Torque values for front suspension?
Discussion in 'Suspension' started by Stumpjumper, Aug 29, 2017.
  1. Aug 29, 2017 at 3:13 AM
    Stumpjumper
    Stumpjumper [OP] Not a new member
    Fate, Tx
    2017 Tundra TSS 4x4
    Is there a list some where on this forum? I can't seem to find one. There is a comprehensive list on the Tacoma forum on a sticky. I have written the Tacoma values down for the castle nuts on UCA and tie rod thinking they should be same or close.
  2. Aug 29, 2017 at 6:30 AM
    Stumpjumper
    Fate, Tx
    2017 Tundra TSS 4x4
    From what I have found the Tacoma torque values are good for Tundra too. Anyone know what the lug nuts should be torqued too?
  3. Aug 29, 2017 at 7:26 AM
    CaptTyler
    CaptTyler Life’s too short to have an ugly boat.
    Tyler
    2018 Ram 2500 Cummins
    Not sure about the rest but I believe the lug nuts should be torqued to 90.
  4. Aug 29, 2017 at 9:48 PM
    Agitated1
    Agitated1 Newish Member
    Los Angeles
    2017 Tundra Crewmax TRD 4x4 Quicksand
    TRD Pro Grill King Coilovers with compression adjuster Tint 5% Rear, 30% front and 70% windshield Husky X-Act Floor liners BA Muffler 8in standard system Truck Covers USA retractable bed cover Yakima bed rails
  5. Aug 30, 2017 at 10:16 AM
    Stumpjumper
    Fate, Tx
    2017 Tundra TSS 4x4
    thanks Agitated1. For the most part they look to be same as Tacoma
    Agitated1 likes this.
  6. May 30, 2022 at 8:47 PM
    Flockem
    Flockem New Member
    Remington
    2016 Crewmax 4x4
    6112/5160 +CB shims SPC UCA and Diff Drop Toytec Shackles 35x12.50 BFG ATs on factory 20s Spidertrax 1.25s BMC Headlight Revolution SM LED Breather Mod Dents in the body due to trees...
    So I have found conflicting numbers for the lower control arm to the frame.
    Some in here say 96ftlbs
    Toyota suspension manuals say 207ftlbs
    All pro instructions say 207ftlbs
    Toyota dealership has 96ftlbs
    so my question is the lower control arms on my 2016 pop and when I tighten to 200+/- they stop…. But is 96 right or 207?
  7. May 31, 2022 at 5:29 AM
    Terndrerrr
    Terndrerrr 923000 miles to go
    Music City
    6UR-FE
    I don’t have the numbers in front of me, but when I installed my TRD Fox kit, I remember the LCAs being in the 200 range.
    96 sounds more like it’s for the wheels’ lug nuts to me.
    Hbjeff likes this.
  8. Jun 4, 2022 at 12:00 PM
    Flockem
    Flockem New Member
    Remington
    2016 Crewmax 4x4
    I went with the 207
    feels good but not like butter, changed multiple things at one time so who knows what it is.
    new suspension
    Different alignment
    New lower and upper control arms
    all in all it feels good just need to chase the little noises
  9. Feb 21, 2024 at 2:22 PM
    HTH
    HTH New Member
    2017 tundra limited
    Did you ever figure out the noise? I’m in the same situation and am leaning towards the sway bar
