Steering wheel clunking sound
Discussion in '1st Gen Tundras (2000-2006)' started by B.G., Jan 25, 2021.
  1. Jan 25, 2021 at 11:44 AM
    B.G.
    B.G. [OP] New Member
    06 SR5
    Hi - this is my 1st post here on the Tundra forum. I have an 06 SR5 2 WD that started making a clunking sound on rocky rough roads only. My truck has 88K miles on it since new. I recently had an the lower ball joints, steering ram mounting bushings, alignment, and new Michelin tires all the way around. After poking around online - I decided to check the lower steering shaft for slop at the 'rag joint' shaft coupling. There is clearly vertical movement at the joint, but little if any lateral movement. The rubber union felt surprisingly soft - given that the outside air temp was only around 36 degrees when checking it for slop. The bushings for the sway bar look good visually. I could hear a bit of clunk when pulling up and down on the tail shaft of the lower rod. I'm 99% sure the noise is coming from the rag joint. Here is my main gripe - the replacement is over $200, and I'm pretty sure that a new rubber disc is all that's necessary for the job. Maybe I'm wrong. It wouldn't be too difficult to cut off the existing rivets and install a new disc using grade 8 bolts to replace the rivets. The Toyota replacement includes the entire assembly - that's why the high cost. Has anyone found a suitable replacement that can be made to work ( safely ) ?
    Thanks
    Bruce
  2. Jan 25, 2021 at 1:56 PM
    PenderBen
    PenderBen Forum lurker…
    Gulf Islands, BC Canada
    2003 Tundra AC 4x4
    How are the shocks? Bad shocks or shock mounts could lead to clunking.
    I know that wasn’t really what you were asking, but a worth checking before getting more in depth.
  3. Jan 25, 2021 at 2:45 PM
    Professional Hand Model
    Fred
    Hand Protectors
    I’d ask that you take some pics of your work as it might help save some money for anyone in the future considering fixing this problem. You sound like you have a good idea.
  4. Jan 25, 2021 at 3:05 PM
    B.G.
    06 SR5
    Thanks for the replies so far.
    Shocks and shock bushings are in good shape. Entire front end was checked out 6 months ago and the worn parts replaced. I'm quite positive that the coupling is the problem. The guys over in the Taco forums gripe about this all the time. They also has stated that the collapsing portion of the column is the culprit. Many of them have welded that part of the column at the slip joint to make it solid. They claim that the noise is gone after doing this. My concern is that this modification makes the steering shaft solid - and it is supposed to collapse in a head on accident. This to keep the wheel from crushing the driver. Pretty important. It's also a ton of work to take out the steering column on the Tundra. I'm hoping someone here has had some experience with replacing the lower steering shaft - or even changing out the flex joint disc / rag. That isn't a big job if you're handy. But I can't find any soft parts for the coupling specifically made for Toyota. Only option I have found is replacing the entire shaft with the OEM part.
  5. Jan 25, 2021 at 3:15 PM
    assassin10000
    assassin10000 New Member
    Andrew
    Northern CA
    '05 SR5 AC 2wd
    You could try removing the column and slide the shaft out, coat lightly with some adhesive like silicone caulking or windshield urethane then install and let cure 24hrs.
    This may eliminate the slop but still allow it to break free in an accident to slide, as intended.
  6. Jan 25, 2021 at 3:33 PM
    Fred
    Hand Protectors
    Nice idea. I like the Urethane idea.
  7. Jan 25, 2021 at 5:53 PM
    B.G.
    06 SR5
    I'm sure that could be done - I just don't want to mess with that part of the column unless it actually is the cause of the problem. I need to temporarily fill the spaces on the Rag joint above the steering box - then take it on a bumpy road and see if anything has changed.
  8. Jan 26, 2021 at 10:40 AM
    Mine was outer tie rods. Had just replaced them too. Could be almost any part of the articulating suspension. LBJ was replaced so may eliminate that. Get it up on jacks and pull on the tires. 12 and 6 to check for bearing play and ball joint play. 3 and 9 to check for steering component play. Doing one wheel at a time leaves the other on the ground to resist moving while inspecting the other. May need one person working the tire and one looking underneath individually at each component during. I have a clunk on the right front again that I haven't chased down yet. The joys of owning an older truck. Good luck and let us know what you find. If it turns out to be the rag joint, post some pics or a vid to help others diagnose theirs.
  9. Jan 26, 2021 at 10:50 AM
    PenderBen
    2003 Tundra AC 4x4
    Yeah, I wondered about LBJs too, were OEM used? Did the clunk ever go away after the work done then come back?
    I can’t say about the rack and other stuff you’re looking at, but that doesn’t seem to be a common problem on these trucks, at least that I’ve read about.
  10. Jan 26, 2021 at 11:18 AM
    B.G.
    06 SR5
    Thanks for the replies and ideas. When the weather dries out a bit - I will mess around with it to check the other possible problems
  11. Nov 17, 2021 at 7:22 AM
    Adventundra
    Adventundra New Member
    NJ
    2016 SR5 Long Bed
    Cap and bed slide
  12. Feb 21, 2024 at 6:20 AM
    zack20cb
    zack20cb New Member
    Zack
    2003 Tundra (Base, 5-Speed)
    I’m posting here because this thread came up when I was searching for clues about what turned out to be a much simpler problem.
    If the clunk is more of a metallic clank, and it feels it’s coming from inside the wheel rather than somewhere down the column, it’s likely to be a failed vibration damper. This definitely happens on 2003-2004 Tundras and Sequoias, and I’ve heard of it happening on 05/06.
    Note: Be sure to disconnect the battery and bleed off any capacitance before opening the steering wheel!
    Removing the failed vibration damper is a quick fix with simple tools, and there seems to be no adverse effect. I recommend doing this, it’s much better than leaving the broken part floating inside. On my truck, it started to jostle the clock spring and fire the horn when I was parallel parking. Not cool.
  13. Feb 21, 2024 at 7:01 AM
    FishNinja
    FishNinja HIDE YOUR DAUGHTERS
    Lee
    TEXAN....big surprise
    06DC2wd
    our racks like to explode with heavy wheeling.
    the rack bushings can be a culprit for clunking. They may look good but rubber is a deceitful material
  14. Feb 21, 2024 at 2:02 PM
    Over in the steering wheel info dump thread, you'll see some pics in the specific reply I just linked. Seems like the later year 1st Gen Sequoias and the 4Runners had the weight. My 2006 Access Cab didn't. Super weird.
    And lemme tell you, they must've threadlocked that SOB weight in there, because the damn thing WOULD NOT come out without some butchery. Total pain in the ass. There's one other member who had the clunk you mention, in another thread, because their weight detached from its metal bracket.
