Rear end noise
Discussion in 'General Tundra Discussion' started by Huntersxsp, Feb 28, 2024.
  1. Feb 28, 2024 at 6:04 PM
    Huntersxsp
    Huntersxsp [OP] New Member
    Huntrr
    2010 Toyota tundra xsp
    3.5 in lift on 33x12.50r20 black wheels
    Ok so I’ve got a 2010 Toyota tundra xsp with 200,xxx miles and it’s making noise when I either speed up or decelerate it makes a clunking noise and it somewhat shakes but I’ve narrowed it down to either 1. It’s the carrier bearing or 2. It’s my rearend or 3. its my driveshaft u-joints either way I need to get it fixed I’ve looked at All the parts I need and the rear end has been serviced regularly like it should so I really don’t see why it would be making noise it does it sometimes tho it’s not all the time I don’t know what it would be can someone give me some pointers or some info on it please
    hunter,
  2. Feb 28, 2024 at 6:45 PM
    2mchfun
    Welcome to the forum! Crawl under it and see if you can wiggle around the driveshaft, sounds like you have sloppy and worn u joints and or a bad carrier bearing. You can jack it up and put it in neutral and just spin the tire by hand back and forth as well and see/hear what is clunking. YouTube will have videos on the repairs.
  3. Mar 1, 2024 at 5:08 PM
    Huntersxsp
    Huntrr
    Thank you I was hoping it wasn’t my rear end I really appreciate that
    2mchfun likes this.
