2022 Tundra Suplemental Transmission Cooler?
Discussion in '3rd Gen Tundras (2022+)' started by Bustedandrusted, Sep 16, 2022.
  1. Sep 16, 2022 at 6:22 AM
    Bustedandrusted
    Bustedandrusted [OP] New Member
    After my recent experience with high temp alarm on my transmission under load on an incline I’m hoping for an additional cooler for the new 10 spd.
    The dealer tested the truck in the field and the temperature was hitting 225F quickly which is out of range from my understanding.
    Anyone seen a possible solution in the aftermarket?
    romanlegion likes this.
  2. Sep 16, 2022 at 6:27 AM
    pursuit2550
    pursuit2550 New Member
    You’re probably going to have to wait till someone gives a damn. The only reason the 2.5 gen have an aftermarket one is because a member here decided to do all the leg work and made a kit. Unless a 3 gen owner decides to do it, I am pretty sure no company will make one.
  3. Sep 16, 2022 at 6:30 AM
    Bustedandrusted
    Well it won’t be long before others have the same problem so I’ll be patient.
    Thanks for the background info.
    pursuit2550 likes this.
  4. Sep 16, 2022 at 6:47 AM
  5. Sep 16, 2022 at 7:05 AM
    Bustedandrusted
  6. Sep 16, 2022 at 8:42 AM
    Coasty
    Coasty New Member
    Pat
    Oregon
    2022 SRS Crew Max 6.5 4x4
    I'm hoping the issue you brought up with tranny temps under a load cause them to look at the software that controls the thermal bypass switch for the current tranny cooler and it will save all of us who tow a trailer or actually put a load in the truck. I'm holding out hope it's just another software update.
  7. Sep 16, 2022 at 8:48 AM
    I have one on my rock crawler. These are nice units.
  8. Sep 16, 2022 at 9:07 AM
    Bustedandrusted
    I hope so too. Toyota engineering is aware of the issue so hopefully they fix it quickly.
    The service manager felt this was the most likely culprit as well. A software update could patch the problem.
    However isn’t there software where this value could be configured? I’ve seen posts about editing parameters on these trucks before, but maybe that function is not cracked yet.
  9. Sep 16, 2022 at 9:37 AM
    pursuit2550
    I am not sure but if the cooling system is anything like the 2.5 gen then I don’t think an update will do much. You have to remember that the trans oil is being cooled by the engine radiator. Normal temp on it is around 190*. It’s also just a small tube inside the radiator. It’s hard for the oil to cool in such a small passage especially when the trans temps are 20-30* pass 190. Only way to absorb that much heat is a separate cooler. Toyota dropped the ball on this redesign when it came to the trans cooler. It was already proven that the 19-21 ran high temps when towing.
    Polo08816 likes this.
  10. Sep 16, 2022 at 10:44 AM
    Bustedandrusted
    Yeah I feel the same way. The cooler they designed is just not capable of keeping the temps down.
    In the meantime I’ll keep it in manual or 4Lo offroad.
    I’ve got a big trip to Colorado with my camper coming up and will monitor with my Scangauge 3.
  11. Sep 17, 2022 at 8:29 AM
    fordguy1470
    fordguy1470 Member-ish
    West Columbia, SC
    22 CM SR5
    Getting there
    I had the same thing happen when pulling my camper through the mountains in NC. It only came on for a few seconds and went away. I’m hoping a TSB comes out to adjust that thermal bypass switch.
  12. Sep 28, 2022 at 9:03 PM
    romanlegion
    romanlegion New Member
    Roman
    Katy, TX
    2022 Tundra SR5 TRD Off-Road Lunar Rock
  13. Sep 28, 2022 at 9:35 PM
    Tbrandt
    Tbrandt I read it on an internet forum, it must be true.
    Tristan
    Kansas City
    2021 SR5 DC TRD Off-Road
    Kenwood DMX907S + Maestro iDatalink RR2 Kenwood DRV-N520 dash cam Kicker Door Speakers TRD rear sway bar Firestone airbags + Daystar cradles Setrab oil cooler, OEM thermostat and hard lines Century High-C topper Bedrug Helmholtz resonator on stock exhaust Sound deadened + insulated cab Platinum 20s, hwy tires Viair 400P
    I bet the fan makes a huge difference at low speeds. I was eyeing the Setrab fan pack units the other day, but likely have no legitimate use for one since I’m all highway miles right now.
