Skid plates or No
Discussion in '2.5 Gen Tundras (2014-2021)' started by TundraJC, Feb 25, 2024.
  1. Feb 25, 2024 at 2:06 PM
    TundraJC
    TundraJC [OP] New Member
    2014 Tundra SR5
    What's up yall.
    So I was looking around my new to me 2014 Tundra. I have no skid plates.
    Should I get at least the front one?
    It most likely won't go off roading.
  2. Feb 25, 2024 at 2:21 PM
    I believe RCI has a sale going on right now.
  3. Feb 25, 2024 at 4:09 PM
    Saltyhero13
    Saltyhero13 Throbbing Member
    If you don't offroad get cat plates. Tundras are a prime target for cat thieves.
    PolishedTRD likes this.
  4. Feb 25, 2024 at 4:11 PM
    Skid plates can protect your truck from road debris. It's not just for off road obstacles. I always opt for them, but if you do not off road I'd spend the money for the TRD Pro plate. It looks good, is lighter than steel, and has an access door for oil changes.
    Cat protection like @Saltyhero13 is a good idea too. Shitbags target Tundras and Tacomas because they are easy to get under and they have 4 catalytic converters.
    ATV25 and equin like this.
  5. Feb 25, 2024 at 4:43 PM
    d33pt
    d33pt New Member
    What's the sale? Is there a coupon code?
  6. Feb 25, 2024 at 4:46 PM
    Talon2006
    Talon2006 New Member Vendor
  7. Mar 1, 2024 at 6:50 AM
    Black widow TRD
    Black widow TRD New Member
    Manuel
    2023 Black Tundra SR5/TRD
    RCI makes some really fine products!!
    2mchfun and Sean492 like this.
  8. Mar 1, 2024 at 6:52 AM
    coTony
    Tony
    Montrose, CO
    I am tempted to buy a new set of aluminum. I want to replace my steel with the aluminum and that sale is tempting
  9. Mar 1, 2024 at 7:18 AM
    Sean492
    Sean492 New Member
    Winston Salem, NC
    2018 MGM Tundra Sport
    Tons of people on here have their OEM skid plate sitting in the garage since it was replaced. If you don't mind a simple OEM skid plate for the front they are sometimes listed on here as free. Post that you are in the market and I bet you could pick one up cheap in your local area.
    Totmacher and 2mchfun like this.
  10. Mar 1, 2024 at 8:13 AM
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Don't have plates on either of our rides and haven't had any issues. The OEM plate for the Sequoia is sitting in the garage. I don't even think my 2016 had one when I bought it new. We do have a big ass plate for cats
    WILLINH likes this.
  11. Mar 1, 2024 at 9:07 AM
    equin
    equin Texarican Tundra
    Ed
    DFW, TX
    Agree 100%. My 2015 SR5 came without skid plates. I bought and installed a TRD Pro skid plate, and shortly thereafter the skid blocked a wooden block a vehicle in front of me spit out at highway speed. It was a loud smack. Not sure what would’ve happened if I didn’t have that skid plate.
    As for cat shields, I got them AFTER all 4 cats were stolen. The thieves caused over $7500 in damage cutting the fuel line and some kind of purge valve line, not to mention the O2 sensors. Instead of waiting months for OEM cats (which my USAA insurance fine print wouldn’t cover) I went with aftermarket cats. They worked for awhile until the check engine light kept comingon and then stayed on, risking failure of the state-mandated emissions testing. I ponied up the money out-of-pocket for OEM cats and finally got to install them after a painstakingly long 10 month wait.
    So in short, my advice is to get both a front skid and cat skids!
    ATV25 and 2mchfun like this.
  12. Mar 1, 2024 at 9:22 AM
    Saltyhero13
  13. Mar 1, 2024 at 9:51 AM
    b6graham
    b6graham New Member
    2020 Voodoo 1794 RW Wheels 315/70
    what's your location?
    might be able to find someone local with a take off
    WILLINH and 2mchfun like this.
