Axle housing Swap
Discussion in '1st Gen Tundras (2000-2006)' started by woodenfrog, Feb 27, 2024.
  1. Feb 27, 2024 at 8:47 AM
    woodenfrog
    woodenfrog [OP] New Member
    New England
    '03 Reg. Cab Long Bed 2wd
    Hi,
    I'm looking to replace the axle housing on my 03 tundra regular cab 2wd v6 abs. I found one online that is from and 05 access cab with abs. From what I've read this should fit? I am re-installing the third member so nothing is changing with the gears. Can anyone tell me if this will or won't work?
    Thanks in advance
    scooterprint likes this.
  2. Feb 27, 2024 at 9:10 AM
    whodatschrome
    whodatschrome New Member
    North of North Plains, Oregon
    lots of dents
    I’m fairly positive that the housings are the exact same. And when i mean fairly positive, i mean i would have 100% confidence in heading over to the wrecking yard and removing ANY abs axle housing from ANY v6 or v8 2000-06 single cab or access cab (NOT a double cab) truck and totally expect it to fit my own truck.
  3. Feb 27, 2024 at 1:48 PM
    woodenfrog
    New England
    whodatschrome likes this.
  4. Feb 27, 2024 at 4:39 PM
    whodatschrome
    lots of dents
    Out of curiosity, how much is the one that you found?
  5. Feb 27, 2024 at 5:33 PM
    woodenfrog
    New England
    @whodatschrome it is 200 bucks and comes with the axles as well as the housing. The thing is rusty so I'll need to refinish it but it's got plenty of life left. I'm not sure if I'll be able to use the axles but I'll hold onto them anyway
