4.7
    That's really nice dude, I wouldn't hate to drive at night anymore with those.
    btw, if I look too long at that picture I start to feel like I'm moving :eek2:
  28. Mar 1, 2024 at 7:19 PM
    Festerw
    Festerw New Member
    Cambridge Springs, PA
    04 Tundra DC
    I'd choose SKF personally just because I've used their bearings quite a bit at work with no issues.
    ToyotaDude[QUOTED] likes this.
  29. Mar 1, 2024 at 7:40 PM
    My delivery notification from UPS came as being from “NA” via email before I got stuff from Serra. Then the part invoice stuff came thru. The part arrived the next day. Indeed, it was quiet and jumbled order, but fast to get here.
  30. Mar 1, 2024 at 7:49 PM
    I’ve never noticed it before. Pretty sure my parts always had my name on em.
    I was gonna answer, “it started right up”, then I saw the replies. I couldn’t post much today.
    I’m surprised how long it took to ignition. Did you not kick the key on/off a few times to get the fuel pump to pressurize before starting up? Did you throw some MMO or similar into each cylinder for extra lubage?
