Considering 2nd gen Tundra
Discussion in 'New Member Introductions' started by aaronj5353, Feb 23, 2024.
  1. Feb 23, 2024 at 7:37 AM
    aaronj5353
    aaronj5353 [OP] New Member
  2. Feb 23, 2024 at 7:50 AM
    The ol Granpa's proverbial weekend truck. Low miles and well cared for. The 4.7 is not invincible, it's Achilles heel(s) is the timing belt and SAIS system. If those are kept maintained properly, then yes, they are known for well over 300k miles (and as many as 1 million miles) of service without issue. Sometimes low mileage comes with it's own problems. Not using a vehicle can be worse than using it. Short trips and not driving it frequently enough allows for things to corrode, seals to shrink, and moisture to form due to not getting hot and burning it off. If you're pretty sporty as a mechanic, give it the good once over for rust and maintenance issues and grab it up if it tickles your fancy. If you're not mechanically inclined, take it to a TOYOTA tech who knows these vehicles and have them inspect it for peace of mind. Looks like a very nice example for a 2008. The medium cab with the full size bed is a good combo.
    Nightshade Tundra likes this.
  3. Feb 23, 2024 at 9:13 AM
    apwisher
    apwisher New Member
    Everett, WA
    2007 CM SR5/TRD 4x4 White
    canopy, TRD Sway, audio
    as a base model with a 4.7, I'd offer $15k or even a little less. They probably took it in for 7-8K as trade. I would definitely check for rust or issues under that drop-in bed liner. Looks like a nice truck. g/l
  4. Feb 23, 2024 at 11:23 AM
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
    Welcome from LA (Lower Alabama)! Best of luck in your decision!
  5. Feb 23, 2024 at 12:47 PM
    The Black Mamba
    BlackSnek
    Flower Mound, TX
    Black 00 SR5 AC 5VZ PreRunner
    Imma keep it stock
    Welcome from the Great State of Texas!
  6. Feb 23, 2024 at 2:20 PM
    Ely010606
    Ely010606 New Member
    SPARKS, NV
    2017 QS SR5 CM TRD 4x4
    Welcome from Nevada
  7. Feb 23, 2024 at 3:40 PM
    Welcome from NY.
  8. Feb 28, 2024 at 5:50 AM
    RitcheyRch
    RitcheyRch New Member
    Richard
    Star, Idaho
    TRD Lowered and Supercharged
    Welcome from So Cal
