2002 Tundra 4.7 Magnefine installation on automatic transmission line question
Discussion in '1st Gen Tundras (2000-2006)' started by Truckguy2023, Feb 15, 2024.
  1. Feb 15, 2024 at 5:50 PM
    Truckguy2023
    Truckguy2023 [OP] New Member
    2002 Toyota Tundra SR5 4.7 V8
    Thanks everybody for al the great info in the forum. Does anybody know of a guide / tutorial for installing a Magnefine inline automatic transmission fluid filter. TIA
  2. Feb 15, 2024 at 6:09 PM
    Mr.bee
    Mr.bee King Turdra
    '02 AC TRD
    My gimicky senses are tingling. I guess if i were installing one, i'd do it after the cooler, because a cooler will still cool fluid under more pressure, and if it slows fluid flow, the fluid would spend more time in the cooler.
    there are a couple of installation vids on youtube.
    Jack McCarthy likes this.
  3. Feb 15, 2024 at 6:17 PM
    The Black Mamba
    Snek
    DFW
    Black 00 SR5 AC 5VZ PreRunner
    Imma keep it stock
    Do you run all terrain tires?
    Jack McCarthy and bmf4069 like this.
  4. Feb 15, 2024 at 7:17 PM
    Truckguy2023
    A little backstory on why I want to install it. Truck with 295K miles driving great and hoping to give to my son when he gets his license in a year. Recently, first time ever I experienced some rough shifting. ATF was a little low, so I topped it off and seem to run better. I went ahead and did a 4qt drain and fill also. Fluid is red but dirty. Truck is running great now. Embarrassed to say I stripped the plug so I am replacing the pan and will also install new ATF filter. I am planning on doing drain and fills to refresh ATF over time. I heard great things about Magnefine inline filter and think it would be good to install before I do ATF work to keep circulating fluid clean.
    The instructions state for less than 5000miles install on cooler supply side. On more than 5000miles, install on cooler return line.
    455h0le_dachshund and Mr.bee like this.
  5. Feb 15, 2024 at 8:15 PM
    whodatschrome
    whodatschrome New Member
    North of North Plains, Oregon
    lots of dents
    I believe that Ford required using Magnefine filters on some of there replacement transmissions. If not, then the warranty would be void.
    I did installex Magnefine filters on my mother’s 2008 honda odyssey right after she bought it brand new from the dealer (on both the power steering and tranny). I cut one apart after about 100,000 miles. The filter media was fairly dark. There’s also a large magnet located inside of it. It’s just a plain old circular magnet, not a fancy rare high powered magnet though.
    Mr.bee[QUOTED] likes this.
  6. Feb 15, 2024 at 8:25 PM
    whodatschrome
    lots of dents
    I recently swapped a different (used) transmission into my 2004. Before i installed it, i removed both the pan and torque converter. I left them to completely drain at all sorts of angles for a few days. I was going to install a Magnefine on both the tranny and power steering, but i had the wrong size (too small of barbs) of filters on my shelf.
  7. Feb 16, 2024 at 4:59 AM
    Don’t be embarrassed about stripping the plug. You’re not the first on here and won’t be the last.
    similarly be careful with the transfer case when you drain/fill if you’re 4WD. You conveniently left that out of your truck info ;)
  8. Feb 16, 2024 at 5:32 AM
    Relentless. :rofl:
  9. Feb 16, 2024 at 5:41 AM
    bfunke
    bfunke Tundra Curmudgeon
    Be sure to apply PB blaster and maybe heat to the pan screws. Many people have snapped those.
    455h0le_dachshund likes this.
  10. Feb 16, 2024 at 6:05 AM
    Does the magnetite filter have a bypass function? What happens if it captures a large amount of debris, enough to occlude the filter. Does the transmission starve for oil now? Not convinced I would want an inline filter on my transmission, the pickup screen / filter is responsible for that function.
    The Black Mamba likes this.
  11. Feb 16, 2024 at 7:35 AM
    whodatschrome
    lots of dents
    Maybe there is maybe there isn’t, but don’t recollect seeing a bypass valve. Then again i didn’t specifically look for one. It was about 4 years ago that i cut my magnefine apart. There was enough filter media located inside of it that i think you’d be hard pressed to clog up. You’d stand a much greater chance on clogging up a standard issue engine oil filter.
    The transmission pick up screen will screen out bigger chunks, while a magnefine will filter out the tiny shtuff. My thought is if my transmission starts dropping out enough large enough chucks of itself to block the fluid flow to a magnefine filter, then i got much bigger issues to worry about.
    Ford rebranded magnefine filters as Motocraft filter to use in their vehicles. No doubt Furd did a fair amount of their own research before they used those filter.
    KNABORES[QUOTED] likes this.
  12. Feb 16, 2024 at 8:14 AM
  13. Feb 16, 2024 at 8:37 AM
    vtl
    vtl New Member
    Boston 'burbs
    2019 Red SR5 DC 4x4
    whodatschrome[QUOTED] likes this.