  14. Sep 29, 2022 at 5:25 AM
    aj350925
    aj350925 New Member
    What menu are you using to see trans temp?
    I tow 10k with my 22’, but have only towed in flat states with no elevation.
  15. Sep 29, 2022 at 6:03 AM
    Bustedandrusted
    There’s no way to see it on the dash, not that I’ve found. Just the alarm warning “pull over” message.
    Mattedfred likes this.
  16. Feb 14, 2024 at 6:51 PM
    PROTERRA
    PROTERRA @201.PRO
    Sal
    So Cal
    2024 Tundra TRD PRO
  17. Feb 14, 2024 at 7:21 PM
    jctmundra
    jctmundra New Member
    Northern VT
    '23 1794 Hybrid Stunning Mesquite/Cream
  18. Feb 14, 2024 at 7:33 PM
    PROTERRA
    PROTERRA @201.PRO
    Sal
    So Cal
    2024 Tundra TRD PRO
  19. Feb 14, 2024 at 7:50 PM
    jctmundra
    Northern VT
    Make sure you post what you end up with. Now that I can see actual temp I may be looking at cooler addition when towing 7K#.
    PROTERRA likes this.
  20. Feb 15, 2024 at 3:18 PM
    MaxPayne3
    MaxPayne3 New Member
    2024 Lunar Rock SR5 Crew Cab
    Just starting out but never will be done
    I own a transmission shop and I will tell you that 225 is definitely out of range. The transmission cooler that comes stock (PN- 329100C020) on these trucks is a joke! It's about the size of your fist and is bolted to the transmission. It's not like the typical old school cooler built into the radiator, although it still uses coolant. A lot of newer vehicles now have the transmission cooler built into the A/C condenser. There's not really going to be a "bolt on" solution. I will eventually be replacing my cooler with an aftermarket one as I live in AZ and we get summer temps over 115 degrees for extended periods of time (last year we went 35 plus days in a row over 115). The main issue with transmission coolers is that they will keep the same temperature as the coolant. If the engine overheats, the transmission overheats, and vice versa. A good operating temperature for a transmission is below 180 degrees. Heat is the biggest enemy to a transmission. Transmissions with 6 or more speeds are going to run hotter, especially a 10 speed. I'm surprised that Toyota is still using the WS ATF in these 10 speeds opposed to an Ultra Low Viscosity Fluid that the other OEM's are using in their 8 speeds and higher transmissions :facepalm: There's a couple of different ways you can add a separate cooler, but I always bypass the radiator because I like my transmissions to run cooler than the engine temperature. Luckily, there's A LOT of good real estate behind the grille to mount a cooler. Always use the plate and fin style, they are super efficient and work much better than the tube and fin style. Using a fan on the cooler is almost never necessary, unless you are pulling a heavy load and sitting in traffic for an extended period of time. I have an LS swapped El Camino with a heavily modified transmission and I run a B&M Super Cooler setup on it with a fan and that's all I use for my cooling. In the summer at 115 degrees sitting at a traffic light my transmission temperature doesn't exceed 180 degrees and the fan has only come on once or twice but that was at the drag strip. Once I get moving the transmission temp ranges in the 160s.
    Something that is 11x8 or 13x11 and is plate and fin should be plenty. You may have to buy some conversion fittings if you get a cooler plumbed with 1/2 NPT to hose barb. I generally convert everything to NPT fittings because transmission output pressures can get to 160-200 psi on the output side, and that's a lot for hose clamps (although OEM's often use clamps) and I don't want to take that kind of risk. You'd have to also cap off or put a pass through fitting on the coolant inlet outlet as well. It sounds like a lot, but it's really fairly simple if you are mechanically inclined.
  21. Feb 15, 2024 at 3:29 PM
    MaxPayne3
    The thermal bypass valves are not switches and are not computer controlled. They are a basic thermostat, with a spring and plunger. A few OEM's actually have issues with the thermal bypass valves sticking. The purpose is to bypass the cooling system whether it is done through the cooling system or the A/C condenser until the transmission gets up to "operating temperature". This helps in colder climates. However, the thermal bypass valves can get stuck and continue to bypass the cooling system all together which eventually becomes catastrophic for the transmission. GM is on their 3rd redesign of their thermal bypass valves, and Dodge hasn't even addressed theirs. If you really want to make sure your transmission runs cooler, you will need to replace the puny OEM cooler and use an aftermarket one.
