  1. Feb 13, 2024 at 6:05 PM
    #5611
    offshore2005
    offshore2005 New Member
    TEXAS
    2022 Tundra Limited 4x4 RC leveling kit and 295/65/20 Cooper STT PROs
    This was an extra I had back when I bought my 2018 tundra. I want to say it was off eBay.
  2. Feb 13, 2024 at 7:44 PM
    #5612
    ToyoMon
    ToyoMon New Member
    2022 White Tundra SR5
    Go Rhino Ceros (no drill roofrack)
    Solid no drill option for our trucks, feels extremely sturdy when installed. Took me 10-15 minutes to remove.
  3. Feb 14, 2024 at 3:40 PM
    #5613
    Dpoll995
    Dpoll995 New Member
    Houston TX
    2024 Tundra Limited
    Installed bed D rings and finished cargo board with bed liner added rod holders and installed window visors
  4. Feb 14, 2024 at 3:58 PM
    #5614
    PapaDave418
    PapaDave418 A Dude who knows a Dude
    Dave
    North Idaho
    3rd Gen Limited TRD
    37’s—PullKitchen--KB Voodoo Rack & Full Ext Cargo Tray
    Swapped out my stock battery for an X2 AGM group 27F. 92AH instead of 75AH. More reserve power for my fridge, lights and heater.
    8A485B77-4668-4A5B-BF6A-79F5965E03F7.jpg 4789C05C-FC68-4109-A6BD-924A2FBADA8D.jpg
  5. Feb 14, 2024 at 4:12 PM
    #5615
    DIYReid
    DIYReid New Member
    KC
    2024 Ice Cap Tundra Limited
    Where did you get the D Rings?
  6. Feb 14, 2024 at 4:17 PM
    #5616
    Dpoll995
    Dpoll995 New Member
    Houston TX
    2024 Tundra Limited
    Mr Rick and DIYReid[QUOTED] like this.
  7. Feb 14, 2024 at 5:56 PM
    #5617
    freaksavior
    freaksavior Did you call tech support
    Richmond, Tx
    '22 AG 1794
    Dechromed
    Rails from KBVoodoo showed up today.
    One of the bolt threads to mount the hardware was damaged but everything else went great.
    PapaDave418 likes this.
  8. Feb 14, 2024 at 8:28 PM
    #5618
    1bad2k
    1bad2k New Member
    TRD pro wheels and new falken at4w tires.
    scott's life, KClav, mikev25 and 4 others like this.
  9. Feb 15, 2024 at 8:23 AM
    #5619
    Clark_k3nt
    Clark_k3nt New Member
    2023 Tundra iforce Max Army green
    Never posted here before but just thought I’d share. Chrome delete almost done. Just want to get the rims powder coated in the next few months.
  10. Feb 15, 2024 at 9:15 AM
    #5620
    montera.built
    montera.built New Member
    Jordan
    2022 AG Toyota Tundra TRD Offroad
    I'm running a ton of lights hooked to my Garmin and will end up running a second Garmin in the bed for lighting I'm running in my camper. I also have a fridge that I'll eventually hook up, but for now I'm using a portable power source. Curious if you think this battery is enough for some light overlanding?
    Also, ever since I started wiring all of this to my battery, my start/stop at stop lights never works. I constantly get the "battery charging" message. If you've experienced this, has that battery upgrade helped?
    PapaDave418[QUOTED] likes this.
  11. Feb 15, 2024 at 11:05 AM
    #5621
    PapaDave418
    Dave
    North Idaho
    3rd Gen Limited TRD
    Yeah I ran the Group 31 version in my Tacoma for years to Death Valley/Mojave/Baja/Canada and it was solid. I’m a lazy camper and I want everything to be quick and fast so I didn’t want to store/haul/set up a power cube when the truck can power it. My stock battery wouldn’t activate the start/stop feature anymore either. Just this morning I sat for about 1.5 minutes at a light with the engine off. I don’t love the start/stop feature but I kinda forgot I had it till this morning when it worked again. The Group 27F has 22% more reserve than the stock flooded acid battery.
    montera.built[QUOTED] likes this.
  12. Feb 15, 2024 at 11:17 AM
    #5622
    montera.built
    Jordan
    Good to know! Might go this route since I have portable power for my fridge when we use it. Hell of a lot cheaper than a dual battery setup.
    I'm assuming this is a drop in replacement and fits fine?
  13. Feb 15, 2024 at 1:58 PM
    #5623
    mrcarey
    mrcarey New Member
    Love this setup. What rack and what retractable cover is that? Retrax?
  14. Feb 15, 2024 at 2:02 PM
    #5624
    MtWhitney
    MtWhitney New Member
    '23 4WD Limited Dbl long bed
    I really like what Bulletpoint has, how was the mount, I read that you have to drill holes and mount with screws, how did that go? Not sure I could get a drill in there just right with windshield. If this were mounted and then not wanted in place later, would that little rubber mat that came in the slot cover up the holes? I have a hard time with commitments ;)
  15. Feb 15, 2024 at 3:28 PM
    #5625
    sandiegosteve
    sandiegosteve New Member
    San Diego
    24 Limited TDR Lunar Rock
    I like the D-rings and the rod holder location. I just cut and old 2x8 for a divider. Rod storage is on my list to figure out. Unfortunately, many of my rods are 8-9' long and that gets a little high for overpasses.