  14. Mar 1, 2024 at 9:58 AM
    2mchfun
    Yes, plate that beast. That said, I suggest saving money with DIY plates. They don't have to be beautiful, only functional. I'm even a fan of recycled materials if they're available. Tools can be bought used and sold, which can basically eliminate those costs. Lots of pictures are available on the web, even in this thread. Cardboard makes great templates. I'd even suggest plating the fuel tank as well because thieves like to drill tanks when gas gets expensive. If enough tanks get drilled, you could have problems finding a replacement and be left with a truck that can't move. Long story short, an ounce of prevention is worth a pound of cure.:thumbsup:
    equin likes this.
  15. Mar 1, 2024 at 12:15 PM
    TundraJC
    2014 Tundra SR5
    Lockport, IL.
    Any issues with heat for the cat plates?
  16. Mar 1, 2024 at 1:04 PM
    2mchfun
    Excellent question! Heat isn't good for sure. Answer is venting, and plenty of it. In fact, if I purchased any of the aftermarket plates, more venting would be cut prior to the installation. Not only does it vent better, it also becomes lighter which makes installation easier and less load on the truck.
  17. Mar 1, 2024 at 1:13 PM
    Saltyhero13
    I think @Tundra234 tested temps and it was ~100* difference.
    Tundra234 likes this.
  18. Mar 1, 2024 at 1:19 PM
    The truck doesn't notice the weight. It's different than unsprung weight like tires.
  19. Mar 1, 2024 at 1:20 PM
    I'm in FL and I have no issues at all with heat. I am running full engine skid and front and rear cat plates. Not too much temperature change after the installation.
  20. Mar 1, 2024 at 2:45 PM
    2mchfun
    Weight affects payload, fuel mileage, braking distance, handling, etc. Just depends on what compromises each individual wants to make.
  21. Mar 2, 2024 at 1:05 PM
    mfelton18
    mfelton18 I'M THE PROBLEM
    South Central Texas
    2014 Magnetic grey SR5 4x4 crewmax
    Eibach Stage 2, RCI armor, Method 705
  22. Mar 2, 2024 at 4:10 PM
    tufftundy11
    tufftundy11 New Member
    2000 tundra limited
    King shocks, spc upper control arms
    i haven't had skid plates on for a few years and have done a lot of offroading. maybe ive just been lucky. 37s keep me off the ground pretty too though
  23. Mar 3, 2024 at 6:21 AM
    Talon2006
    There is always luck, until there isn’t.
    This weekend my buddy rolled his International scout with a 7.3 idi swapped in it. We could literally see the end of the trail and he missed a little hole that flipped him over. Thankfully he is ok!
    WILLINH and equin like this.
  24. Mar 3, 2024 at 3:10 PM
    mfelton18
    South Central Texas
    oof
  25. Apr 1, 2025 at 3:39 PM
    illfixit
    illfixit New Member
    Potter Co.
    15 TUNDRA TRD OFF ROAD
    SKID PLATES!!!!! For times like these!!!
  26. Apr 1, 2025 at 3:54 PM
    rheosibal
    rheosibal New Member
    2.5 Platinum OEM+
    and times like these...
  27. Apr 1, 2025 at 4:01 PM
    TacomaTRD4x402
    TacomaTRD4x402 New Member
    Southern California
    :eek:
  28. Apr 1, 2025 at 4:02 PM
    TacomaTRD4x402
    Southern California
    Finally going to pull the trigger on this.
    @Talon2006 Sent you a DM
    Wish I could drive n pick them up :(
  29. Apr 1, 2025 at 4:25 PM
    SAGE63
    San Diego County
    Convertable mod in porgress...
    Glad your friend is ok
  30. Apr 1, 2025 at 5:25 PM
    CasperTheFriendlyTundra
    CasperTheFriendlyTundra New Member
    Get the TRD knock off skid plate from Amazon. Under 200.00 shipped.
