2007 tundra crewmax
Discussion in '2nd Gen Tundras (2007-2013)' started by Tamorris78, Feb 18, 2024.
  1. Feb 18, 2024 at 7:04 AM
    Tamorris78
    Tamorris78 [OP] New Member
    Terry
    2007 tundra green crewmax 5.7l sr5
    How to you remove the 4wd switch in the dash??? I think mine has went bad cause it does nothing....TIA is there anyway to check these???
  2. Feb 18, 2024 at 7:21 AM
    shawn474
    shawn474 Lego connoisseur
    MoCo, Maryland
    If you haven’t done so already, I would check fuses and other more common issues related to the issue prior to pulling the switch. I have never heard of one of these switches going bad. Something the actuator or solenoid go bad as well. Might look there too.
  3. Feb 18, 2024 at 7:39 AM
    Tamorris78
    Terry
    I have checked all fuses and the actuator on front axle looks new...and how would you check the one on the transfer case???
    Any info would be greatly appreciated cause I just bought this truck like 2 days ago and trying to figure out the 4wd.. this is my first toyota ever
  4. Feb 18, 2024 at 7:47 AM
    apwisher
    apwisher New Member
    Everett, WA
    2007 CM SR5/TRD 4x4 White
    canopy, TRD Sway, audio
    To get to that switch, just follow a tutorial on how to replace the stereo. If you have an aftermarket stereo it may be worth a look in case it didn't get plugged back in. this may especially be true if the previous owner yoinked the stereo out before you bought it. they would likely be in a hurry. I would think if the problem was an actuator it would still flash on the gauge cluster when you turned the knob. If there is nothing, then yeah, I'd check the switch and fuses.
    PolishedTRD likes this.
  5. Feb 18, 2024 at 7:49 AM
    Tamorris78
    Terry
    I have checked all fuses and the switch is plugged in I checked that after I checked the fuses...and I get nothing on the dash no 4hi no 4lo nothing...its like it's not even hooked up but it is... and the actuator on the front axle new brand new and I'm not sure how to check the one of the transfer case... this is my first toyota ever and I just bought it 2 days ago
  6. Feb 18, 2024 at 8:05 AM
    apwisher
    apwisher New Member
    Everett, WA
    If there is nothing on the dash cluster then I would pull the fuse again, check it with a multimeter (if you haven't already) and also see if you have power to the fuse block. If there is no power there, then start a very careful check for rodent damage, as ican be fairly common depending on where you live.
  7. Feb 18, 2024 at 8:09 AM
    Tamorris78
    Terry
    Ok I will check those thank you
  8. Feb 18, 2024 at 10:45 AM
    Canman
    Canman New Member
    2007 Crewmax Limited
    I would take it back to where you purchased it from or the person who sold it to you. Makes no sense for the 4x4 system not to function two days after you got the truck. Did you test it prior to buying it?
  9. Feb 18, 2024 at 10:47 AM
    Tamorris78
    Terry
    Unfortunately not and it was "as is" I didn't think about it till yesterday when I tried it..
  10. Feb 18, 2024 at 1:45 PM
    Canman
    Canman New Member
    Damn! Might best to take it to a garage and have them scan it for codes before you start digging into too far.
  11. Feb 18, 2024 at 7:32 PM
    huntertn
    huntertn New Member
    Tennessee
    2008 White CrewMax Limited 4x4
    I wonder if someone messed with the bulbs? When you turn the key on and the system does the light bulb check where it lights up the warning lights, do you get a VSC OFF light for a second and then it goes out? The 4lo and 4hi don’t light up during that check. And, don’t get a Check engine light for a sec?
