DIRTY SEVEN CLUB
Discussion in '2.5 Gen Tundras (2014-2021)' started by matictundra, Feb 18, 2019.
  1. Feb 13, 2024 at 7:49 AM
    #3241
    J's 4x4
    J's 4x4 New Member
    Juan
    Los Angeles County
    2020 Tundra Cement Grey TRD 4x4
    King lift,Leather seats,3m film wrap around,35's KO2 on FUEL Wheels,Line-X, backflip,Bam 10" exhaust with Toyota Black Chrome Exhaust tip,Amp research step,K&N air Filter,TRD air flow Accelerator
    Morning fellas, so quick question for you all. I've read about 7 pages now and very informative. But I guess I'm still paranoid about it. I want to jump onto 37's but want to know if I need to do anything to my lift. Currently running Kings with a 3" lift with body chop. I forget what upper control arms I'm running I'll look later. Wheels are 18" with zero offset. I called the place where I did my lift and they said I wouldn't be able to run 37's cause of my lift. Just wanted to see if this is true or not. Any info will help. Currently looking at getting some Toyo RT tires, my k02 have about 30k on them but I 've had them for about 4 years now and would like to get a fresh set of tires. Thanks again
    MTBTANDRA801 and bmw345 like this.
  2. Feb 13, 2024 at 10:15 AM
    #3242
    Chad D.
    Chad D. New Member
    Western Oregon
    2018 CrewMax Platinum
    Only 132 more pages to go…
    It’s not the lift that’s hurting you, it’s the 0mm offset. Try moving to a +25 to +35 and you’ll be in better shape with less trimming.
    SAGE63, bmw345, TS1794 and 2 others like this.
  3. Feb 13, 2024 at 10:32 AM
    #3243
    Boisefly
    Boisefly New Member
    Boise, ID
    2014 Crewmax 1794 4WD
    No problem jumping to 37's. Like Chad said, 0 offset might cause more rubbing on the fender behind the front tires. Would be best to have adjustable UCAs to increase caster a bit. Your lift would be great for 37s.
    J's 4x4[QUOTED] likes this.
  4. Feb 13, 2024 at 1:17 PM
    #3244
    J's 4x4
    J's 4x4 New Member
    Juan
    Los Angeles County
    Sounds like a new set of wheels & tires is what I'm hearing. Appreciate the info fellas. Will keep ya updated on how my new set up goes. Thanks again
    SAGE63 and TS1794 like this.
  5. Feb 14, 2024 at 6:37 AM
    #3245
    bmw345
    bmw345 New Member
    CT
    2018 Platinum Pro, Pro Fox's TRD Skid
    I am running 2.5" front and plus 1" shackle in the rear and running plus 35 offset 17's with 37's. No rubbing at all. I am bumper spaced and the plastic is pushed back an extra inch and do have a BMC. Good luck!
  6. Feb 14, 2024 at 10:15 AM
    #3246
    J's 4x4
    J's 4x4 New Member
    Juan
    Los Angeles County
    On the hunt now to look for new wheels with the offset you guys gave me. Hard part is deciding which wheel and how they look in person Vs internet.
  7. Feb 14, 2024 at 11:07 AM
    #3247
    Shanet421
    Shanet421 (Semi) New Member
    San Diego,CA
  8. Feb 14, 2024 at 1:33 PM
    #3248
    Chad D.
    Chad D. New Member
    Western Oregon
    If I were putting 37” tires on 17” wheels for a Tundra, I’d be looking at any 17x8.5” with +35mm offset. That’s pretty easy to find. Method for sure, and I believe SCS may be the same offset in their 17” flavors.
    J's 4x4 likes this.
  9. Feb 14, 2024 at 3:05 PM
    #3249
    SAGE63
    San Diego County
    J's 4x4 and coTony like this.
  10. Feb 15, 2024 at 1:31 PM
    #3250
    nmpeter
    nmpeter New Member
    South Florida
    18' Tundra Cement Crewmax
    I finally got my 37s on. 3.5/3" lift
    BMC, bumper shim mod, SPC UCA, trimmed plastics. Rubbing the BMC on full lock left and I believe some plastics need to be cut more.
