Remove Diff Spacers and Tie Rod Replacement?
Discussion in 'Suspension' started by SCRunner12, Feb 16, 2024.
  1. Feb 16, 2024 at 2:34 PM
    SCRunner12
    SCRunner12 [OP] New Member
    Robert
    Santa Cruz, CA
    2015 SR5 Crewmax
    I just replaced my Fabtech budget 4" lift and put on Icon CO and UCA's. Should I remove the installed Fabtech 1/2" diff spacers or will it not make a difference? Never used diff spacers in my previous Toyota's for a 3" lift, but first time lifting a 2nd gen tundra so not sure if they are preferred.
    Also the install instructions say to remove 3/8" of the factory tie rod, now I'm worried I should replace those as well to return to factory spec.IMG_6256.png
