Those in the 5w-30 crew…
Discussion in '2.5 Gen Tundras (2014-2021)' started by acruisinf, Feb 17, 2024.
  1. Feb 17, 2024 at 10:54 AM
    acruisinf
    acruisinf [OP] New Member
    South Texas
    2020 1794 4x4
    About where does your oil pressure gauge hover during driving?
    I ask because my Land Cruiser 200 has been running 5w-30 for a year and the gauge hovers around the 1/4 mark and floats up to half point every now and then.
    I just put 5w-30 in my new-to-me 2020 Tundra with 23k and the gauge hovers around half point and floats a bit above under acceleration.
    Same oil, same fill quantity, same engine(?!)…I’m wondering what’s the difference and more importantly, what is the oil pressure danger zone in our trucks?
    Thanks all!!
  2. Feb 17, 2024 at 10:56 AM
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    My gauge does the same as yours.
  3. Feb 17, 2024 at 10:58 AM
    acruisinf
    South Texas
    2020 1794 4x4
    Thanks for the quick clarifications and validation, crew!
    2mchfun and texasrho83 like this.
  4. Feb 17, 2024 at 4:36 PM
    SportDek
    SportDek Boat hauler, Bus Driver
    Dale
    TEXAS from MN
    2021 1794 Tundra Crewmax Windchill Pearl
    TRD Swaybar, RCI Skid plates, DiamondBack HD cover, bed rug, Cooper AT3 4S
    For what it is worth, I use Mobil 1 Truck & SUV Full Synthetic Motor Oil 5W-20. It has gotten rid of the Tundra Tick/diesel sound at idle. My oil pressure gauge has went from just below 1/2 to between 1/2 and 3/4 mark.
    acruisinf[OP] and IA_Tundra like this.
  5. Feb 17, 2024 at 4:53 PM
    2mchfun
    Mine runs 5w-30 and does a similar dance, just under 48% at idle in gear, then advances upwards to around 64% or so under acceleration.
    acruisinf[OP] and myt1 like this.
  6. Feb 17, 2024 at 4:57 PM
    SportDek
    Dale
    TEXAS from MN
    Sounds like we are in sync then! lol
  7. Feb 17, 2024 at 5:48 PM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    2017 Tundra Platnium
    Too many mods to come
    Oil pressure will rise under acceleration. All normal. If it doesn’t then that’s a problem lol
  8. Feb 17, 2024 at 5:55 PM
    OHwendTrd
    OHwendTrd Aging Member
    Josh
    21 SR5 3UR-FE
    ATF Cooler
    Yup! Fixed it for you btw.
  9. Feb 17, 2024 at 6:08 PM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Amsoil 5w-30 and I change the filter every other oil change
    reywcms likes this.
  10. Feb 19, 2024 at 7:23 AM
    acruisinf
    South Texas
    2020 1794 4x4
    Haha, come on man, give me more credit than that. Rising under acceleration wasn’t my concern. It was the overall range (I thought it was high) on the gauge.
  11. Feb 19, 2024 at 7:27 AM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    Same pressure and observation of gauge using 5w-30. You're good to go.
    2mchfun and acruisinf[OP] like this.
  12. Feb 19, 2024 at 8:00 AM
    BiggHertz
    BiggHertz DZTLIMO
    Chandler, AZ
    IG: dztlimo
    Stuff and Things
  13. Feb 19, 2024 at 8:50 AM
    Gene_in_FL
    Gene_in_FL SUPER genius
    FLORIDA
    2016 SR5 DC 5.7 2021 SR5 DC 5.7
  14. Feb 19, 2024 at 8:58 AM
    OHwendTrd
    Josh
    21 SR5 3UR-FE
    ATF Cooler
  15. Feb 19, 2024 at 10:18 AM
    Skaufma0
    Skaufma0 Just a little stitious.
    Rock Hill, SC
    2018 MBM Limited CM
    Amazon's vehicle fit stuff is shaky at best. Any time I've bought anything on there for any vehicle it hasn't been accurate.
    Gene_in_FL[QUOTED] likes this.
  16. Feb 19, 2024 at 11:27 AM
    Jowett
    Jowett New Member
    North Adams, MA
    2011 Regular cab long bed 5.7 Work Truck Package
    Many on the way.
    Buy the one with the script in Fuji blue. 12180-38030
  17. Feb 19, 2024 at 11:29 AM
    BiggHertz
    BiggHertz DZTLIMO
    Chandler, AZ
    IG: dztlimo
    Stuff and Things
    Even more in your face anti-EPA messaging...
    Mdl likes this.
  18. Feb 19, 2024 at 11:43 AM
    Joe333x
    Joe333x Member
    Boston
    2019 Tundra CrewMax Platinum
    5w30 doesn't change the oil pressure gauge when compared to 0w20 in my experience anyway. Now when you put 15w40 in then it will actually read a little higher.
    acruisinf[OP] likes this.
  19. Feb 20, 2024 at 8:29 PM
    d33pt
    d33pt New Member
    Do you guys use 5w-30 syn or dino oil?
  20. Feb 20, 2024 at 8:31 PM
    2mchfun
    Mobil One synthetic
  21. Feb 20, 2024 at 8:42 PM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    When cold the oil pressure is definitely higher with 5w-30 than 0w-20 in my guage.
    i like 5w-20 the best. Truck sounds and feels the best
  22. Feb 20, 2024 at 8:56 PM
    RobertD
    Robert
    DFW, Texas
    :spending:
    Damn it. I was on the fence but that gives me more blue under the hood..... @BlueRibbon4x4 :anonymous:
    BlueRibbon4x4 likes this.
  23. Feb 20, 2024 at 9:26 PM
    There is no reason to use Dino oil. None.
    Gene_in_FL, Mdl and blenton like this.
  24. Feb 20, 2024 at 11:38 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    If you do run the abiogenic oil change it at 3k. Synthetic stands up to the harsh conditions especially if your Supercharged or running a turbo.
  25. Feb 22, 2024 at 6:41 AM
    fallen0
    fallen0 New Member
    Minnesota
    2017 Tundra TSS OFF-ROAD, 2020 Mazda CX-5, 1997 Mazda Miata
    I saw no gauge difference between 0w-20 and 5w-30. When warm, the gauge is at the middle at idle and goes up to about 3/4 when accelerating depending on load.
