Wood Grain Interior Question
Discussion in '1st Gen Tundras (2000-2006)' started by socomoby, Feb 18, 2024.
  1. Feb 18, 2024 at 10:14 AM
    socomoby
    socomoby [OP] New Member
    2006 DC V8/2WD SR5 LSD
    Hello all. I was piddling around in the other wood grain threads and could not find an answer to my question (or probably overlooked it)
    Anyway, I’ve identifies a few bezels online for the 2WD but they all are a bit expensive as opposed to their 4WD counterparts for some reason. To be specific, I have bezel with the Carho Lamp and Defrost button on the on the right hand side. Emergency flasher on the left, under the Shift L button
    Is the 4WD version of the bezel above compatible with the 2WD l? I was hoping to get lucky enough for it to be compatible and just have the 2WD/4LO buttons on the clock face ignored for obvious reason
    Weagle likes this.
  2. Feb 18, 2024 at 1:13 PM
    Weagle
    Weagle I survived my timing belt change
    Prattville, AL
    2006 Tundra SR5 DC 4.7 2WD LSD towing pkg
    Bilstein 5100's with 2883's - close to 2" Replacing the 2883's and going back to the bottom perch ASAP -mobile/apple play stereo with sub and backup cam -Power stop HD front calipers and rotors for towing -20" wheels with 32" tires (305/50's) Toyo AT 3's with no rubbing -Westin nerf bars -Detroit axle new (not rebuilt) steering rack with poly bushings, inner and outer TRE's -Suspension Maxx extended front sway bar links -Overland tuning - medium level -Power front leather seats and steering wheel from 06 Sequoia -fully de-chromed/blacked out trim -all light housings incl 3rd brake light and tag lights replaced with smoked lenses, LED where appropriate -mini projector headlights -fully rebuilt trans and new torque converter -new complete drive shaft with spicer u-joints and carrier bearing -all LED interior lights including backlighting -new lower window seals for all 4 doors -all new hardware and clips for tailgate Next: Dirty Deeds racing exhaust with LT headers, yellow box, 12 hole DD fuel injectors, redo or replace door panels
    Wish I could help you. I think I recall that possibly some years were compatible with sequoias? if so, they would at least expand your options some
  3. Feb 18, 2024 at 1:14 PM
    jerryallday
    jerryallday New Member
    Jerry
    Pasadena, Ca
    2006 DC SR5 V8 Grey
    Add a picture of the one you need
    Weagle likes this.
  4. Feb 18, 2024 at 1:23 PM
    socomoby
    Second picture is the one I need. First picture is the one that’s for a 4WD model. Asking if the first picture is fine to place in a 2WD model and retain all functionality of the bezel, outside of the 2WD/4WD buttons on the clock
  5. Feb 18, 2024 at 2:17 PM
    Weagle
    Prattville, AL
    I'm pretty sure those are fully interchangeable
  6. Feb 18, 2024 at 2:32 PM
    You’ve got a lot of fun waiting ahead of you to swap stuff over. As long as the HVAC and clock chunk get moved you’ll probably be fine, not all are cross-compatible, but potentially some work there. I’d search locations other than fleabay.
  7. Feb 18, 2024 at 3:16 PM
    socomoby
    Thanks all. Shifty, were else would I look beside a Toyota parts site? I didn’t see OEM bezels anywhere but eBay and Toyota
  8. Feb 18, 2024 at 3:46 PM
    bfunke
    bfunke Tundra Curmudgeon
    The earlier bezels have a smaller opening than the newer version
  9. Feb 18, 2024 at 4:15 PM
    Www.car-part.com
    I search for parts trucks on Facebook Marketplace, OfferUp and Craigslist also. You’d be shocked at how many are out there.
  10. Feb 18, 2024 at 4:58 PM
    Leg 99
    Leg 99 New Member
    ‘06 2WD DC X-SP
    What type of panels do you currently have? I have an 06 2WD with all the wood grain, possibly thinking about painting it or plasti-dipping it black. If you have all the black trim pieces I might be down to swap, located in GA.
  11. Feb 18, 2024 at 5:43 PM
    socomoby
    I wish I would have made this thread 2 days ago lol. I already have bought all the other pieces. I just need the bezel at this point
  12. Feb 18, 2024 at 5:47 PM
    Leg 99
    Leg 99 New Member
    ‘06 2WD DC X-SP
    I see lol. Well, what are you planning on doing with your old pieces? Might still be interested in taking them off your hands if they’re in good shape.
