  1. Feb 29, 2024 at 7:55 AM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    2017 Tundra Platnium
    Too many mods to come
    Pavement princesses
    Wallygator and KNABORES[QUOTED] like this.
  2. Feb 29, 2024 at 8:05 AM
    Oh, the mall. Got it.
    reywcms[QUOTED] likes this.
  3. Feb 29, 2024 at 8:20 AM
    Phrog Driver
    Phrog Driver New Member
    2021 Silver Sky Crew Max TRD Off Road
    Sorry radon, it came with the truck. Truck was certified used but with only 2k miles on it when I got it, I was thinking the top shelf was stock? I'll go out after rain stops and see if it has any markings on it.
  4. Feb 29, 2024 at 8:28 AM
    RobertD
    Robert
    DFW, Texas
  5. Feb 29, 2024 at 8:28 AM
    radon222
    radon222 '21 CrewMax / '18 4Runner
    Ed
    NW Arkansas
    2021 CrewMax TRD OffRoad
    Stock for now
    Thanks Frog - Don't bother heading out. Turns out your right it is a Toyota accessory that includes the rails. I bought my truck used too and I guess the previous ditched the shelf somewhere but left the rails installed.
    https://parts.frontiertoyota.com/oe...-organizer-tray-2015-2020-tundra-pt9243415020
  6. Feb 29, 2024 at 8:29 AM
    radon222
    Ed
    NW Arkansas
    Stock for now
    Phrog Driver and RobertD[QUOTED] like this.
  7. Feb 29, 2024 at 10:55 AM
    Florida AF
    Logan
    North Florida
    Stock suspension/wheels 2017 2WD 1794 with Blue Ox weight dist hitch. Pulls without an issue, other than dropping into the 7-8mpg range.
    JMGmanAZ and WFD473 like this.
  8. Feb 29, 2024 at 2:01 PM
    EC1
    EC1 Ask about our BumperShellz Vendor
    Rocklin, CA
    BumperShellz
    :worthless:
    By "thread", I mean post :D
    LabRat[QUOTED] and bulldog93 like this.
  9. Feb 29, 2024 at 2:08 PM
    BoyHowdy
    BoyHowdy New Member
    2021 Tundra
    Damn those are beef
  10. Feb 29, 2024 at 6:46 PM
    Henry1jg
    Henry1jg 2021 TRD Sport
    MI
    I hope I find a matching shell for $500 some day!
    Damie Street and bulldog93 like this.
  11. Feb 29, 2024 at 7:21 PM
    biebs96
    PA
    not sure what you did, but 285/75 fit very well on these trucks.
  12. Feb 29, 2024 at 7:27 PM
    NTX_Tundra
    NTX_Tundra New Member
    I'm running 285/65/18 and I'm fine, I can't imagine you would have issues.
  13. Mar 1, 2024 at 6:48 AM
    Nice! I like those wheels. Just curious, what is that in front of the garage?
    Sierradevil likes this.
  14. Mar 1, 2024 at 6:48 AM
    coTony
    Tony
    Montrose, CO
    Well I have lost control of my right hand back in Dec 19th and been trying to figure out WTF a is wrong but still no answers. I have been on hold for a while (Dec 19 grrrrr) but have been working with it and can do some things. So I am going to go until I cannot any more…
    I started my build process in CAD (cardboard aided drafting) and got the base of the entire things figured out, more or less. Once I determined what the size would be I got my wood and started the basics
  15. Mar 1, 2024 at 7:56 AM
    Tripleconpanna
    2021 TRD PRO CM; 2008 SR5 CM
    :fingerscrossed:
  16. Mar 1, 2024 at 9:01 AM
    PomDad
    PomDad we having snacks?
    Conrad
    Atlanta
    2021 Cement Limited
    So I don't really want to bump an old thread to ask people's thoughts, but I'm doing my rear differential (and possibly front/xfer case) this weekend as well as installing the TRD swaybar. I'm just shy of 30k miles.
    My ask is - should I do my front/xfer case? I've probably put ~100 miles total on 4WD (mostly just bi-weekly shifts into 4WD to keep everything lubricated), so I'm thinking that it might be better to wait until 60k miles. Just curious if there's any reason I should do it sooner? I have a feeling I'd just be prematurely throwing out 'good' oil.
    bulldog93 likes this.
