Diff shavings ok or bad news?
Discussion in '2.5 Gen Tundras (2014-2021)' started by Toyotaloop, Feb 25, 2024.
  1. Feb 25, 2024 at 1:45 PM
    Toyotaloop
    Toyotaloop [OP] New Member
    Pittsburgh
    2021 SR5 Crewmax MGM
    Very little so far
    Changed diff oil today at 22k miles. Just because. Saw a lot more than just specs and sludge on the plug magnet, and a bunch of shavings and specs in the drain pan. Pics of paper towel is what I magneted out of the drain pan. The plug pics are from after I wiped the sludge and recollected the big pieces. Should I be concerned?
    bulldog93 likes this.
  2. Feb 25, 2024 at 1:46 PM
    Toyotaloop
    Pittsburgh
    Very little so far
  3. Feb 25, 2024 at 1:59 PM
    bensky
    bensky PlatinumPro
    Ben
    Utah
    2018 Red Platinum Tundra
    In my experience, the first oil change on diffs can look a lot like this. I don’t worry unless it looks like that the second time.
  4. Feb 25, 2024 at 2:38 PM
    Jbehredt
    Jbehredt Burgeoning member
    Westminster, CO
    2020 TRD Pro DC White
    Mine looked very similar on my first change. Not losing any sleep. I’m quickly approaching 60k on mine so I’ll let you know what I find on the magnet this time.
    KNABORES, yakeng, des2mtn and 4 others like this.
  5. Feb 25, 2024 at 2:55 PM
    2mchfun
    You're GTG with the metallic flakes, but did you relocate the vent yet? If not, I'd do that soon.
  6. Feb 25, 2024 at 3:57 PM
    Jmunk
    Jmunk New Member
    2020 Tundra SR5 Crewmax
    I did mine today, similar mileage. I had less on mine but not by much. Pretty standard for a new assembly to have some debris from wearing in. I ended up using right at 4qts. I had the truck level on jackstands since I was doing my transmission fluid at the same time. I know most people do the rear differential fluid change with the truck parked on a level surface. I’m curious how much leveling off the truck affects the level, if any. I didn’t think it was take all 4qts but when the last little bit went in it started to run out.
  7. Feb 25, 2024 at 7:32 PM
    boomsling
    boomsling New Member
    ‘18 SR5 Double Cab 4x4
    Magnuson, Rough Country 2” coil overs
    First change at 70k. No issues.
  8. Feb 25, 2024 at 8:37 PM
    Pretty typical shavings. I wouldn't even lose any sleep over it.
    bulldog93 and des2mtn like this.
  9. Feb 26, 2024 at 11:42 AM
    Toyotaloop
    Pittsburgh
    Very little so far
    Thanks all. Appreciate the examples showing its not the end of the world.
    2mchfun likes this.
  10. Feb 26, 2024 at 8:25 PM
    Tundra_361
    Tundra_361 New Member
    Victor
    2019 Black 1794 4x4
    Doing mine tomorrow with 48k miles on the clock. I’ll post some pics
  11. Feb 26, 2024 at 9:56 PM
    Mine had two weird metal discs in it at my first 60k rear diff fluid change.
  12. Feb 27, 2024 at 8:16 AM
    clownkillerloaf
    clownkillerloaf New Member
    Logan
    '21 SR 5.7
    normal. Its leftover metal from when the axle housing was drilled. You wont see them on your next drain/fill.
