Anyone use this? Tired of the mess of oil changes
Discussion in '2.5 Gen Tundras (2014-2021)' started by snowball1794, Feb 18, 2024.
  1. Feb 19, 2024 at 7:12 AM
    OHwendTrd
    OHwendTrd Aging Member
    Josh
    21 SR5 3UR-FE
    ATF Cooler
    When they restock I plan to order one. I emailed them in January asking for a timeline and haven't heard back yet.
  2. Feb 19, 2024 at 7:23 AM
    yakeng
    yakeng 3URFE Apologist
    Just lookup "oil filter drain tool" on Amazon. There's several models out there, but the one I bought is from "Powerworks". Was $11 I think.
  3. Feb 19, 2024 at 7:27 AM
    vtl
    vtl New Member
    Boston 'burbs
    2019 Red SR5 DC 4x4
    I use a drain nipple coming with OE filter and a longer scrap metal tube I found in garage. $0, can't be more convenient.
  4. Feb 19, 2024 at 8:41 AM
    Gene_in_FL
    Gene_in_FL SUPER genius
    FLORIDA
    2016 SR5 DC 5.7 2021 SR5 DC 5.7
    Damn. That is not good news.
    I tried to sign up for their newsletter this morning, and the website just pops up one of those "404" error things.
    OHwendTrd[QUOTED] likes this.
  5. Feb 19, 2024 at 8:59 AM
    OHwendTrd
    Josh
    21 SR5 3UR-FE
    ATF Cooler
    No it isn't. None of this is good news if you're wanting one.
  6. Feb 19, 2024 at 2:28 PM
    yakeng
    I was hoping to buy one of their funnels, but guess I’ll be holding off.
  7. Feb 19, 2024 at 3:13 PM
    belairbrian
    belairbrian New Member
    2016 Crew Max 4x4 TSS
  8. Feb 19, 2024 at 3:53 PM
    InfernoTundra15
    InfernoTundra15 2015 TRD Pro
    If you had to take truck to dealer or shop for oil change, does this cause an issue?
    Leo's first likes this.
  9. Feb 19, 2024 at 3:56 PM
    Leo's first
    Leo's first TRUCK GANG
    Groton ma
    Nope I've herd of guys having dealer install at last free oil change
    DogRunner2 and WILLINH like this.
  10. Feb 19, 2024 at 4:12 PM
    Eddie2807
    Eddie2807 New Member
    Edgar
    Nh
    Great upgrade for sure it will make your life so much easier
  11. Feb 20, 2024 at 3:52 AM
    CMikeB
    CMikeB New Member
    I've used Fumoto valves on my vehicles since our '84 Cressida.12 vehicles later, never an issue on any of 'em.
  12. Feb 21, 2024 at 11:57 AM
    snowball1794
    snowball1794 [OP] New Member
    Reed
    2021 AG 1794 TRD-off-road
    Fox 2.5’s Dirt King Boxed UCA Coach builder rear shackles 35x12.50r17 Toyo MT’s Method MR701 17x9 0 offset BMC
    WILLINH likes this.
  13. Feb 21, 2024 at 1:38 PM
    Clemsonman14
    Clemsonman14 New Member
    2020 SR5 Crewmax 4x2
    How many people have had an issue getting the filter housing off after using the free dealer oil changes?
    I finally ran out of free ones now planning to do it myself and just wondering how common it may be for them to over tighten it
  14. Feb 21, 2024 at 1:57 PM
    DIYReid
    DIYReid New Member
    KC
    2024 Ice Cap Tundra Limited
    Had one on my Tacoma for 12 years, will have one on my Tundra after the free oil changes are done.
  15. Feb 21, 2024 at 5:50 PM
    OHwendTrd
    Josh
    21 SR5 3UR-FE
    ATF Cooler
    Hi Josh,
    Thanks for reaching out. ETA for more caps is unknown at the moment. I will add you to the list and drop you a note when I have more info.
    Regards,
    Brian (Jowett)
    bulldog93 and Henry1jg like this.
  16. Feb 21, 2024 at 7:05 PM
    DSTundra
    DSTundra New Member
    Dave
    Albuquerque, NM
    2017 Tundra Platinum
    If you haven't purchased one yet, I'd recommend getting the F133 instead of the F103. The F133 drains faster...
