Valve stem
Discussion in '3rd Gen Tundras (2022+)' started by 23TundaTRDPro, Feb 23, 2024.
  1. Feb 23, 2024 at 8:49 PM
    23TundaTRDPro
    23TundaTRDPro [OP] New Member
    2023 Tundra TRD Pro
    On the 2023 Tundra TRD Pro, What is the valve stem for in the bed of truck. Is located in same spot as the electric outlet.
  2. Feb 24, 2024 at 4:38 AM
    Look in the manual.....doesn't the 3rd gen have an air suspension in the rear?
  3. Feb 24, 2024 at 7:05 AM
    TakiEvo
    TakiEvo New Member
    Allentown, PA
    2022 SR5 TRD Sport Crewmax White
    Did you get truck used? Sounds like aftermarket air bag helper spring. A schrader valve to fill up when towing.
  4. Feb 24, 2024 at 9:27 AM
    PERRY1060
    PERRY1060 Hammer Down
    Perry
    Indiana
    Blk on Blk 22 Ltd 4x4
    TRD wheels, skid plate, black fender flares, mud flaps and running boards. Pirelli Scorpion 275/70/20 Allterrain Plus tires
    Can you post a picture of valve stem and area above rear axle near coil spring?
  5. Feb 24, 2024 at 11:12 AM
    TakiEvo
    TakiEvo New Member
    Allentown, PA
    That’s not oem. Look under truck for air bags.
  6. Feb 24, 2024 at 12:40 PM
    23TundaTRDPro
    2023 Tundra TRD Pro
  7. Feb 24, 2024 at 12:41 PM
    23TundaTRDPro
    2023 Tundra TRD Pro
    I'll check. Bought used 4 days ago. First time toyota buyer, so still learning the truck. Enjoying it though so far.
    Jettster likes this.
  8. Feb 24, 2024 at 3:29 PM
    23TundaTRDPro
    2023 Tundra TRD Pro
    Finally got underneath. I found the hose but it's connected to nothing. Looks like was cut from whatever it went to.
  9. Feb 24, 2024 at 5:20 PM
    blenton
    blenton New Member
    It was most likely to helper air bags.
    pwpblue likes this.