  13. Feb 18, 2024 at 5:59 PM
    socomoby
    Well for the console and bezel I had no problem to get rid of. I was going to keep the door pieces as backups but I think I’d give it all for the bezel. I will say the cup holder trim piece of the console is missing most of all the little rubber flaps that would “ hold” a smaller cup.
  14. Feb 18, 2024 at 6:06 PM
    Man I nearly had to give my minty black bezel away for free to a forum member on here.
  15. Feb 20, 2024 at 4:29 AM
    JasonC.
    JasonC. ¯\_(ツ)_/¯
    2001 4x4 4.7L “Best Cab”/AC Limited 50k mi
    If you’re buying stuff on fleabay, there’s a guy that sells those foam insert replacements. Mine turned out great.
    G_unit3000 and jerryallday like this.
  16. Feb 20, 2024 at 2:12 PM
    socomoby
    Huh I see now. I may give it a go. Thanks for the tip
  17. Feb 20, 2024 at 2:30 PM
    There's a couple actually. And one of the guys selling the foams, they tend to go purple after a while if you park in the sun. The buyer I bought mine from was "eptech2003"
  18. Feb 20, 2024 at 6:22 PM
    The first has the “shift L” button for the 5 speed auto. The second has a “Tundra” button. Do you need that shift L button? Can you swap the buttons from your bezel into whichever you buy?
  19. Feb 20, 2024 at 6:37 PM
    socomoby
    You are correct. I don’t “need” the shift L button but my bezel has it. I think what I’ll end up doing is buying the 4WD bezel, switching the boards over and obsolete the buttons on the clock.
  20. Feb 20, 2024 at 6:46 PM
    whodatschrome
    whodatschrome New Member
    North of North Plains, Oregon
    lots of dents
    You can peel off the long thin flexible black plastic that covers the clock and then swap it on a different bezel. The only thing is that the adhesive on the back side of it might not restick as well. Use a heatgun or hair dryer to soften up the sticky glue. And clean your hands really well before hand so that the oils don't contaminate the sticky stuff. Better yet, just make sure you don't touch the sticky stuff at all.
    socomoby[QUOTED][OP] and shifty` like this.
  21. Feb 20, 2024 at 9:14 PM
    Whether you plan to use it, or it’s actually required for the truck to function properly may be two different things. I’m not sure as my truck has the 4 speed and no shift-L
  22. Feb 21, 2024 at 2:12 AM
    socomoby
    i don’t believe it’s necessary. It only engages if you toggle it and to do so you have to specifically put the rig in 2nd gear first. Like I said I’ll get the bezel with the Shift-L button already available so hopefully it won’t be an issue either way
    KNABORES[QUOTED] likes this.
  23. Nov 25, 2024 at 11:23 AM
    Rich L.
    Rich L. This too shall pass
    Pacific NW
    '06 SR5 AC V8 4WD
    If you peel off this "long thin flexible black plastic ... cover" deal does it free the buttons? I ask because I want to swap the "Auto LSD" button in one bezel for a diff. lock button from another bezel. But even when I open it up and remove the circuit boards from the back of the bezel, the actual button part is still trapped in the bezel somehow.
    Does peeling off the cover separate the 4WD buttons from the bezel? Thanks.
  24. Nov 25, 2024 at 2:10 PM
    whodatschrome
    lots of dents
    It’s been a minute, but i think i had to pry the 4wd buttons out from the back of the dash bezel? I think they were clipped in?..or maybe it was smaller #1 phillips screws? I can’t remember if there were any errant springs in there that would try to make a break for freedom or not.
    I don’t think pealing off that plastic strip has anything to do with the switches themselves. All it was is to cover up the holes where a switch would reside.
    Rich L.[QUOTED] likes this.
  25. Nov 25, 2024 at 2:15 PM
    Rich L.
    Pacific NW
    '06 SR5 AC V8 4WD
    Thanks! I got brave and tried prying. Yes, the button is 2 parts that clip to each other. Pry them apart and one part comes out the back and the other out the front of the bezel. No springs, no removal of the sticky bits required. Yay!
    whodatschrome[QUOTED] likes this.
