VLED's reverse light questions
Discussion in '3rd Gen Tundras (2022+)' started by SDHNTR, Feb 18, 2024.
  1. Feb 18, 2024 at 9:18 AM
    SDHNTR
    SDHNTR [OP] New Member
    Was thinking of installing the license plate bracket and swapping out the stock bulbs to LED's of the same temperature. Has anyone else done this? Looks like I just need the universal license plate kit, right? Then what factory reverse light bulbs do I need?
    The parts search feature using make and model on the VLEDs website is near worthless.
  2. Feb 18, 2024 at 9:20 AM
    Just give them a call.
  3. Feb 18, 2024 at 9:40 AM
    TakiEvo
    TakiEvo New Member
    Allentown, PA
    2022 SR5 TRD Sport Crewmax White
    The reverse light is already LED.
    Also, here what the vled license plate look like compared to OEM reverse light.
    Reverse lights
    1lowlife likes this.
  4. Feb 18, 2024 at 9:46 AM
    SDHNTR
    I know, but ideally I wanted to match the temp of the license plate light bracket. Not a huge deal if I can't.
  5. Feb 18, 2024 at 9:47 AM
    TakiEvo
    TakiEvo New Member
    Allentown, PA
    It's LED so there is no bulbs.
  6. Feb 18, 2024 at 9:49 AM
    SDHNTR
    Semantics tho right? I know it's not a halogen bulb, but isn't it an LED "bulb"? Or are you saying it's not a serviceable light at all? I haven't taken the cover off.
  7. Feb 18, 2024 at 9:49 AM
    If it's already led, then it is integrated....no removable bulbs.
  8. Feb 18, 2024 at 9:53 AM
    TakiEvo
    TakiEvo New Member
    Allentown, PA
    Not serviceable at all. It's all one unit. The reverse and license plate light. With one connector.
  9. Feb 18, 2024 at 9:55 AM
    SDHNTR
    Ok, but that's not the light I'm referring to. I'm talking about the reverse light beneath the tail light. AND then adding a license plate bracket reverse light. I wasn't planning on tinkering with the light you referenced.
  10. Feb 18, 2024 at 10:12 AM
    TakiEvo
    TakiEvo New Member
    Allentown, PA
    Sorry, just little confused on which reverse light you're referring to, but the only reverse lights that I know of on my 3rd gen are marked #2 in the pic above. The reverse light/license plate light are one unit. I never seen factory led lights use led bulbs, just circuit board LED chips.
    Added a pic below, this owner got the VLED license plate lamp too and seems to match pretty well.
  11. Feb 18, 2024 at 11:14 AM
    SDHNTR
    Oh boy. Well, now I feel dumb. You're absolutely right. This truck is brand new to me. I'm coming from a 5th gen 4Runner, so I just assumed the system was similar and there was a reverse light contained within the tailight compartment. Oops. I get it now.
  12. Feb 18, 2024 at 1:52 PM
    SDHNTR
    Next dumb question... for the guys that have installed the VLEDs license plate bar, what did you tap into? The factory reverse light or the trailer wiring harness? Is one easier that the other? And into what color wires (somebody save me from poking around with a test lamp)?
  13. Feb 18, 2024 at 3:04 PM
    DRP
    DRP Old Member
    Dave
    Been looking at doing the same thing but haven't dug into it yet. Others posted in another thread that they used this so they didn't have to poke into or cut the factory harness.
    https://www.amazon.com/gp/product/B09BMNLX6S/
    This is the other thread.
    https://www.tundras.com/threads/under-tailgate-lighting.137021/
  14. Feb 18, 2024 at 4:59 PM
    mrfreeman
    mrfreeman New Member
    Kenny
    Buffalo
    2024 Tundra SR5
  15. Feb 18, 2024 at 5:39 PM
    Cassidy1866
    Cassidy1866 New Member
    2023 Tundra Limited TRD Off-Road
    I received one as a Christmas present and hooked it up last week. I was very impressed with the product and the included harness, which makes installation exceptionally easy.
    I immediately noticed a substantial improvement in reverse lighting. The one I have also functions as a tail light and brake light.
    Removal takes no more than 5-10 seconds when you want to use the hitch for towing, recovery, bike rack, etc.
    mrfreeman[QUOTED] likes this.
  16. Feb 18, 2024 at 9:29 PM
    jctmundra
    jctmundra New Member
    Northern VT
    '23 1794 Hybrid Stunning Mesquite/Cream
    Or... You can pick up a nice set of fogs from DD and move the OEM fogs to the back.
    Be carefull on the plate lamp bar. It mounts above the plate, there may be little to no clearance when opening the tailgate.
  17. Feb 19, 2024 at 6:48 AM
    Ipaddick
    Ipaddick New Member
    Canada
    Platinum hybrid w/advanced package
    I have the xlp from vled. They make a 7 pin harness that makes it easy to install. I also have diode dynamics reverse light kit and hitch pod
  18. Feb 19, 2024 at 9:51 AM
    SDHNTR
    I tow regularly. The receiver hitch light isn't going to work for me, nor if it plugs into the trailer plug for power. I want to tap into the proper wires. Can anyone confirm the color of the wires to tap into?
  19. Feb 19, 2024 at 9:55 AM
    jctmundra
    Northern VT
  20. Feb 19, 2024 at 9:59 AM
    Ipaddick
    Ipaddick New Member
    Canada
    It’s a harness. There’s no tapping, it doesn’t make you unable to use the plug, it’s a pass through harness, and you can still plug a trailer in.
    https://www.vleds.com/7-pin-trailer-harness-reverse-parking-breakout.html
  21. Feb 19, 2024 at 10:00 AM
    SDHNTR
    Unless I'm not following you, again, I don't want to use something that plugs into my trailer harness. I use that too regularly. I want to tap into a wire behind the trailer plug or behind the reverse light. I'm trying to find someone who has actually done this with the VLED's license plate bar and hard wired it, and can confirm specifically which wires they tapped into.
  22. Feb 19, 2024 at 10:02 AM
    jctmundra
    Northern VT
    The harness goes behind the bumper plug, between the bumper connector and the body harness.
  23. Feb 19, 2024 at 10:02 AM
    SDHNTR
  24. Feb 19, 2024 at 10:03 AM
    Ipaddick
    Ipaddick New Member
    Canada
    Look at the link I posted. This is getting painful
  25. Feb 21, 2024 at 3:08 PM
    iforceAZ
    iforceAZ New Member
    It keeps your trailer hookups completely functional. Just taps into them to pull power for the light.
  26. Feb 22, 2024 at 6:51 AM
    mrfreeman
    Kenny
    Buffalo
    2024 Tundra SR5
  27. Feb 22, 2024 at 2:31 PM
    SDHNTR
    Helpful. Thanks for taking the time!
  28. Feb 22, 2024 at 2:35 PM
    Breathing Borla
    AZ
    doesnt that much light wash out the camera view? it seems to be much better on this gen as it is especially with the handle light to show the trailer hook up already there.
  29. Feb 22, 2024 at 6:12 PM
    Cassidy1866
    Not sure if you’re asking about the Diode Dynamics hitch light but if so my take is that it’s improved the rear camera view significantly when reversing.
  30. Jun 26, 2024 at 3:19 PM
    ksj0823
    ksj0823 New Member
    2024 Tundra Platinum 6.5 MGM HV
    jctmundra, I saw your 1794 in another post with fog light mount under rear bumper. It looks really nice. I was looking for your mounting point and the wiring. By any chance do you have a post about your rear fog light?