  17. Feb 21, 2024 at 7:09 PM
    Chuy!
    Chuy! New Member
    Lakeside, CA
    2007 Tacoma 4X4
    No & yes. The lever falls nicely into place that makes it difficult to open accidentally. But, if you are worried about it, you can install a mini hose clamp that prevents the valve from opening. I did this.
    I found a pic comparing the Fumoto and EZ Valve. You can see how much larger the EZ ID is. And despite it having an o-ring, I use a regular drain bolt gasket. Valve is going on nine years with no issues.
    Henry1jg likes this.
  18. Feb 21, 2024 at 7:12 PM
    snowball1794
    Reed
    Where’s the best place to get the EZ?
  19. Feb 21, 2024 at 7:30 PM
    Chuy!
    Chuy! New Member
    Lakeside, CA
    2007 Tacoma 4X4
  20. Feb 21, 2024 at 7:54 PM
    #50
    Coal Dragger
    Coal Dragger New Member
    Kung Fu Dick
    I just used one on my mom’s RX350 today to make sure her vehicle is good to go for her trip to go see my brother and his family.
    Next week I’ll use the valve on my Tundra to change the oil on it too.
    I should have bought one like 15 years ago for the Tundra.
    The Fumoto valve works great and makes oil changes way less messy, quite a bit faster, and if you want to take oil samples for analysis mid OCI facilitates that easily too.
  21. Feb 21, 2024 at 8:42 PM
    #51
    snowball1794
    Reed
    Okay cool deal. I’m gonna order one. Hate the mess the traditional one makes
  22. Feb 22, 2024 at 5:24 AM
    #52
    agrestic1
    agrestic1 New Member
    2016 CrewMax
    AMP Research PowerStep, AMP BedStep Bumper Step, BedRug Carpet Bed Mat, Bazooka Powered Subwoofer Tube
    Just changed my oil. Have the Fumoto F133S, extra cap and clip & hose kit. Motivx funnel and oil filter drain, Performance tool filter wrench..
    bgdv1, WILLINH, Shanet421 and 2 others like this.
  23. Feb 22, 2024 at 5:30 AM
    #53
    Stumpjumper
    Stumpjumper Not a new member
    Fate, Tx
    2017 Tundra TSS 4x4
    I had to use a 2' cheater bar and my neighbor had to hold my legs. Destroyed one filter wrench (cheap one) and the plastic cap. Fortunately I had a metal one ready to go. Get a good filter wrench and do not insert ratchet. Use a socket. Gave the dealer a 0 on survey and service manager called me. I told him to give his goons a lesson in using torque wrenches. They also left 2 bolts out of skid. When I picked up the bolts he offered to replace the plastic cap. I should have taken it for a backup. He asked me if I wanted him to install the skid bolts. I said HELL NO.
  24. Feb 22, 2024 at 6:04 AM
    #54
    Noones getting that last little bit, with or without the fumoto. Note the drain location
  25. Feb 22, 2024 at 7:25 AM
    #55
    Chad D.
    Chad D. New Member
    Western Oregon
    2018 CrewMax Platinum
    Good point. And, that’s why I always fire ‘er up and haul ass in a counter-clockwise circle in the field for a few minute. Sloshes that last ounce of oil right out da hole.
  26. Feb 22, 2024 at 7:27 AM
    #56
    CMikeB
    CMikeB New Member
    Great idea, I'm doin' it!:D
  27. Feb 22, 2024 at 8:35 AM
    #57
    AZBoatHauler
    So.Arizona
    You know there is a nut welded inside the pan right? I doubt the fumoto extends beyond that.
    Gene_in_FL likes this.
  28. Feb 22, 2024 at 9:27 AM
    #58
    equin
    equin Texarican Tundra
    Ed
    DFW, TX
    Subscribed
  29. Feb 22, 2024 at 9:31 AM
    #59
    Chad D.
    Chad D. New Member
    Western Oregon
    Please refer to post #55 for the solution to this issue.
  30. Feb 22, 2024 at 4:27 PM
    #60
    Gene_in_FL
    FLORIDA
    Hey Brian, I'm not Josh (that's OHwendTrd) but I definitely would like to know when those caps are available again! If you need my email it's wgene67, at gmail. Thank you sir!