    I got an alignment after the mount and balance and asked the tech to get me as much caster as possible. We went from 5.3 to 4.7, and 6.3 to 5.8.
    I went home confused on why I had less caster than originally.
    I'm back today and I asked another tech to see if he would be able to adjust the caster and try to get it as close to 6 as possible. Caster specs did not change but now I have negative camber.
    Should I find a new shop or are alignments more complicated than they seem?
  11. Feb 16, 2024 at 8:08 AM
    #3251
    reneaux
    reneaux I've been around
    2017 SR5 CM 4x4
    May want to check that the SPC balljoint is in the correct position to max caster. My guess is he is not adjusting that and only adjusting cams. A good alignment shop should be able to adjust these for you. Usually they are not just your typical alignment shop though and are some sort of race/performance/offroad shop. I have a drift car so my drift car shop buddy was able to dial in everything for me however it cost me $200 for a one-time alignment, which is typically what my drift car costs after I hit another car or end up needing adjustments.
  12. Feb 19, 2024 at 1:42 PM
    #3252
    Downytide
    Downytide New Member
    GTA
    Lunar Rock that whines
    Did test fit, so the Turbomac HD 17x8.5 et0 clears StopTech ST60 calipers, goal is to have tires on by end of the week.
    Update: done, exhaust needed to be chopped :(
    I love the ride, not sure how much the springs will settle, ET0 requires lot of massaging but it clears 99.5% of time, will need more caster when new shocks go in.
    J&ATundra, reywcms, n0rth and 9 others like this.
  13. Feb 26, 2024 at 8:01 AM
    #3253
    J's 4x4
    J's 4x4 New Member
    Juan
    Los Angeles County
    I've been silent for a min but I think I'm going to pull the trigger. I wanted to go 17" wheels but I thought I read somewhere that for the big brake kit wheels need to be 18", 17" wouldn't work. Any info on this ?
    Jman245 likes this.
  14. Feb 26, 2024 at 8:35 AM
    #3254
    Jman245
    Jman245 Just moving about my way.
    Jay
    R.CUCAMOMGA,CA
    '19 Tundra TRD SPORT, ‘21 Trail Edition
    Trd pro suspension
    Yes, but there is a kit that clears 17’s. If you search on this site you should find it. I think it starts with an A
  15. Feb 26, 2024 at 8:37 AM
    #3255
    Jman245
    Jay
    R.CUCAMOMGA,CA
    Trd pro suspension
    Here ya go, https://alconkits.com/products/toyota-lc300-tundra-2021-front-big-brake-kit
  16. Feb 26, 2024 at 9:44 AM
    #3256
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    2017 Tundra Platnium
    Too many mods to come
    17s and no issues with the Alcon kit fitting.
  17. Feb 26, 2024 at 11:41 AM
    #3257
    Downytide
    GTA
    Fifteen52 Turbomac clears Stoptech ST60 kit
    if you look with magnifying glass you can see the clearance.
    CaptRussia253 and reywcms like this.
  18. Feb 26, 2024 at 11:42 AM
    #3258
    J's 4x4
    J's 4x4 New Member
    Juan
    Los Angeles County
  19. Feb 26, 2024 at 12:20 PM
    #3259
    Downytide
    GTA
    yes, 17x8.5 et0
    barrels is gonna be the tight spot, but it clears, tons of space between spoke and caliper surface, I think Alcon has more clearance than Stoptech.
    J's 4x4 and reywcms like this.
  20. Feb 27, 2024 at 12:38 PM
    #3260
    Mrf1987
    Mrf1987 New Member
    2020 Trd sport tundra
    Bilstein 8112’s up front and 8100 bypasses in the rear
    Alan 1200lb over stock and 1.5” of lift in rear with .5” shackle
    Titan 7 T-Ak1 wheels 17x8.5 +5
    Drt fab body mount relocate
    Toyo RT trail 37x12.50R17
    Deaner, Cthulhu, kbahus and 17 others like this.
