General Supercharger Thread
  1. Feb 29, 2024 at 10:19 AM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    JBA Longtubes, Snivs 2.0 SC pulley, ASP crank overdrive pulley 6.71 in, DD Full 3inch dual exhaust, IPT valve body, Airbox mod, 4.5inch intake, Denso 750, 450 Walbro, W/M injection, GM 95mm TB, SABM, Camburg UCA, Icon shocks, Speedmaster LSD, Motive 5.29 Gears, Mickey Thompson Baja Legend EXP 35's, solid Offroad engine mounts, DIY Traction Bars, Tuning by snivspeedshop.com
    I remember @snivilous telling me to have a good internet connection, fully charged laptop battery and make sure it doesnt update during your session. Turn all that bubblegum crap off.
    Costco had a sale on a cheap Lenovo IdeaPad for $200. Wasn't sure if its good but only use it for dedicated HPT and Techstream. I passed on the deal but still thinking about it since it's cheap.
  2. Feb 29, 2024 at 10:22 AM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    This right here! Why I wired an accessory on/off switch for all nonessential stuff drawing amps with ign on.
  3. Feb 29, 2024 at 10:28 AM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    If you don't have your laptop for dataogging I use my phone to record. I'm able to record the gauges, afr/boost/fuel psi, and rpm for shift points. Helps me see the lag in PE when it shifts and if it needs some adjustment. But data log is best! Just make sure your looking at the road!
  4. Feb 29, 2024 at 11:02 AM
    carn_dogg
    carn_dogg i don't think so
    Pat
    Eastern Shore MD
    2013 Black Tundra Platinum
    mans wants me to blow my truck up for the 0-60 run?!
    I'll get a few runs done once I make sure my truck isn't running too lean at high rpms... or 650's and a tune is next
  5. Feb 29, 2024 at 11:16 AM
    snivilous
    SW UT
    300k+ Supercharged 2008
    I just emailed a guy a tune and this was the list of things I told him I do to try and flash successfully:
    1. If you have a battery tender/charger plug that in so the battery voltage stays up. If this isn't an option, I drive the truck around and warm it up so the battery is topped off.
    2. Have a reliable internet connection. I even go so far as to hotspot off my phone since I don't trust the wifi from dropping out.
    3. Turn everything off in the truck. Headlights, interior lights, radio, climate controls, everything possible so there's no extra draws.
    4. Make sure the laptop isn't going to crash. I personally close everything except HP Tuners to try and avoid any other programs hijacking the CPU and triggering something. If you have to plug in your laptop so be it. Maybe sit there and twitch the mouse so it won't turn off if you're unsure what the standby time is.
    5. Once I click flash I don't touch anything, the last thing you need is for the USB cord to get bumped and lose continuity.
    6. Pray to the ECU gods.
    Wynnded, ARES35, armyoffoo and 4 others like this.
  6. Feb 29, 2024 at 11:21 AM
    M3Tundra-JK
    M3Tundra-JK New Member
    Scott
    2005 GX470
    Just get a trickle charger and hook it up while you tune and you'll be fine. I have the one linked below
    https://www.amazon.com/gp/product/B00GODGN9E?ie=UTF8
  7. Feb 29, 2024 at 11:45 AM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    Another item HPT support suggested to me when I had issues was to buy a high quality USB cord. Suggested I don't use the one sent in their kit. Go figure that one...
    PolishedTRD, Wynnded and reywcms like this.
  8. Feb 29, 2024 at 11:55 AM
    reywcms
    reywcms New Member
    Rey
    Beaverton,Oregon
    2017 Tundra Platnium
    Too many mods to come
    LOL makes no sense
    Wynnded, helidave and Mdl[QUOTED] like this.
  9. Feb 29, 2024 at 12:05 PM
    snivilous
    SW UT
    :rofl: the fuck
    Wynnded likes this.
  10. Feb 29, 2024 at 12:15 PM
    blenton
    blenton New Member
    I’ve thought about doing this. Wasn’t sure how well it would work with parallels and my older machine as I’m not sure my little M1 MBP that I usually have in my bag in the truck has enough room or HP for it. I used to run Parallels on my iMac but it has 32GB of ram so I didn’t have any resource issues.
  11. Feb 29, 2024 at 3:27 PM
    ARES35
    ARES35 New member for life
    Mile high
  12. Feb 29, 2024 at 3:42 PM
    NatesNightMare
    NatesNightMare Is what it is
    Pinetop Az
    Put Snivs 76mm pulley on Mon and it WAKES this thing UP! Im at 7k ft and she screams! Gonna be fun when I travel into lower altitudes lol
    Silver17, Mdl, reywcms and 6 others like this.
  13. Feb 29, 2024 at 3:55 PM
    NatesNightMare
    Pinetop Az
    I did my own and it was simple for the most part
    koditten[QUOTED] and Mdl like this.