  17. Mar 1, 2024 at 9:03 AM
    AZBoatHauler
    So.Arizona
    I’d do the front diff and not touch the tcase yet. I’ve done the front diff twice - first time around 30k it was dirty and a little stinky. Did again just after 60k and it looked new. Get that break in junk out of there imo.
    I did the t-case around 75k and it was still serviceable.
  18. Mar 1, 2024 at 9:08 AM
    koditten
    Kirk
    Midland of the Mitten
    I know a guy:anonymous: who has removed both rear axles, replaced both rear wheel bearings, has 225k on odometer.
    The oil dripping off the axles when pulled, was clear as what comes new out of the bottle. This was at the 125k mark.
    That oil ain't getting changed, just checked for level.
  19. Mar 1, 2024 at 9:09 AM
    I use the 4wd system pretty infrequently, let's call it less than 100 miles a year. Changing the transfer case fluid and front diff fluid with that few miles will look like you are throwing out good oil. It will likely not be dirty, or worn out like the rear diff fluid looks. The recommended interval should still be followed to be safe, but I myself only do the T-case and front diff every 100k. Even then it still looks clean.
  20. Mar 1, 2024 at 9:27 AM
    1794TX
    Steven
    N.TX
    '20 1794
    I had the dealer change front, rear, and xfer at 20k miles, even against their objection that it's unnecessary. I had less than 200 miles in 4x for maintenance lube, and maybe another 100 actually off pavement. The service advisor said all of them looked pretty bad for only having 20k miles. It's not that expensive or troublesome.
    Tripleconpanna likes this.
  21. Mar 1, 2024 at 9:29 AM
    Would love to see the front diff and Tcase fluid that looked “pretty bad” in that scenario. If that’s true, I would want my diff and transfer case seals replaced under warranty.
    1794TX[QUOTED] likes this.
  22. Mar 1, 2024 at 11:06 AM
    1794TX
    Steven
    N.TX
    '20 1794
    'pretty bad for 20k miles' and 'pretty bad' might be two different things. I had it changed at 50k as well, and the shop didn't say anything was out of the ordinary. I know you get what you get with a Toyota shop, but Toyota of Plano is a good one, and they'd have told me if I needed to get additional work done. Best part is, the 4WD components have been used for their intended purposes much more in the past 35k miles than they were in the first 20k.
  23. Mar 1, 2024 at 11:18 AM
    monaco730
    monaco730 New Member
    16 Inferno Tundra
    Fox shocks, TRD Exhaust, TRD grill, TRD shift knob, weathertech floor/bed liners, ARE topper, FrontRunnerOutfitters cargo rack, Relentless cargo bars, color matched front bumper/side mirrors, fuel wheels, nitto RGs, K&N intake
    Lift and tire info, please!
  24. Mar 1, 2024 at 12:47 PM
    monaco730
    16 Inferno Tundra
    I'll let the truck owner respond. Thanks.
    Wishbone Runner likes this.
  25. Mar 1, 2024 at 12:50 PM
    koditten
    Kirk
    Seriously! The info is laid out very clearly in the first posts.
  26. Mar 1, 2024 at 1:04 PM
    PomDad
    Conrad
    Atlanta
    2021 Cement Limited
    Thanks all for the feedback! I'll definitely do the back, probably do the front (especially because I have the lexus plugs to install and don't want to store them for another ~3 years), and maybe do the xfer case depending on how the front's oil looks.
    Going to be a fun day tomorrow; hoping the front sway bar makes a somewhat noticeable difference (aside from looking cool lol).
  27. Mar 1, 2024 at 1:17 PM
    Yeah some people have no clue lol.
  28. Mar 1, 2024 at 1:39 PM
    Tundra979
    Tundra979 New Member
    '14 SR5 TRD Off Road Package Radiant Red
    Morimoto Headlight/Tail Light/3rd Brake light conversion. Interior LED's Alpine ILX-F511 Head Unit, Black out badges
    Found a good deal for a Black TRD Pro grille and Hood bulge. I'm still waiting for my bumper shellz to come in to have it all color matched66781.jpg and I'm impatient. So for now, just a new grille.
  29. Mar 1, 2024 at 1:42 PM
    bulldog93 and Terndrerrr like this.
  30. Mar 1, 2024 at 1:43 PM
    Or lazy.
    JMGmanAZ, Vendeta2k and Sierradevil like this.
