Spray-in bedliner - Paint Removal
Discussion in '2.5 Gen Tundras (2014-2021)' started by 101ABNAASLT, Feb 23, 2024.
  1. Feb 23, 2024 at 9:12 AM
    101ABNAASLT
    101ABNAASLT [OP] New Member
    2021 Tundra Limited 4x4
    I recently bought a used Tundra and the previous owner spilt some white paint on the factory spray-in bedliner. It's not a lot, but looks like bird poop droppings, so wanting to see about getting it removed.
    Any ideas on how to remove the paint, but not damage the bedliner?
  2. Feb 23, 2024 at 9:13 AM
    b6graham
    b6graham New Member
    2020 Voodoo 1794 RW Wheels 315/70
    paint the paint?
  3. Feb 23, 2024 at 9:23 AM
    Winning8
    Winning8 New Member
    Da Bay Area
    2019 MGM DC 4x4 SR5
    Paint another coat of bed liner on top
    MedCityMoto and RobertD like this.
  4. Feb 23, 2024 at 9:26 AM
    RobertD
    Robert
    DFW, Texas
    Or hit it with a pressure washer.
  5. Feb 23, 2024 at 9:27 AM
    Retired...finally
    If it's latex use alcohol. It may take a while but loosen it and powerwash.
  6. Feb 23, 2024 at 10:17 AM
    101ABNAASLT
    I've tried power washer, but it didn't help...
    And I don't think painting it with the same color (White) will do the trick either, haha. I read somewhere to try brake fluid, but not sure about that.
  7. Feb 23, 2024 at 10:18 AM
    101ABNAASLT
    Not sure if it's water or oil based paint
  8. Feb 23, 2024 at 10:46 AM
    Retired...finally
    Always start with the most benign solvent first. Escalate as needed. You're past the water stage. Try 91% isopropyl alcohol on a rag and rub it. If it transfers to the rag it's most likely latex based. Pick a spot on the bedliner and test it as well. Rub harder and if no transfer you have your solvent. If not move to mineral spirits next.
    101ABNAASLT[OP] likes this.
  9. Feb 23, 2024 at 10:47 AM
    shawn474
    shawn474 Lego connoisseur
    MoCo, Maryland
    Rustoleum makes a spray bed liner (it comes in a rattle can) - i would do that to cover the paint before I started throwing all kinds of chemicals on the existing bedliner. Some of them might eat away the liner inadvertently.
  10. Feb 23, 2024 at 12:24 PM
    purplenova
    purplenova Not a new member
    Tom
    Ohio
    2016 Tundra Crewmax SR5
    Ultimate Linings, out of Houston, TX, used to be the manufacurer of the spray in bedliner products.
    I assume they still are ????
    They have a conditioner for the bedliner and I was told not to get in on the paint because it will take it off.
    This might work in your situation, i do not know though.
    Here is additional contact info:
    Cathy Elizondo
    Customer Service Representative
    10301 Round Up Ln.
    Houston, TX 77064
    Phone: 713-466-0302 Ext. 212
    Fax: 713-937-0052
    800-989-9869
    email: celizondo@ultimatelinings.com
    Credit: https://www.tundras.com/threads/bed...ry-toyota-tundra-sprayed-in-bed-liners.70955/
