Diff housing
Discussion in '1st Gen Tundras (2000-2006)' started by Aaol1, Feb 12, 2024.
  1. Feb 12, 2024 at 4:41 PM
    Aaol1
    Aaol1 [OP] New Member
    Sam
    05 DC tundra TRD offroad 4x4 V8 w/ LSD and tow
    2 inch lift, diff drop
    Hey all,
    Finally switching out my 3rd today from ECGS. Was all fairly straightforward, was looking for issues or damage anywhere and I did find this which is interesting.
    Looks like a chunk of diff housing broke off at some point? There was no leaks with the old one , so I'm guessing not too concerning?
  2. Feb 12, 2024 at 5:20 PM
    I haven’t had mine apart, but I’m not convinced that’s broken. Looks intentional?
    FirstGenVol likes this.
  3. Feb 12, 2024 at 5:33 PM
    shifty` Ten EV 12's so you know I raise hell
    Especially if you look at the lip behind it which has an oddly similar shape machined into it. And it looks machined to me, both.
    KNABORES[QUOTED] likes this.
  4. Feb 12, 2024 at 6:15 PM
    Aaol1
    Sam
    Yea now that I'm seeing that I'm thinking same thing actually. Such a weird shape but definitely looks the same
  5. Feb 13, 2024 at 3:08 AM
    tvpierce
    tvpierce Formerly New Member
    Maine
    Looks like the same machining is on the opposite side as well.
  6. Feb 13, 2024 at 7:43 AM
    whodatschrome
    whodatschrome New Member
    North of North Plains, Oregon
    lots of dents
    No doubt that factory notch is there so that the girdles/bearing caps on the 3rd member can slip past that particular spot. It’s toyota’s round hole square plug technology.
    Aaol1[OP] likes this.
  7. Feb 13, 2024 at 9:58 AM
    w666
    w666 D. None of the above
    Maryland
    04 Access Cab SR5 V8 4WD
    The same notch (2, actually) are on the factory gasket as well.
    (the magnets are holding my gasket on the side of my tool box to prevent damage until I'm ready to use it...just in case you were wondering what you're looking at)
    whodatschrome, Aaol1[OP] and des2mtn like this.
  8. Feb 13, 2024 at 9:59 AM
    kentuckyMarksman
    kentuckyMarksman New Member
    Looks like intentional machining to me.
  9. Feb 13, 2024 at 3:02 PM
    I was thinking it was for a Elocker rear end, but not sure if 8.4s came with a Elocker for a different model. I just did my diffs and didn’t notice/pay attention
    whodatschrome[QUOTED] likes this.
  10. Feb 13, 2024 at 3:44 PM
    assassin10000
    assassin10000 New Member
    Andrew
    Northern CA
    '05 SR5 AC
    Normal.
    Elocker notch is at 3 o'clock.
    whodatschrome and FrenchToasty like this.
  11. Feb 19, 2024 at 6:57 PM
    Aaol1
    Sam
    Nice perfect , thanks everyone! glad its not broken or anything lol
