CarPlay...hitting play on Spotify results in no sound
Discussion in '3rd Gen Tundras (2022+)' started by Gemccormick, Mar 13, 2023.
  1. Mar 13, 2023 at 1:37 PM
    Gemccormick
    Gemccormick [OP] New Member
    Graham
    2022 Tundra Limited
    I’m curious if anyone has had a similar issue or if I’ve missed a setting somewhere. When first starting up my truck my phone will connect to carplay, but if I hit the play button on Spotify there is no sound. I can turn up the volume on my phone and in the truck but nothing happens. The only way I’ve found to resolve it, is to get out of Carplay and hit “enable audio” on the music tab.
  2. Mar 13, 2023 at 2:45 PM
    xc_tc
    xc_tc New Member
    I’ve had this happen before. Seems to be a bug with Carplay since it’s happened to me in other brands. One way I found to reset it in the Tundra is to hold the power button on the head unit to reset everything. Usually Spotify will work after this.
  3. Mar 13, 2023 at 3:02 PM
    articdesert
    articdesert Will work for truck parts
    23 1794 MGM
    When mine plays with no sound I go into the app on my phone and press pause and play and it usually starts playing again
    Hecteasy and Supertech1 like this.
  4. Mar 13, 2023 at 7:27 PM
    TakiEvo
    TakiEvo New Member
    Allentown, PA
    2022 SR5 TRD Sport Crewmax White
    I’ve always thought this issue was apple CarPlay. Sometimes pausing and pressing play solves it. Other times I had to close the Spotify app and restart it on the phone. Usually restarting Spotify app solves the no sound issue.
  5. Mar 13, 2023 at 7:31 PM
    Supertech1
    Supertech1 New Member
    This works for me as well.
  6. Mar 13, 2023 at 8:20 PM
    t300
    t300 New Member
    Manitoba
    22tundra
    Happens once in a while to me and use the same reset as this
  7. Mar 28, 2023 at 4:00 PM
    JReedG
    JReedG New Member
    Jonathon
    2022 Tundra TSS
    Mine does this. I hit “Mode” on steering wheel and it plays. My spotify now has recently not displayed. Just a blank screen now idea how to fix it
    mrfreeman likes this.
  8. Sep 20, 2023 at 9:01 AM
    iforceAZ
    iforceAZ New Member
    YouTube Music here. Randomly sound quits but song keeps "playing"
    I have to click "Enable Audio" to get it to play again in the Toyota audio settings
  9. Sep 23, 2023 at 6:37 AM
    Duke_962
    Duke_962 New Member
    Nwnj
    2022 tundra sr5 4x4
    Rci skid plate,
    Every time. I have to close the app on the phone. Close the phone then hit Spotify on the screen and it will play. No volume or volume controls when issue happens.
  10. Feb 21, 2024 at 7:21 AM
    DeaG
    DeaG New Member
    SF Bay Area
    2024 Lunar Rock Tundra Limited TRD OR
    This happens to me about 90% of the time. Haven't found a good solution to resetting yet. I've tried rotating Modes, pause-play, resetting the headunit, changing what device Spotify plays then back to Carplay, etc. All these have worked but never consistently. Also 90% of the time my Spotify resets and doesnt play the last song it left off of and I have to select a playlist or song every time I get in my truck.
  11. Feb 21, 2024 at 7:24 AM
    SM Tundra
    SM Tundra New Member
    Cody
    2024 Limited Smoked Mesquite Tundra
    Mine has done this a couple times. What I do is go into my phone and exit out of Spotify completely, then open it up again and that usually works to get the music to start playing again
  12. Feb 22, 2024 at 6:42 AM
    Dfrink
    Dfrink New Member
    SR5 CM 4wd
    This happens to me all the time. My simple fix (although annoying) is to press the volume knob in, which switches to radio. Radio sound will instantly play, then press the play button on your screen for Spotify and you should get sound from Spotify.
