Tech12Volts Amp Kit
Discussion in 'Audio & Video' started by morgaj1, Jan 22, 2024.
  1. Jan 22, 2024 at 7:21 AM
    morgaj1
    morgaj1 [OP] New Member
    AL
    2021 Tundra Platinum CM 4x4
    I am installing this kit this coming weekend. Looking at the install, I see that the amp rack screws into the floorboard with supplied drywall screws. Do those screw go through the metal floor pan or just into the carpet?
  2. Jan 22, 2024 at 7:30 AM
    FISHN43
    FISHN43 New Member
    Ohio
    2020 Super White TRD Pro
    Can you be more specific on what amp kit?
  3. Jan 22, 2024 at 7:36 AM
    morgaj1
    AL
    JBL DSP4086 kit for the factory JBL audio
    FISHN43 likes this.
  4. Jan 22, 2024 at 7:42 AM
    SnrDisregardo
    SnrDisregardo New Member
    Wade
    IL
    2018 Platinum CrewMax 4x4
    Pretty much. There are a couple of holes that you could probably use with bolts instead, but mine zipped right down.
  5. Jan 22, 2024 at 7:48 AM
    Danimal86
    Daniel
    Sacramento, CA
    2017 White Tundra SR5
    I used the sticky side of Velcro to hold it to the carpet.
    1lowlife and morgaj1[OP] like this.
  6. Jan 22, 2024 at 7:52 AM
    morgaj1
    AL
    Through the metal pan or just into the carpet?
  7. Jan 22, 2024 at 7:55 AM
    1lowlife
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    Same here..
  8. Jan 22, 2024 at 8:56 AM
    SnrDisregardo
    Wade
    IL
    Pretty sure it went thru the metal. It grabbed like it did, but I was surprised that a drywall screw would be able to act as a self-tapping with not a lot of pressure.
    morgaj1[QUOTED][OP] likes this.
  9. Jan 22, 2024 at 1:49 PM
    morgaj1
    AL
    Thanks guys. With that amp, if I wanted to replace the door speakers, are they 2 or 4 ohm speakers?
  10. Feb 5, 2024 at 3:14 PM
    Jeff Spicoli
    Jeff Spicoli New Member
    2019 Platinum
    Dual Magnaflow exhaust, Bakflip MX4, Taylor's Audio amp, speakers and subwoofer for Tundra JBL.
    For those of you who have the DSP4086 amp kit from James how long did delivery take from the time you bought it? I ordered one and was curious
  11. Feb 5, 2024 at 4:05 PM
    SnrDisregardo
    Wade
    IL
    IIRC, approx a week.
  12. Feb 6, 2024 at 4:15 AM
    Bergy24
    Bergy24 New Member
    How much did this amp help with the OEM speakers?
    I upgraded to the JBL Club Box from Taylor and still wanting more.
    Will this amp help with the punch as well as all other speakers?
    Any issues at all?
  13. Feb 6, 2024 at 4:35 AM
    SR5BART
    SR5BART New Member
    Bart
    Chicago
    21 SR5 TRDOR
    Same here. I did not want to put any screws through metal if i didn't have to. Velcro has help up real well
  14. Feb 6, 2024 at 9:24 AM
    Downytide
    Downytide New Member
    GTA
    Lunar Rock that whines
    I keep getting this crackling sound on the driver's rear door, I bought JL 10" subs, Hertz door speakers and the amp kit, I install sub and amp first cause time was short, noticed the crackling sound but didn't hear back on the issue, then finally swap out the door speakers, still getting the crackling.
    to be honest, its driving me nuts.
  15. Feb 6, 2024 at 4:54 PM
    morgaj1
    AL
    It added a lot of depth to the other speakers and made the sub sound like a sub. No regrets.
    ATV25 likes this.
  16. Feb 6, 2024 at 4:54 PM
    morgaj1
    AL
    About 2 weeks for me.
  17. Feb 6, 2024 at 4:59 PM
    SnrDisregardo
    Wade
    IL
    Have you guys played with the gains on the amp? James said he preset it but I feel like there should be a bit “more” to it.
  18. Feb 6, 2024 at 5:01 PM
    morgaj1
    AL
    Reading other threads, several have gone in and added mid back to the doors. I will do that on mine when I do the post-hunting season deep clean.
  19. Feb 6, 2024 at 7:01 PM
    ARMYGREEN
    ARMYGREEN New Member
    2014 CrewMax MGM
    What are they preset at?
  20. Feb 6, 2024 at 7:07 PM
    SnrDisregardo
    Wade
    IL
    I’d have to go and look at the amp. I didn’t really mess with it.
  21. Feb 6, 2024 at 7:07 PM
    SnrDisregardo
    Wade
    IL
    How would you do that?
  22. Feb 7, 2024 at 3:33 AM
    morgaj1
    AL
    You download the JBL software to a Windows-based laptop and connect it to the amp with the included usb cable. Be sure to save the setup that James programmed it with as a backup before starting. Details on the different settings:
    https://www.youtube.com/watch?v=CNPjM3Xe7bI&t=783s
    SnrDisregardo[QUOTED] likes this.
  23. Feb 7, 2024 at 5:35 AM
    Mountaineer
    Mountaineer New Member
    TN
    2019 MGM Platinum
    I got into mine and changed the crossover and eq settings for all the speakers to sound better (at least to me). The video @morgaj1 posted is pretty good at explaining the setup.
  24. Feb 8, 2024 at 7:54 AM
    Downytide
    GTA
    What are the following settings on your guys amps?
    Low Hi 1 or Hi2 ? Also is it on Rem DC or Audio?
    I asked James to confirm these almost 2 years ago and never got an answer.
  25. Feb 8, 2024 at 6:50 PM
    morgaj1
    AL
    Hi and DC
    Downytide likes this.
  26. Feb 21, 2024 at 9:22 AM
    Downytide
    GTA
    I spent almost 5 hours chasing every single wire and finally found the culprit, I highly recommend folks with this kit keep an eye on the connectors.
    At a glance, everything seems ok, then I noticed the green wires were held on by one strand on the negative side, after a close inspection, 2 more plugs were held on barely, strip them and tighten them down and noise was gone.
    cdavi060, ATV25, RainMan_PNW and 2 others like this.
  27. Jul 9, 2025 at 9:30 AM
    lsumatt1514
    lsumatt1514 New Member
    2020 Tundra Crewmax Platinum
    Could you PM me your setup file? Thanks!
