  1. Feb 25, 2024 at 7:29 PM
    Lost an hour and a half swapping them back. They literally work on either side of the engine. But the fuel rails on a modern LT have plug ins on the back. Noticed that fact after we bolted them in. Thankfully we didnt fully torque them down when we noticed it.
    NUDRAT[OP], Sunnier, BroHon and 2 others like this.
  2. Feb 25, 2024 at 7:30 PM
    Ouch.
  3. Feb 25, 2024 at 7:46 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    @KNABORES when you said o-ring in reference the the wheel bearings the other day, were you talking about the snap rings? I'm trying to make sure I order everything for front and rear wheel bearings. I'm not sure if I need to replace them all, but I know I need to replace at least one, if not a couple.
    Did you get your finger stitched up?
  4. Feb 25, 2024 at 7:53 PM
    des2mtn
    SW
    2004 Black DC Limited 4x4
    Tonto cover
  5. Feb 25, 2024 at 7:57 PM
    Don’t recall the O-ring comment, but there’s an inner and outer seal and some sort of snap ring jobber that you have to press the bearing one way to start, remove the first piece and then flip the spindle and press the bearing out the other way. At least that’s what sue did.
    And hell naw I didn’t get any stitches. Got the bleeding to stop with a filthy shop rag. Then washed it in the sink and poured peroxide in it. Not too bad. Then held pressure a little longer with a clean paper towel and sprayed what I thought was liquid bandage antiseptic on it, however I’m convinced it was aerosolized and ignited nitro-methane. After I could see again, I added some liquid stitch in a bottle and bandaid and finger condomed that booger picker. Good as new, back in the shop. Only snitches get stitches. Or wind up in ditches.
  6. Feb 25, 2024 at 8:01 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    My parts list is already over $1k with the discount. Fuck. I think I might just write down all the part numbers and wait till the next sale. Seems they run these things every few months. No big rush to get the 4x4 in tip top shape.
    NUDRAT[OP] likes this.
  7. Feb 25, 2024 at 8:01 PM
    Mr.bee
    Mr.bee King Turdra
    '02 AC TRD
    I've camped in ditches, and never snitched. :notsure:
    Also 'drifted' a fwd eagle talon into a ditch, but dont wanna talk about that.
    KNABORES and BroHon like this.
  8. Feb 25, 2024 at 8:04 PM
    des2mtn
    SW
    Tonto cover
    For the rears, there is an o-ring that goes on the axle housing itself. The axle housing has a raised lip that goes into the bearing housing on the axle shaft. The axle housing also has an inner axle seal. This is separate from the outer axle seal on the axle shaft itself.
  9. Feb 25, 2024 at 8:05 PM
    Mr.bee
    Mr.bee King Turdra
    '02 AC TRD
    i dont think i'm gonna have time this trip, but next time i come down we'll get the 4x4 up to 50mph on jackstands while i lay underneath & listen to the bearings through a screwdriver.
  10. Feb 25, 2024 at 8:08 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    Word. You need me to bring anything west with me next week? A certain dyi bumper kit perhaps?
  11. Feb 25, 2024 at 8:10 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    For the fronts do I need new snap rings or can I reuse those? They want $8 a pop with the discount.
  12. Feb 25, 2024 at 8:17 PM
    Mr.bee
    Mr.bee King Turdra
    '02 AC TRD
    Not that i can think of, and i'd have to order a move bumper, because i'd want the plate with the logo bent backwards.
    tpope likes this.
  13. Feb 25, 2024 at 8:18 PM
    des2mtn
    SW
    Tonto cover
    I've never done the fronts, but I would look at the FSM to see the instructions. They will usually indicate if Toyota calls for a part like that to be replaced and not reused.
  14. Feb 25, 2024 at 8:53 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    What do you mean?
    Like flat?
    Anyways, the dude told me he'd give you a good deal, if that makes any difference.
  15. Feb 25, 2024 at 8:57 PM
    Mr.bee
    Mr.bee King Turdra
    '02 AC TRD
    No, i wanna weld it in backwards, so the move logo is mirrored, and when i turn on the light behind it, people can read it in their rearview mirror. They'll get that warning for a solid 5 seconds before i start to push.
    JasonC., bmf4069, KNABORES and 2 others like this.
  16. Feb 25, 2024 at 9:04 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    Judging by the pic I sent you, that could be done with ease, by flipping that section of the kit 180° before welding it in.
  17. Feb 25, 2024 at 9:08 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    Damn, I'm looking at moves site now. They actually do have a few bumpers that I don't dislike. Interesting. I thought that just had one or two designs. Looks like they stepped their game up.
  18. Feb 25, 2024 at 9:09 PM
    Mr.bee
    Mr.bee King Turdra
    '02 AC TRD
    Pretty sure the center section is bent, not welded. Yea, it could be done, but thats alot of extra work for a dumb gimmick.
  19. Feb 25, 2024 at 9:15 PM
    Mr.bee
    Mr.bee King Turdra
    '02 AC TRD
    https://youtu.be/SdfW_2frXnE?si=I2kiouvy5hm8wG8W
    JasonC. and BroHon like this.
  20. Feb 25, 2024 at 9:19 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    It might be. I assumed each piece had to be welded. That way it could ship in a smaller package, as pieces would lay flat. I'll ask Juan about it.
  21. Feb 25, 2024 at 9:21 PM
    Mr.bee
    Mr.bee King Turdra
    '02 AC TRD
    I saw this and assumed.
  22. Feb 25, 2024 at 9:29 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    You might be right.
    I like this
  23. Feb 25, 2024 at 10:26 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    It won't let me place my order.
    Edit: I got it to work as a guest. They claimed nationwide free shipping, yet in my email receipt it shows I paid $42 for shipping and handling. Any body else notice this BS?
    BroHon likes this.
  24. Feb 25, 2024 at 10:51 PM
    artsr2002
    artsr2002 2005 Tundra DC SR5
    'Yonder
    Internet hug of death perhaps?
  25. Feb 26, 2024 at 3:22 AM
    I realized last night that I didn't have the wheel straight when I removed the tie rods. But I did count the spins (17 and 18) and I haven't moved the wheel since they have been off.
    Should I leave the wheel alone for now or go ahead and straighten it before I install the new tie rods? I'd like for the toe to be close but I'll take it for an alignment either way.
  26. Feb 26, 2024 at 3:23 AM
    Shipping should have been free over $75. What dealer did you use?
  27. Feb 26, 2024 at 3:25 AM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    Serra Toyota Birmingham, AL
  28. Feb 26, 2024 at 3:29 AM
    The Black Mamba
    Snek
    DFW
    Black 00 SR5 AC 5VZ PreRunner
    Imma keep it stock
    You should be close
  29. Feb 26, 2024 at 3:31 AM
    The Black Mamba
    Snek
    DFW
    Imma keep it stock
    Still down this morning
  30. Feb 26, 2024 at 3:36 AM
    The Black Mamba
    Snek
    DFW
    Imma keep it stock
