Lost all my Keys 2006 Toyota tundra
Discussion in '1st Gen Tundras (2000-2006)' started by Morrisonleroy, Feb 16, 2024.
  1. Feb 16, 2024 at 7:36 AM
    Morrisonleroy
    Morrisonleroy [OP] New Member
    Morey
    2006 toyota tundra
    I don't believe I need a chip key...it started and ran on a normal flat metal key...any ideas on how I should proceed?
  2. Feb 16, 2024 at 7:39 AM
    2006Tundra
    2006Tundra Financially Irresponsible
    Lou
    Long Beach, CA
    2006 Toyota Tundra Double Cab SR5, 4.7L V8
    Do you mean you lost your spare key? Go to your local dealer and have some made.
  3. Feb 16, 2024 at 7:46 AM
    1lowlife
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    Welcome to the forum.
    If you bought it new or where given all the original paperwork and stuff, there is a metal tab that shows your key code.
    As well the dealership could look it up as long as you have proof of ownership.
    I think it is also on the door lock.
    https://youtu.be/gPu5wHfoCWw?si=1HhMP5J5BEnmHO5W
    The Black Mamba and bulldog93 like this.
  4. Feb 16, 2024 at 8:36 AM
    w666
    w666 D. None of the above
    Maryland
    04 Access Cab SR5 V8 4WD
    Take your VIN, proof of ownership, and ID to the dealer...they can "cut to VIN" for like $25 or so
    bulldog93 likes this.
  5. Feb 16, 2024 at 8:44 AM
    jerryallday
    jerryallday New Member
    Jerry
    Pasadena, Ca
    2006 DC SR5 V8 Grey
    You do not need a chipped key. Locksmith can help you out. You can take the lock cylinder off off the tailgate and have them make you a key to avoid them traveling to you
  6. Feb 16, 2024 at 12:28 PM
    bfunke
    bfunke Tundra Curmudgeon
    Yup take registration or title to dealer and get key cut from VIN that will be cheapest and easiest. Get two spares and put one away somewhere.
  7. Feb 16, 2024 at 1:09 PM
    Dakillacore
    Georgia
    If you have one key and just need another one, I went to Home Depot and had one cut for my 06. It was pretty cheap.
  8. Feb 16, 2024 at 2:16 PM
    Some double cabs do actually use chipped keys. But we don't know what cab OP has.
  9. Feb 16, 2024 at 2:18 PM
    bfunke
    Bare metal key would point to no chip Shifty’
  10. Feb 16, 2024 at 2:34 PM
    Likely, but depends on OP's idea of "bare metal key". Are they saying the blade itself was bare metal? The whole thing waas bare metal? I try to avoid jumping to conclusions on stuff like that.
  11. Feb 16, 2024 at 2:40 PM
    bfunke
    Good point Shifty’
