Paint Issues
Discussion in '1st Gen Tundras (2000-2006)' started by 2006 Tundra AC, Feb 18, 2024.
  1. Feb 18, 2024 at 8:44 AM
    2006 Tundra AC
    2006 Tundra AC [OP] Slowly upgrading my grandfather's old truck
    Andrew
    Cedar Park, Texas
    '06 desert sand 4.0 V6
    Alumas, Alcans, TuRD Pro wheels, 285/70/17 Falken
    Some paint problems have reared it's ugly head during the last few months. Looks like the clear is finally going out. :( With my limited knowledge of paint, it looks to me like I could wet sand the old clear away and re-clear. What is everyone else's opinion? Re-clear, sand it down to bare metal and re-do all of it, or just let it go because, after all, it's just an old truck?
  2. Feb 19, 2024 at 8:24 AM
    dbittle
    dbittle Middle Age Member
    Huntsville AL
    2006 V8 RCLB 2WD
    Sanding it down and redoing the clear is what I did on mine, just to buy time and keep it from being so hideous with sunburn patches everywhere. It’s not a permanent fix but it will look better, absolutely.
    HBTundra likes this.
  3. Feb 19, 2024 at 9:07 AM
    2006 Tundra AC
    Andrew
    Cedar Park, Texas
    What clear did you use and would you use it again?
  4. Feb 19, 2024 at 9:29 AM
    ENOK
    ENOK New Member
    Paul
    Adirondack Mountains, NY
    2000 SR5/AC/TRD BLACK 4X4
    Sanding off the old clear and the reapplying new clear can cause ‘possible’ problems. If you don’t get all the old clear off, totally, you might have a problem of the new clear adhering since the old and new clears most likely will be different chemistry. If it were me, I would strip down to bare metal, properly prime and come back up with new base and then clear. I only use PPG on all my old trucks and have never had a issue. The bonus of going down to bare metal is you can easily change the trucks
    color and its like getting a new truck…….well at least to your eyes ha ha
    Good Luck
    Paul
  5. Feb 19, 2024 at 2:56 PM
    dbittle
    Huntsville AL
    2006 V8 RCLB 2WD
    I used duplicolor and it’s doing ok after a couple of years. I had the paint from another project and tried it to see what would happen. The gentleman with rhe previous reply is certainly correct that a full repaint is best, but putting on something is way better than doing nothing and letting surface rust start. It will look about 80% better. The base paint goes back to the original color when you re-clear.
  6. Feb 19, 2024 at 3:15 PM
    ENOK
    ENOK New Member
    Paul
    dbittle;
    Unless your a Pro, shooting paint every day, never mix brands of paint or clears, etc.. Many different chemistries are used in making paint. Some chemistries between brands do not play nice when laying primers, base, clear etc. Disaster can happen quick.
    I only use PPG Commercial Auto Finish paints, hardness and clears.
    From Bare Metal up it goes like this;
    PPG MP-170 Epoxy Primer
    PPG MP-180 High Build Primer
    PPG Shop Line Base Color
    PPG Shop Line High Solids Clear
    Frame/Under carriage;
    PPG MOA Chassis Black Satin
    Paul
  7. Feb 19, 2024 at 3:39 PM
    dbittle
    Huntsville AL
    2006 V8 RCLB 2WD
    Peace, brother, peace.
  8. Feb 19, 2024 at 3:42 PM
    whodatschrome
    whodatschrome New Member
    North of North Plains, Oregon
    lots of dents
    x2 ^^^^
  9. Feb 19, 2024 at 3:48 PM
    ENOK
    ENOK New Member
    Paul
    Forgive please, I do not understand your post ?
    Paul
  10. Feb 19, 2024 at 8:12 PM
    dbittle
    Huntsville AL
    2006 V8 RCLB 2WD
    It means I answered the man’s question and I’m tired of the conversation.