  14. Feb 29, 2024 at 4:58 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    Keep an eye on those afr's when approaching sea level. Try to keep it at 10.5 afr or lower when on it...
  15. Feb 29, 2024 at 9:17 PM
    NatesNightMare
    Pinetop Az
    I need to get an afr setup but cant afford it right now
  16. Feb 29, 2024 at 11:06 PM
    helidave
    helidave Hellacopter
    flagstaff
    2015 DC 4x4
    Bench recovery of the ECM appears to be unsuccessful. Was able to get it to do the force reflash of the stock file with VF, but it's still behaving the same as before. :annoyed:
    snivilous[OP] likes this.
  17. Mar 1, 2024 at 5:35 AM
    snivilous
    SW UT
  18. Mar 1, 2024 at 7:39 AM
    ARES35
    Mile high
  19. Mar 1, 2024 at 8:18 AM
    helidave
    flagstaff
    2015 DC 4x4
    Anybody know what fusible link @Fastlane47 had blow in his truck that made it look like the ecm bricked?
    Mat at VF seemed to think it could be a blown fuse, but I can't find any.
  20. Mar 1, 2024 at 9:33 AM
    NatesNightMare
    Pinetop Az
  21. Mar 1, 2024 at 10:00 AM
    ARES35
    Mile high
    The DD exhaust starts to scream once that pulley starts spinning lol.
  22. Mar 1, 2024 at 10:27 AM
    carn_dogg
    Pat
    Eastern Shore MD
    Did you do boost ref cause you went smaller pulley or was your truck running lean with stock mag tune and kit components. Can’t remember
    ARES35[QUOTED] likes this.
  23. Mar 1, 2024 at 11:31 AM
    ARES35
    Mile high
    Yes I couldn't get enough power enrichment with dialed in fuel trims with 43 psi regulator boost referenced with 76mm pulley. Duty cycle was maxed. So I did the jumper on the FFV relay for 60psi boost referenced. Now I'm deducting fuel in PE and gained back InjDC. Furthermore non boost referenced with regulator being pulled from the intake tube I was leaning out in lower rpm when getting into PE. Boost referenced with PE adjustment richened low rpm cells for me.
  24. Mar 1, 2024 at 11:31 AM
    V10Ace
    V10Ace New Member
    Salem, Oregon
    '21 TRD PRO
    Harrop w/ Prospeed goods & Kooks LTs
    Recently started trying out 4wd launches. Power steers like crazy! Way more violent than 2wd :cool:images.jpg
    kbark, Black@Blue19, Wynnded and 6 others like this.
  25. Mar 1, 2024 at 11:37 AM
    carn_dogg
    Pat
    Eastern Shore MD
    ok so you were fine until you added 76 pulley. Then ran lean. Did boost ref. Wasn’t enough. Did jumper with boost ref to gain another 10psi and then ran too rich. Now you’re dialing it back to give your injectors a break. You’re on 535’s? Or upgrade to 650?
  26. Mar 1, 2024 at 11:44 AM
    ARES35
    Mile high
    Yes running off the 43 psi with FFV relay pulled, 750cc injectors, 76mm and non boost referenced I could not get enough fuel. I would lean out from 4400-6000 rpm. Then I boost referenced at 43 psi and tuned the MAF/re adjusted PE. That cleared up running lean getting into boost but not up high. Then jumping the relay to 60psi, BR'ed, MAF adjusted was able to decrease all my multipliers in the PE table. Now I'm right at 10.5 A/F up top..... I'm still tuning leaner down low when getting into boost. She taps in at 9-9.4 in the lower rpm ranges. For reference here is a log I pulled earlier. As you can see I need to decrease the PE in the lower rpm ranges.
    FYI also keep in mind I did reset ethanol content to zero. It kept creeping positive in the fuel trims and had me at 39% ethanol. Never had I ran corn in this vehicle.
  27. Mar 1, 2024 at 12:03 PM
    NatesNightMare
    Pinetop Az
    Hkw did you think you were running lean/rich? Was it feeling off, stutter, power loss? Or just ran numbers to see?
    You think it has something to do with the FF system?
  28. Mar 1, 2024 at 12:06 PM
    ARES35
    Mile high
    I'm logging A/F via pro link on scanner. When I was lean MFER would move with knock feedback above -3.0. When I running rich I would misfire and throw a code. FFV logic is fucked up imo. Fuel density is a problem and has to be reset to zero now and then.
  29. Mar 1, 2024 at 12:43 PM
    NatesNightMare
    Pinetop Az
    Yeah you had me worried when I I travel and drop into lower alt's lol but looks like youre fighting with the ffv
  30. Mar 1, 2024 at 12:46 PM
    ARES35
    Mile high
    FFV is a pain, makes everything so inconsistent. Just tune on the rich side and make sure your MAF table is dialed in and you'll be golden:D