  16. Feb 15, 2024 at 4:00 PM
    #5626
    Dpoll995
    Dpoll995 New Member
    Houston TX
    2024 Tundra Limited
    lol my rod holders are there just for when I need to tie lures or if I’m just driving down the beach. I wouldn’t go very fast with my rods on that 1x8. My bed cover will be here soon so my rods will ride under the cover while traveling
    sandiegosteve[QUOTED] likes this.
  17. Feb 15, 2024 at 4:13 PM
    #5627
    PapaDave418
    Dave
    North Idaho
    3rd Gen Limited TRD
    My build thread addresses it, 94R is a direct replacement and the 27F I purchased required a little persuasion of the center strap
  18. Feb 15, 2024 at 4:14 PM
    #5628
    Jalzate44
    Jalzate44 New Member
    San Antonio TX
    2024 Tundra SR5 Crewmax 4x4
    the tray pops out and then you drill it. Took about 10 mins to set up. Year the Mat would cover the holes. It’s 5 small holes
    MtWhitney[QUOTED] likes this.
  19. Feb 15, 2024 at 4:27 PM
    #5629
    freaksavior
    Richmond, Tx
    '22 AG 1794
    Dechromed
  20. Feb 16, 2024 at 1:36 PM
    #5630
    Goobax
    Goobax New Member
    2024 SR5 4x4 Tundra
    Swapped over my non-heated SR5 steering wheel to a heated one from I believe a platinum (blue stitching). Also swapped over the matte grey trim from my truck as the platinum is more gloss silver. Was working on adding the door panel strip LEDs but got sent one of the door lights that was in the wrong box so ended up with two driver fronts instead of all 4 corners.
    gives me time to do the radio upgrade while I’m in there at least.
  21. Feb 16, 2024 at 2:10 PM
    #5631
    Dpoll995
    Dpoll995 New Member
    Houston TX
    2024 Tundra Limited
    Added the black console cover and console tray. I also modified the tray with a small cup holder to hole my vape. Also installed cup grips.
  22. Feb 16, 2024 at 2:28 PM
    #5632
    freaksavior
    Richmond, Tx
    '22 AG 1794
    Dechromed
    Rci sliders installed. Might be overkill but I do hope to one day take advantage of their full capabilities
    Riverfisher, Acey and PapaDave418 like this.
  23. Feb 16, 2024 at 4:04 PM
    #5633
    scott's life
    scott's life New Member
    I always store the toyota mats and buy MaxPider mats
  24. Feb 16, 2024 at 4:14 PM
    #5634
    PapaDave418
    Dave
    North Idaho
    3rd Gen Limited TRD
    Looks awesome! 0 degree angle? How was bolting it on?
    If you don’t want to post here you can DM, but I’m interested in the gap between the rear wheel and the rear of the slider, and the gap from the front wheel to the slider. I want to see how much of the rocker is vulnerable to a rock if you’re able to take photos of it
  25. Feb 16, 2024 at 6:04 PM
    #5635
    CAPT_Squatchy86
    CAPT_Squatchy86 New Member
    2024 TRD ORCM Lunar Rock
    I really want a platform style roof rack, but I am not okay with having holes drilled in my roof. Even by professionals. Good to know that people are starting to make something like this now. You're a lifesaver!
    ToyoMon[QUOTED] likes this.
  26. Feb 16, 2024 at 6:14 PM
    #5636
    freaksavior
    Richmond, Tx
    '22 AG 1794
    Dechromed
    They jut straight out so yes it should be 0.
    How was the bolt on? Honestly, the instructions were confusing for the driver side and the friend that helped me do this said the same thing. Read them twice and be sure you have someone help you.
    Quote me again or dm me if I don’t update you tomorrow but I’ll aim to get that for you tomorrow morning.
  27. Feb 16, 2024 at 7:53 PM
    #5637
    GutenWurst
    GutenWurst New Member
    Middle Tennessee
    '23 Army Green 1794 w/TRD
    Today I learned that the console box pocket was precisely designed to accomidate two North American Regulation sized hotdogs. That's why you buy a Tundra.
  28. Feb 17, 2024 at 1:18 PM
    #5638
    freaksavior
    Richmond, Tx
    '22 AG 1794
    Dechromed
    Covered the 4x4. Looks pretty good.
    photo_2024-02-17_15-15-13.jpg photo_2024-02-17_15-15-11.jpg photo_2024-02-17_15-15-12.jpg
    photo_2024-02-17_15-15-23.jpg photo_2024-02-17_15-15-15.jpg photo_2024-02-17_15-15-16.jpg photo_2024-02-17_15-15-17.jpg
    Hope that is what you were after.
    Acey, PapaDave418[QUOTED] and TundrX like this.
  29. Feb 17, 2024 at 2:21 PM
    #5639
    TundrX
    TundrX New Member
    Toan
    Sacramento, CA
    2024 Tundra Hybrid Platinum
    Finally got around to installing the Diode Dynamics grille light bar. Installed the TourTop tonneau cover awhile back and threw on the RTT I took from my old taco.
    Helo, Yaboy and earlwright239 like this.
  30. Feb 17, 2024 at 3:34 PM
    #5640
    Jordan611
    Jordan611 New Member
    Jordan
    2023 Army Green SR5
    Well despite getting sideswiped by an 18 wheeler last night I got my marker lights installed today. We were very fortunate to walk away safely and not sustain detrimental damage to the truck.IMG_3569.jpg
    TundrX, freaksavior and 4mm like this.
