Smaller aftermarket antenna suggestions
Discussion in '1st Gen Tundras (2000-2006)' started by MrFeldman, Feb 14, 2024.
  1. Feb 14, 2024 at 1:48 PM
    MrFeldman
    MrFeldman [OP] New Member
    Mr
    ‘05 Tundra Limited Crew Cab
    Upgraded Stereo
    Anyone have any luck with an aftermarket antenna? I’m planning to remove the factory whip and replace it with a new smaller antenna. Suggestions are appreciated.
  2. Feb 14, 2024 at 1:51 PM
    jerryallday
    jerryallday New Member
    Jerry
    Pasadena, Ca
    2006 DC SR5 V8 Grey
  3. Feb 14, 2024 at 2:02 PM
    shifty` Oh, I have felt Cobain's sarcoma
    I've heard nothing but shit things about the shorty/stubby antennas in the 1st gens. Horrible reception, bad idea, yadda yadda.
  4. Feb 14, 2024 at 2:40 PM
    FishNinja
    FishNinja HIDE YOUR DAUGHTERS
    Lee
    TEXAN....big surprise
    06DC2wd
    Be-fucking-careful. First gen antennas like to go *snappy snap*
    ask me how I know.
    The Black Mamba and VR6T like this.
  5. Feb 14, 2024 at 2:55 PM
    MrFeldman
    Mr
    Upgraded Stereo
    Thanks for the reply’s. I’ll save my money and stick with the original antenna, a quick Amazon search of reviews echos what you all experienced.
  6. Feb 14, 2024 at 3:22 PM
    HBTundra
    HBTundra New Member
    2006 DC 2wd
    Pretty sure I've got the same one off scamazon as listed above.
    If I've lost any reception, it's not much.
    I do live where there is plenty of signal, so there's that.
    But when I do go out of town, I lose reception just about the same area as I did with the factory whip-stick.
    Maybe there's crappy imposter copies IDK, but I do listen to am /fm a lot, and if the thing was garbage, it'd be in the trash.
    https://www.antennamastsrus.com/
  7. Feb 14, 2024 at 4:29 PM
    ATBAV8
    ATBAV8 New Member
    Tempe, AZ
    You need one of the 50 cal "brotennas".
  8. Feb 14, 2024 at 5:12 PM
    VR6T
    Texan.... Big suprise
    00 Tundra Limited 2WD AC
    How do you know?
    Dirt Ferguson likes this.
  9. Feb 14, 2024 at 6:40 PM
    The Black Mamba
    BlackSnek
    Flower Mound, TX
    Black 00 SR5 AC 5VZ PreRunner
    Imma keep it stock
    A whip antenna attached to the front of the brush guard because the OEM was deleted due to a snorkel install brings in better than factory reception :cool:
    VR6T likes this.
  10. Feb 14, 2024 at 6:41 PM
    The Black Mamba
    BlackSnek
    Flower Mound, TX
    Imma keep it stock
    To echo this, the antenna base and that chrome ring are discontinued and highly saw after because they are prone to crumble. If you ever decide to take yours off, don’t ever throw it away
    VR6T[QUOTED] likes this.
  11. Feb 14, 2024 at 7:20 PM
    I really need to dig back into whether a Sequoia power antenna will fit into an AC fender or not. I’d love to have power antenna. I never listen to the radio and the antenna smacks every damn thing. Leave the garage? Smack. Enter my parking deck at work? Smack the bar on the way in, smack the roof at each floor, smack the roof crossing from the upside to the downside, it’s aggravating.
    But I’d like to keep my antenna intact, just to stay tucked away unless the radio is on.
  12. Feb 14, 2024 at 7:33 PM
    Ponderosa_Pine
    Ponderosa_Pine
    Northwest
    I just removed my antenna (unscrewed) and put in the rear cab storage (2017 model). Then put a small bolt with the same thread pattern in the hole. The reception wasn’t great obviously but of needed you just switch, since 99% of the time don’t use the radio. Costs 0.50$ and is easy to undo if you don’t like it.
  13. Feb 14, 2024 at 7:33 PM
    FishNinja
    Lee
    06DC2wd
    mine go snappy snap
    VR6T[QUOTED] and The Black Mamba like this.
  14. Feb 15, 2024 at 2:57 AM
    artsr2002
    artsr2002 2005 Tundra DC SR5
    'Yonder
    I put one of these on my Ferd. I don't use FM radio. Just use my phone with Android Auto so didn't care for weaker reception.
    Antenna Mast for Ford F150 (2009-2024) • Highly Durable Premium Truck Antenna 6 3/4 Inch • Car Wash-Proof Radio Antenna for FM AM • Black • Automotive Antenna Replacement for Cars • F-150 Accessories https://www.amazon.com/dp/B06XZC6SS7
  15. Feb 15, 2024 at 7:25 AM
    kentuckyMarksman
    kentuckyMarksman New Member
    All I know is the previous owner of my truck had an "internal antenna" box behind the passenger side sun shade and said there was a break in the antenna line. Haven't gotten to look into fixing that yet, reception is crap on the aftermarket one.
  16. Feb 17, 2024 at 7:40 AM
    Weagle
    Weagle I survived my timing belt change
    Prattville, AL
    2006 Tundra SR5 DC 4.7 2WD LSD towing pkg
    Bilstein 5100's with 2883's - close to 2" Replacing the 2883's and going back to the bottom perch ASAP -mobile/apple play stereo with sub and backup cam -Power stop HD front calipers and rotors for towing -20" wheels with 32" tires (305/50's) Toyo AT 3's with no rubbing -Westin nerf bars -Detroit axle new (not rebuilt) steering rack with poly bushings, inner and outer TRE's -Suspension Maxx extended front sway bar links -Overland tuning - medium level -Power front leather seats and steering wheel from 06 Sequoia -fully de-chromed/blacked out trim -all light housings incl 3rd brake light and tag lights replaced with smoked lenses, LED where appropriate -mini projector headlights -fully rebuilt trans and new torque converter -new complete drive shaft with spicer u-joints and carrier bearing -all LED interior lights including backlighting -new lower window seals for all 4 doors -all new hardware and clips for tailgate Next: Dirty Deeds racing exhaust with LT headers, yellow box, 12 hole DD fuel injectors, redo or replace door panels
    I'm pretty sure it depends on the brand.
    I put a small black Bosch antenna on my Mustang back in the early 80s. I guess they were some of the very first ones. I know I was expecting improved reception based on their marketing, but it turned out to just be equal - still looked much better
    MrFeldman[OP] likes this.
