  1. Feb 19, 2024 at 3:20 PM
    VR6T
    Texan.... Big suprise
    00 Tundra Limited 2WD AC
    Casey over here wanting a fucking Hilux build with his 2UR engine idea
    455h0le_dachshund likes this.
  2. Feb 19, 2024 at 3:22 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    I mean Casey has a Ranger and he always talks about how he wants to swap out the 2uz on his 02 Tundra for all this other stuff...
    Jack McCarthy and VR6T[QUOTED] like this.
  3. Feb 19, 2024 at 3:32 PM
    VR6T
    Wait hes got a ranger........ I kniw where there are 3 2UZ sitting right now. 1 non VVTI 2 VVTI. Theure sequoia engubes but same same for the most part. @Mr.bee how about we start a group project
  4. Feb 19, 2024 at 3:48 PM
    FishNinja
    FishNinja HIDE YOUR DAUGHTERS
    Lee
    TEXAN....big surprise
    06DC2wd
    Only if I’m allowed to jump it.
  5. Feb 19, 2024 at 3:56 PM
    VR6T
    So Baja Ralleye LT Suspension........ Sure lets do it
    FishNinja[QUOTED] likes this.
  6. Feb 19, 2024 at 4:02 PM
    FishNinja
    Lee
    06DC2wd
  7. Feb 19, 2024 at 4:04 PM
    VR6T
  8. Feb 19, 2024 at 4:10 PM
    Mr.bee
    Mr.bee King Turdra
    '02 AC TRD
    I'm not allowed to hot rod dads ranger. I've tried talking him into taking it to 24h of lemons, but its a no-go. If we're gonna build a prerunner it needs to be a 1uz 2wd tundra.
    Jack McCarthy likes this.
  9. Feb 19, 2024 at 5:19 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    FTFY
  10. Feb 19, 2024 at 7:10 PM
    des2mtn
    SW
    2004 Black DC Limited 4x4
    Tonto cover
    Mostly did Parker prep today. Cleaned the interior and scrubbed a few stains out of the carpet, also cleaned up the engine bay some. Got my inverter wired to a switch again. Mounted the roof rack basket. Crawled under the truck and did a quick inspection underneath. Still need to fix one of my air lines that's leaking.
    Finished disassembling my donor front differential. It wouldn't fit in a crate with whatever the hell pinion flange was on it. The Makita impact wouldn't bust the staked nut on the world's longest pinion flange, but the nut was no match for the plug-in impact. You'll need to buy a female torx socket set with an E12 socket to remove the ADD tube/ stub shaft. A 12-point socket will just round the bolt head. https://www.amazon.com/dp/B07JFJD53J?ref=ppx_yo2ov_dt_b_product_details Need to remove the old drain/fill plugs and clean up the stub shaft mounting surface, then it's good to go.
  11. Feb 19, 2024 at 7:17 PM
    That’s a snazzy red milk crate…… ours are mostly green and shades of green out here, I’ve seen a few sweet teal colored ones too
    B888s and des2mtn[QUOTED] like this.
  12. Feb 19, 2024 at 7:28 PM
    ToyotaDude
    ToyotaDude Member
    2003 Tundra AC V8 4x4
    Did front brakes (pads and rotors were due) with Toy parts (Advics as it turns out) and yes plan another spring clip on bottom of caliper.
    Adjusted rears, and shoes look like they're coming up at some point for first time replacement at 247K miles with the slimmest part still about 3 mm (.012").
    Drum IDs are 295.32-295.35 mm well within spec (realize that's not measured in a groove with a drum caliper but definitely not deep to be out of spec if turned).
    Probably need to learn to search the forum better but didn't find recommendations from experience on the FGT of just swapping in OEM shoes, turning the original drums, or replacing the drums with the shoes?
    Rotor and pads.jpg Loaded caliper.jpg Rear brake.jpg Drum measurement.jpg Drum.jpg
  13. Feb 19, 2024 at 7:44 PM
    VR6T
    Question? Why does it seem like no one runs slotted rotors on our trucks? I fully intend to, but I also intend on using the truck with a 15.5ft car hauling trailer, hence the 4.08 gears. And a rear locker st some point.
  14. Feb 19, 2024 at 7:45 PM
    Mr.bee
    Mr.bee King Turdra
    '02 AC TRD
    Slotted rotors are asking for warpage. Smooth rotors have more surface area.
    txagg and Voss like this.
  15. Feb 19, 2024 at 7:45 PM
    des2mtn
    SW
    Tonto cover
    Who said noone runs slotted rotors on these trucks?
  16. Feb 19, 2024 at 7:49 PM
    VR6T
    Not sure how they would. Well out side heavy track use. Vented slotted rotors do cool faster than a solid face vented and they help displace brake pad dust.
