Turn signal and hazards
Discussion in 'New Member Introductions' started by Sandyys04, Feb 22, 2024.
  1. Feb 22, 2024 at 7:56 PM
    Sandyys04
    Sandyys04 [OP] New Member
    Sandra
    2017 Toyota tundra sr5
    Wheel lights, rock lights, 7inch lift, led lights, tvs on headrest , wheels and rims 35
    Hello , my turn signals and hazards stopped working help , I already replaced the fuse under the hood , the fuses under the drivers side is missing the cover so idk what fuse is what or if I need to replace one there too ? Does anyone know were I can order a replacement cover ?
    2mchfun likes this.
  2. Feb 22, 2024 at 8:17 PM
    TILLY
    TILLY Gently Used Member
    Massachusetts
    2019 MGM TRD Sport D/C
    1lowlife and 2mchfun like this.
  3. Feb 22, 2024 at 8:18 PM
    Sandyys04
    Sandra
    Thank u , will do i appreciate it
    2mchfun and TILLY like this.
  4. Feb 22, 2024 at 8:36 PM
    2mchfun
    Welcome to the forum from OKC!
    If fuses aren't the problem, check out your wiring and cabin air filter for rodent damage or evidence. If not already done, screen the HVAC fresh intakes under the windshield wiper cowling.Mice like to get inside these trucks and do lots of damage sometimes. Best to prevent it before it starts. Under the hood I have had success with pine sol soaked rags and bars of pink Dove soap wedged into random pockets around the perimeter of the engine compartment.
  5. Feb 22, 2024 at 8:38 PM
    Sandyys04
    Sandra
    Thank u !
    2mchfun likes this.
  6. Feb 22, 2024 at 10:21 PM
    1lowlife
    1lowlife New Member
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    Welcome to the forum.
    Any chance you recently replaced a bulb?
    The front turn and DRL bulbs are a bit particular about having the correct bulb.
    The 921 rears not so much.
    With all your lift and stuff, there are a few members that have found wiring pinched or crushed under the truck.
    Did you check and see if the front and rear sockets had a good ground?
    Info below shows what wire is what in your sockets..
    Good luck
    Ultimate TUNDRA Wiring Diagrams Collection | Toyota Tundra Forum (tundras.com)
    Front
    Rear
    The Black Mamba, 2mchfun and TILLY like this.
  7. Feb 23, 2024 at 2:38 AM
    Welcome from NY.
    2mchfun likes this.
  8. Feb 23, 2024 at 4:28 AM
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
  9. Feb 23, 2024 at 12:45 PM
    The Black Mamba
    BlackSnek
    Flower Mound, TX
    Black 00 SR5 AC 5VZ PreRunner
    Imma keep it stock
    Welcome from the Great State of Texas!
  10. Feb 23, 2024 at 2:22 PM
    Ely010606
    Ely010606 New Member
    SPARKS, NV
    2017 QS SR5 CM TRD 4x4
    Welcome from Nevada
