Running skiny tires
Discussion in '1st Gen Tundras (2000-2006)' started by 06 daily driver, Feb 28, 2024.
  1. Feb 28, 2024 at 9:11 PM
    06 daily driver
    06 daily driver [OP] New Member
    2006 Tundra
    None
    Replacing stock 265/65/17’s on stock 06 tundra 4x4. Any issue's going to 235/80/17’s
  2. Feb 28, 2024 at 9:51 PM
    blenton
    blenton New Member
    You opening up a pizza joint?
    PomDad, OHwendTrd, Weagle and 2 others like this.
  3. Feb 28, 2024 at 10:32 PM
    06 daily driver
    2006 Tundra
    None
    I like the look of a taller tire and the better traction on slick roads
  4. Feb 28, 2024 at 10:54 PM
    06 daily driver
    2006 Tundra
    None
    I meant the better traction of a narrower tire on slick roads
  5. Feb 28, 2024 at 10:54 PM
    blenton
    blenton New Member
    Then I don’t see a problem. The 235’s are good up to 8” wide rim so as long as you aren’t running anything wider you should be good. The tire is a little taller but if memory serves, you are ok up to a 32” tire.
  6. Feb 28, 2024 at 11:18 PM
    06 daily driver
    2006 Tundra
    None
    Appreciate the info, especially from people that know tundras
  7. Feb 28, 2024 at 11:25 PM
    blenton
    blenton New Member
    Weagle likes this.
  8. Feb 29, 2024 at 5:30 AM
    Elevatorguy
    Elevatorguy Yotas and JD Green!
    James
    05 DC, 4.7, 4wd, LSD.
    Never skip leg day! I wouldn’t run a 235, 255 will look better, pick your sidewall flavor.
    aredub and Weagle like this.
  9. Feb 29, 2024 at 5:36 AM
    Especially with gold wheels. Every time.
  10. Feb 29, 2024 at 5:49 AM
    yup
  11. Feb 29, 2024 at 5:59 AM
    I've never seen anyone run that size but I'm sure it would be fine. Is your truck only used on pavement?
    Personally, I'd want 255/80/17's
    Elevatorguy and Weagle like this.
  12. Feb 29, 2024 at 7:18 AM
    87warrior
    87warrior Whiskey Tango Foxtrot
    Kansas
    2004 DC 2uz 4x4
    I'd really like to see a picture of a first gen running 235/80R17 tires on the stock wheels. Pizza cutters always look like they belong on a Toyota.
  13. Feb 29, 2024 at 7:19 AM
  14. Feb 29, 2024 at 7:26 AM
    Man that looks goofy.
    Elevatorguy likes this.
  15. Feb 29, 2024 at 9:25 AM
    FishNinja
    FishNinja HIDE YOUR DAUGHTERS
    Lee
    TEXAN....big surprise
    06DC2wd
    nope
    edit: yo why does that thing have leafs in the front?!?!
  16. Feb 29, 2024 at 9:28 AM
    nice catch. It’s been SAS’d. Also full disclosure, I have no idea what size tires those are. But they are tall. And they are skinny.
  17. Feb 29, 2024 at 4:49 PM
    Elevatorguy
    James
    I like gold, Gold or bronze wheels belong on absolutely nothing.
    Jack McCarthy likes this.
  18. Feb 29, 2024 at 5:08 PM
    FishNinja
    Lee
    06DC2wd
    there. Fixed it for you
    The Black Mamba and PlatinumPro like this.
  19. Feb 29, 2024 at 5:27 PM
    Elevatorguy
    James
    You fixed nothing. Gold wheels belong on nothing just like your sawzall modded front bumper.
  20. Feb 29, 2024 at 6:17 PM
    whodatschrome
    whodatschrome New Member
    North of North Plains, Oregon
    lots of dents
    I'm going to take a wild guess that they're a 36.5" Michelin 900r16 XZL Tire? I've looked at them in the past to possibly use on my old Ford Highboy flatbed, but i don't want a tire that tall. In fact i don't want over a 33" on the truck...and the truck sees LOTS and LOTS of offroad work abuse.
    https://garbee.net/~cabell/photos5.htm
  21. Mar 1, 2024 at 3:24 AM
    FishNinja
    Lee
    06DC2wd
    Oh. You mean this one?
    shmuck
    The Black Mamba likes this.
  22. Mar 1, 2024 at 10:04 AM
    Elevatorguy
    James
    Yup. I see it’s evolved some.
  23. Mar 1, 2024 at 11:30 AM
    The Black Mamba
    BlackSnek
    Flower Mound, TX
    Black 00 SR5 AC 5VZ PreRunner
    Imma keep it stock
    So when are you placing an order for gold wheels? :rofl:
  24. Mar 1, 2024 at 12:18 PM
    FishNinja
    Lee
    06DC2wd
    literally this weekend or next. Then 9six9 TE knocks offs babyyyyyy
  25. Mar 1, 2024 at 12:25 PM
    Mr Badwrench
    Mr Badwrench New Member
    The only drawback is they only make them in a load range E. They are dually tires. I guess if you currently have load range E's, it won't be a big concern.