    Tundrastruck91 likes this.
  22. Feb 15, 2024 at 3:31 PM
    MaxPayne3
    The thermal bypass is not really a switch, it's a thermostatic valve. It is controlled with a spring and plunger (just like the thermostat in your cooling system). They would have to come out with an updated or revised bypass valve in order to address any issues.
  23. Feb 15, 2024 at 3:36 PM
    MaxPayne3
    The fan is sort of overkill, depending on where the cooler is mounted. Those kits with the fan are designed to be mounted where there is little to no airflow, like in between frame rails under the vehicle or even in the bed (think of those Baja 500 rigs you see with the radiators mounted behind the rear window with fans on them). If you mount the cooler behind the grill you are going to get good airflow while moving, even at low speeds. I have a cooler with a fan on another vehicle mounted behind the grille and here in AZ even at 115 degrees out sitting in traffic or a red light, my fan never comes on because my trans temperature never gets over 180 to turn on the fan
  24. Feb 15, 2024 at 6:34 PM
    PROTERRA
    PROTERRA @201.PRO
    Sal
    So Cal
    2024 Tundra TRD PRO
    This is gold in terms of information.
    what’s your opinion on just adding a Derale remote fluid cooler with fan to solve the issue. Such as the following:
    https://www.summitracing.com/parts/der-13870?cm_mmc=ppc-google-_-search-_-brands-_-keyword
  25. Feb 16, 2024 at 4:31 AM
    xc_tc
    xc_tc New Member
    225 F is not outside of range, that’s slightly above nominal temp of 205 F. The limit is 265 F. That’s when the transmission temp gauge is in the red zone on the gauge if you have the digital cluster.
  26. Feb 16, 2024 at 4:39 AM
    grnwdjsn
    grnwdjsn New Member
    2023 Tundra Limited TRD Offroad
    I had the trans temp alarm come on when I was elk hunting in Colorado. I was running 4W Low through a long stretch of muddy ruts. I was in and out of high\low. It come on for just a short while and then went away. No trailer, just out hunting.
  27. Feb 16, 2024 at 7:13 AM
    MaxPayne3
    If you are planning on mounting the cooler underneath the truck where there's not a lot of airflow, then one with a fan is a must. If you are planning on mounting it behind the grille then a fan is not necessary, you'd be spending money on something that will likely never get used (fan). I use both Derale and Hayden, their stacked plate or plate and fin coolers are very efficient. Something like either of these:
    https://www.summitracing.com/parts/der-13614
    https://www.summitracing.com/parts/der-13402
  28. Feb 16, 2024 at 7:24 AM
    MaxPayne3
    Wrong, just because your gauge goes to red at 265 degrees doesn't mean you're ok, it means you're too late!! The ideal fluid temperature is under 185 degrees, as fluid ages it starts to break down and loses it's viscosity and detergents which affects its capacity to cool down the transmission. Each time transmission fluid is overheated it accelerates the breakdown of the fluid. At 220 degrees, varnish forms and seals start to harden. Anything higher fluid starts to burn, steel plates warp, clutch plates lose their frictions, parts in valve bodies stick.
  29. Feb 16, 2024 at 8:09 AM
    2WD
    2WD New Member
    21 Army Green CM SR5 TRD Off Road
    How is the user of post #3 able to pull this off?
    https://www.ford-trucks.com/forums/1740936-tranny-temp-and-stuff-overthinking-things.html
  30. Feb 16, 2024 at 8:29 AM
    MaxPayne3
    Lip service, I would call BS. I also do fleet work for Enterprise and Element Fleet and one of the most common 10 speeds we get right now from them are the Ford 10R80, 10R140 and the GM 10L series. One of the most common issues on the Ford 10 speeds is hot fluid venting out of the transmission amongst other internal issues. Just do a Google search for Ford 10 speed transmission issues and Ford 10 speed overheating issues and you will see. Not to mention several class action lawsuits. Funny thing is the Ford and GM 10 speeds are actually a collaboration design between Ford and GM.
    Tundrastruck91 and pursuit2550 like this.
