OEM vs Amp bedstep
Discussion in '3rd Gen Tundras (2022+)' started by 4lo Toys, Feb 17, 2024.
  1. Feb 17, 2024 at 7:42 AM
    4lo Toys
    4lo Toys [OP] New Member
    Andrew
    New truck is too tall to be easy to get in and out of. Wife is really struggling and we use the bed multiple times per week. I’m thinking a bed step is the solution, but I admit I don’t love the way they look stowed.
    What are the pros/cons of the OEM vs AMP or others?
  2. Feb 17, 2024 at 8:24 AM
    raylo
    raylo not so new member
    Frederick, MD
    DashCam, amp & sub, DIY rear seat delete, cat shield
  3. Feb 17, 2024 at 8:26 AM
    Breathing Borla
    Northern Illinois
    I really like the power bed step I have, it tucks nice and flat unlike the non power ones I've seen, and it's the perfect height.
    works awesome when you put your golf shoes on, HA
    that said, its probably pretty hard to add the OEM power one I would think
  4. Feb 17, 2024 at 8:27 AM
    smileytn1
    smileytn1 New Member
    Hey Dude I am with ya 100% . I am short and the 20 inch tires are pretty tall when coming form sixteens on last truck. The step is just like yours and is a bit getting use to on the truck i have found that getting to the side instead of rear i can get the step to come down easier because it moves out and down. Also i use GO RHINO electric running boards and they are far superior in construction and bells and whistles than the amp.
    IdahoRay likes this.
  5. Feb 17, 2024 at 8:39 AM
    Breathing Borla
    Northern Illinois
    20" tires are super small, smaller than my snowblower, HAHA:anonymous:
    teab likes this.
  6. Feb 17, 2024 at 8:49 AM
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Any power step vs OEM/non-power has a major disadvantage: when the mechanical aspect fails, they're utterly useless.
  7. Feb 17, 2024 at 8:51 AM
    4lo Toys
    Andrew
    Other than the height is there something else you don’t like about it? How far below the bumper is it when down?
  8. Feb 17, 2024 at 8:51 AM
    4lo Toys
    Andrew
    I’m only looking at manual options.
  9. Feb 17, 2024 at 8:57 AM
    raylo
    Frederick, MD
    It isn't the most attractive thing, but it isn't all that bad IMO. Some folks seem to have bigger gaps than others in the up position. My main issue is that the low deployed height makes it not very useful, IMO. It goes way below the bumper when down. GM's bumper steps are far superior.
  10. Feb 17, 2024 at 9:06 AM
    Dpoll995
    Dpoll995 New Member
    Houston TX
    2024 Tundra Limited
    I believe they all look about the same. I put an aftermarket bed step on my last tundra and it pretty much looks the same as the oem on my new tundra
    ChucklesToy likes this.
  11. Feb 17, 2024 at 2:47 PM
    4lo Toys
    Andrew
    Shopping around online it looks like the OEM can be had a lot cheaper than the AMP version. I don’t really want to risk it on an Amazon knock off so I guess Toyota is the way to go.
  12. Feb 17, 2024 at 4:09 PM
    Blufin
    Blufin Seasoned member
    Bob
    23 Capstone
    I dunno about that,the platinum extended warranty covers it for 10 years soup to nuts.
  13. Feb 17, 2024 at 5:45 PM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Doesn't matter if they're covered under warranty. The time it takes to do a warranty claim and swap for a working step you don't have a step.
  14. Feb 18, 2024 at 4:36 AM
    Blufin
    Bob
    23 Capstone
    Maybe so, if your words are true and fall into this new acceptance of the laxidasiy un accountability & poor work ethic post covid BS. There will be some extended down time, but it will get fixed or replaced under warranty, I am patient within normal boundaries.
    texasrho83 and IdahoRay like this.
  15. Feb 18, 2024 at 6:37 AM
    Sunman54
    Sunman54 New Member
    Why not just a simple folding step stool from Home Depot, Lowes, Etc. Thats what I use on my 2015 Tundra bed.
    texasrho83 and doublethebass like this.
  16. Feb 18, 2024 at 8:10 AM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    I had an F150 Lariat that had that nifty built-in tailgate step that folded out from inside the tailgate. There was also a pole that flipped up and locked into place to grab onto as you climbed up the step.
    Something similar here.
  17. Feb 18, 2024 at 8:55 PM
    matth66
    matth66 New Member
    matt
    Nor cal
    2023 Black Tundra Trd Pro
    I have oem non power, it does sit a little low but still works, my only wish is if they had a passenger side option as well
  18. Feb 29, 2024 at 6:46 AM
    Selcouth
    Selcouth New Member
    Josh
    2019 Smoked Mesquite 1794