  21. Feb 28, 2024 at 7:13 AM
    #3261
    Downytide
    GTA
    still loving the 8100/8112? I'm still waiting for mine to arrive, those Titan was my first choice but couldn't get them to clear the calipers.
    AZBoatHauler and reywcms like this.
  22. Feb 28, 2024 at 7:55 AM
    #3262
    AZBoatHauler
    So.Arizona
    Same question as @Downytide on your feelings about the 8112 suspension.
  23. Feb 28, 2024 at 8:08 AM
    #3263
    Mrf1987
    Mrf1987 New Member
    I had the kings before the bilsteins so i can give a comparison based on that. Remember the Billy’s were tuned by Ian at wheel every weekend.
    The bilsteins shine over the kings for a few reasons.
    1-The fit and finish is nicer and they have held up way better than the kings in the winter
    2- The Ride quality is much much better being that the front is more plush with more articulation. Less preload is needed on these than the kings because the coil on the Billy 8112’s is actually bigger and thicker. The Billy’s use a body that is bigger than 2.5” like the king so the spring follows suit and carries the static load better with less preload. The rears made my truck Feel like a completely different rig. The adjustability is great and the adjusters actually do something that is felt unlike the kings.
    3- I get more drop out in the back being that the Billy is about 1-1.5” longer than the king.
  24. Feb 28, 2024 at 8:08 AM
    #3264
    Mrf1987
    Mrf1987 New Member
    Which calipers are you running? I’m on stock calipers i just had to watch where i put the stock on weights so that they would clear.
  25. Feb 28, 2024 at 8:35 AM
    #3265
    Downytide
    GTA
    Stoptech ST60, James from Titan said the wheel spoke will foul the caliper surface, and the barrels would've been close, surprsingly the Fifteen52 clears with tons of space.
  26. Feb 28, 2024 at 9:24 AM
    #3266
    Jman245
    Jay
    R.CUCAMOMGA,CA
    Trd pro suspension
    I’m on Titan AK2 and they clear factory calipers
  27. Mar 2, 2024 at 8:22 PM
    #3267
    SnowLizard
    SnowLizard New Member
    Richard
    Can I join the club now?
    Bilstein 5100 front max height
    Bilstein 5160 rear + shackles
    Falken Wildpeak R/T 37 12.5r18
    BORA 1.25 spacer
    Stock rims
    Cmc
    Viper cut bumper (needs more trimmimg)
    dherring256, V3N0M, Rugerla1 and 13 others like this.
  28. Mar 2, 2024 at 9:23 PM
    #3268
    eSkittles
    eSkittles New Member
    2021 Tundra Amy Green 1794
    WOW thanks for pics!
    I have traverseHD, same spec wise. Another option for BBK!
    Wonder why the site says 20" wheel required tho
  29. Mar 4, 2024 at 8:54 AM
    #3269
    Downytide
    GTA
    There's two kits, one uses factory sized rotors, which I have, clears 17s, but SOS couldn't be certain since the ST60 calipers are wider and has more overall diameter, so he always said use 18" to be safe, Titan confirmed the smaller version won't clear either TAK1/2 wheels since spokes will foul.
    The second one is 380mm kit, that one SOS mentioned needs 20", I'm sure some 18s will clear but you will need a flat spoke design with low offset, Vivid Racing Forged wheels, I think D02 would clear in 18"s, but they run 18x9 et0, Volks Te37XT 18x9 won't clear the 380mm kit, but will clear the 353mm kit.
  30. Mar 5, 2024 at 9:22 AM
    #3270
    bmw345
    bmw345 New Member
    CT
    37’s to 37’s. Went from 17” Alpha’s with KO2’s to 17” Method 706’s with Baja Boss AT’s. Damn these things are beeefy! IMG_3972.jpg
    Kidd74, Deaner, V3N0M and 9 others like this.
