Is this engine ticking bad? (VIDEO) (With Updates from Dealer)
Discussion in '3rd Gen Tundras (2022+)' started by Delta1Seven, Jan 22, 2024.
  1. Jan 22, 2024 at 3:50 PM
    Delta1Seven
    Delta1Seven [OP] New Member
    Damien
    Truck isn't even 48 hours old. I just purchased it brand new this weekend, only 210 miles on the odometer.
    Any idea what this ticking sound is? Seems to only happen after the truck is put into drive (and back into park).
    UPDATE #2: Was told to pick up the truck as there were no issues and this sound was "Normal Operation of the vehicle" I didn't even make it off the lot before the noise got much louder. I drove right back into service to give my keys back to the Service Advisor. He denied there was an issue, so I went to sales and had them start up new Tundra's on their lot. None made this issue. The salesman was kind enough to walk back to Service with me and he got them to take the truck back to further troubleshoot.
    Update #3: I got the text this morning (9 days of ownership, 7 of those days the truck has been at the service department), that the transmission will need to be replaced. I am a bit nervous on the quality of repair they will perform, as originally there was no issue according to their techs. So it's a bit concerning, especially for such a major replacement at only 210 miles on the odometer.
    I will update further as the situation continues.
    Eurodriver likes this.
  2. Jan 22, 2024 at 3:51 PM
    Is that the transmission tick?
    AZBoatHauler likes this.
  3. Jan 22, 2024 at 3:53 PM
    Delta1Seven
    Damien
    No idea. Is that a common issue? Is it bad?
    The sound seems more pronounced towards the bottom/rear of the engine, so could very well be coming from the transmission.
  4. Jan 22, 2024 at 3:57 PM
    It’s been discussed in several different threads here
  5. Jan 22, 2024 at 6:53 PM
    Hella Krusty
    Hella Krusty New Member
    Put it this way.....that aint normal. I can guarantee mine doesn't sound like that
  6. Jan 23, 2024 at 9:56 AM
    Tom976
    Tom976 New Member
    Tom
    Listen to the tick... sounds like morse code.
    Lets translate...
    ... = S
    --- = O
    ... = S
  7. Jan 23, 2024 at 9:59 AM
    TRDFerguson
    Jake
    Southeast Greater Basin, AZ
    2018 MGM CrüeMax
    I think it might actually be:
  8. Jan 23, 2024 at 10:05 AM
    AZBoatHauler
    So.Arizona
    I know there have been several of these requiring replacement - hopefully they get you up and running soon.
    Tundrastruck91 likes this.
  9. Jan 23, 2024 at 10:33 AM
    BigT27
    BigT27 New Member
    Sounds like an exhaust leak?
  10. Jan 23, 2024 at 10:37 AM
    AZBoatHauler
    So.Arizona
  11. Jan 23, 2024 at 10:43 AM
    Delta1Seven
    Damien
  12. Jan 23, 2024 at 10:50 AM
    AZBoatHauler
    So.Arizona
    Yours almost sounds like the flywheel grinding a bolt
    https://www.tundras.com/threads/ticking-noise-on-brand-new-2024-tundra.134910/
  13. Jan 27, 2024 at 8:46 AM
    james_1234
    james_1234 New Member
    James
  14. Jan 27, 2024 at 8:48 AM
    Black@Blue19
    Black@Blue19 Old Salt
    Ken
    SE Texas
    Dealer problem.
  15. Jan 27, 2024 at 9:06 AM
    Alden
    Alden New Member
    Mine doesn't sound like this at all. I'm sitting at 13k miles. Take it back to the dealer.
    Could be something as simple as a heat shield rattling.
  16. Jan 29, 2024 at 10:08 AM
    Delta1Seven
    Damien
  17. Jan 29, 2024 at 10:10 AM
    Delta1Seven
    Damien
    Thanks for the input. I just got informed they are going to replace the Transmission. Hopefully this doesn't lead to a problematic future of a brand new truck.
  18. Jan 29, 2024 at 11:07 AM
    WtnTN
    WtnTN New Member
    Wyatt
    2024 Platinum Tundra
    I scrolled down and might have missed it but...How did the truck drive/perform with that noise?
  19. Jan 29, 2024 at 1:20 PM
    bcusitsjeff
    bcusitsjeff New Member
    Jeff
    I just picked up my Limited on Thursday and drove down to San Diego the next day, about 140 miles and started hearing the same thing when I parked the truck
    Toyota1990 likes this.
  20. Jan 29, 2024 at 1:31 PM
    Delta1Seven
    Damien
    I only have 200 miles on the truck as I purchased new, and that was mostly highway mileage so it's hard to determine. But the truck seemed fine, other than the noise as far as my short experience has showed.
  21. Jan 29, 2024 at 1:33 PM
    Delta1Seven
    Damien
    My condolences.
    Check with your finance paperwork to see if they have any type of 7 day refund/return type guarantee. My dealer does not, but I do know some do offer this type of guarantee.
    Mattedfred likes this.
  22. Jan 29, 2024 at 1:38 PM
    bcusitsjeff
    Jeff
    Ill have to check the paperwork tonight. As long as Toyota does right and fixes the truck without too much downtime Ill be fine with that.
    Tom976 likes this.
  23. Feb 25, 2024 at 9:12 PM
    Toyota1990
    Toyota1990 New Member
    Mine is doing the same thing. You can even hear it inside the cab. It's loudest when truck is in park and not under load. Sounds like something internally in the transmission. Guess I'll be headed back to the dealer. Truck has 200 miles.
  24. Feb 25, 2024 at 9:18 PM
    Tundrastruck91
    Tundrastruck91 New Member
    2024 TRD Pro Terra Tundra
    Sucks, hope Toyota gets it rectified quickly !
  25. Feb 25, 2024 at 9:32 PM
    Azrsx
    Azrsx New Member
    2023 tundra blueprint limited
    This is a bummer to see, Toyota will make it right but damn not even 300 miles...
  26. Feb 26, 2024 at 8:23 AM
    james_1234
    James
    What's the build dates for guys that are having transmission issues/replacements? Mine is October 2023. Has been in the shop since January 10. Took them almost a month to decide to replace the transmission and has been waiting on the transmission since. Supposedly will be here next week.