    Voss likes this.
  17. Feb 19, 2024 at 8:05 PM
    So wait … you bought OEM and they are Advics parts that came in OEM box?
  18. Feb 19, 2024 at 9:00 PM
    artsr2002
    artsr2002 2005 Tundra DC SR5
    'Yonder
    Where's your lower clip? Adds 10HP you know.
  19. Feb 19, 2024 at 10:03 PM
    ToyotaDude
    ToyotaDude Member
    True that.
    1st Gen Tundra - Advic Pads (rear).jpg 1st Gen Tundra - Advic Pads (front).jpg advics rotor and box.jpg
    For 13WL calipers:
    04465-35290 are original (semi-met IIRC). But 04465-AZ200 are the lower cost pads (ceramic IIRC), and Advics aftermarket come with the shims.
    Advics A6F004U Disc Brake Rotor at RockAuto and other online.
    Advics AD0976 Brake Pad at Rockauto and other online
  20. Feb 19, 2024 at 10:06 PM
    ToyotaDude
    ToyotaDude Member
    Gotta get another set to add.
  21. Feb 19, 2024 at 10:08 PM
    ToyotaDude
    ToyotaDude Member
    Whose rear conversion kit?
    oscardog86 likes this.
  22. Feb 19, 2024 at 10:31 PM
    des2mtn
    SW
    Tonto cover
    SOS conversion.
    Powerstop AT-14BD calipers
    EBC slotted rotors
    EBC Orange stuff pads
    Sequoia master cylinder
    Manual proportioning valve
    I have the SOS e-brake kit installed, but I need to re-design it or/and add a Wilwood E-brake.
    Before switching to EBC with their Orangestuff pads front/ rear, I ran Powerstop Z36 pads/rotors and they ended up warping. The EBC pads bite extremely well, but they are super dusty and seem to have a shorter lifespan.
    With the SOS Performance kit, you'll need a caliper bracket cast with AT-14BD. The regular 14BD caliper bracket is too thick for the SOS Performance backing plate and will need to be shaved down.
  23. Feb 19, 2024 at 11:02 PM
    artsr2002
    'Yonder
    My Carlinkit 5.0 dongle, hehehe, dongle, ............... has been having some hiccups lately and random disconnects so I took it inside and checked for firmware updates. Two updates installed and it appears I am at the latest version. We'll see how it goes.
    KNABORES and des2mtn like this.
  24. Feb 20, 2024 at 3:35 AM
    artsr2002
    'Yonder
    In case anyone else is looking at that 3rd brake light that I installed on mine, the cargo lights are bright but they project light too far up to be useful in the bed. I have a toolbox on my truck and here is how much light hits the bed at night. Lol.
    NUDRAT, VR6T, FishNinja and 1 other person like this.
  25. Feb 20, 2024 at 8:10 AM
    87warrior
    87warrior Whiskey Tango Foxtrot
    Kansas
    2004 DC 2uz 4x4
    I finally have some Australian goodness on the Tundra. Upgraded my reverse lights with some Stedi T10/15 LED's.
    Stock vs the 1,000lm Stedi light. The stripes are caused by the tail light lens.
    Lots of light. Maybe I wont back into the side of the shop again (as you can clearly see I have done once before :mad:)
  26. Feb 20, 2024 at 8:12 AM
    FishNinja
    Lee
    06DC2wd
    LED strips
  27. Feb 20, 2024 at 8:33 AM
    Mr.bee
    Mr.bee King Turdra
    '02 AC TRD
    I havent towed a car with the tundra yet,
    do those use a toyota sized factory rotor?
  28. Feb 20, 2024 at 8:58 AM
    VR6T
    I shimmed mine with weather striping tape. It helps a bit, but I have the same complaint. But it is a nice upgrade for the flashing brake light as well. Cant be too safe on the roads these days. People just don't pay attention nor have a clue how to drive these days.
    artsr2002[QUOTED] likes this.
  29. Feb 20, 2024 at 9:19 AM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    I towed that 2nd gen Honda Insight, that I bought from my old boss and sold to my brother in law, on u-haul car dolly, with the 03, from Galveston to my house. Didn't even really feel it.
    VR6T likes this.
  30. Feb 20, 2024 at 9:26 AM
    Mr.bee
    Mr.bee King Turdra
    '02 AC TRD
    Oops, the first part of that was an abandoned reply, but towing the tractor i didnt really feel it too much either. Even got better than 14mpg & was about 5500ish lbs.
    The sequoia hauled 8k lbs a time or 2, i could feel it, but doubt the rear disc's did much to help. I'm pretty easy on brakes.
