Nsv light bar issues
Discussion in '2.5 Gen Tundras (2014-2021)' started by Tee N, Feb 24, 2024.
  1. Feb 24, 2024 at 10:59 AM
    Tee N
    Tee N [OP] New Member
    Hi all! I just installed the nsv light bar for my 2014 tundra. Everything in the light bar work as it should the issue is it deactivated my fog lights, signal bulbs drl, tail lights, third light. Have one experienced the same issue? I have 2014 tundra Sr5 but upgraded the headlight to OEM Led 2018 model using a harness from Headlight Revolution. Please if you know how to fix it. Thank you all!
    Tundra#21 likes this.
