  1. Feb 14, 2024 at 6:29 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    So they're LEDs and projectors?
    Colights?
    KNABORES likes this.
  2. Feb 14, 2024 at 6:31 PM
  3. Feb 14, 2024 at 6:35 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
  4. Feb 14, 2024 at 6:37 PM
    The Black Mamba
    BlackSnek
    Flower Mound, TX
    Black 00 SR5 AC 5VZ PreRunner
    Imma keep it stock
    BroHon, txagg, bmf4069 and 4 others like this.
  5. Feb 14, 2024 at 6:41 PM
    I mentioned here a few times that my last set of Bosch wiper blades lasted over 6 years. They were on the truck when I bought it in 2016 and I replaced them January 2022. So I actually don't know how much older they are. They are expensive but well worth it. My current set is now is 2 years old and working fine.
  6. Feb 14, 2024 at 6:44 PM
    The Black Mamba
    BlackSnek
    Flower Mound, TX
    Imma keep it stock
    $60 for blades that go 6 years. You can’t buy any pair for $10 a year. Essentially, BOSCH is cheaper
  7. Feb 14, 2024 at 7:07 PM
    VR6T
    Texan.... Big suprise
    00 Tundra Limited 2WD AC
    Bosh Icons came or come standsrd on VWs. Them RainX wipers ised to be really good now theyre trash. Last 3 sets I had wore out inside a year. Went back to Bosh for all my cars.
    notlikejohnny likes this.
  8. Feb 14, 2024 at 7:22 PM
    KTM_AJ421
    KTM_AJ421 New Member
    AJ
    2006 SR5 DC 2WD 4.7
    Alright guys looking at these wheels. A few issues I have is they are 16x7 and a bit expensive. Hoping to talk him down a bit. Going on a 2006 dc 2wd but worried that they have too much off set and don’t really want spacers. What do you think?
  9. Feb 14, 2024 at 7:24 PM
    The Black Mamba
    BlackSnek
    Flower Mound, TX
    Imma keep it stock
    Did your DC come with the 16s or the 17s? What’s the offset of the taco wheel? This info will help you decide if you need spacers or not.
    metalpete likes this.
  10. Feb 14, 2024 at 7:27 PM
    Another Bosch user here. All of their “beam” style blades are great. I have Icons, I believe, on the truck and Highlander. They do last for damn ever.
    I redo’s them to PHM back in the day. I don’t think he was impressed but maybe I misunderstood. I think they’re the best wiper blade I’ve ever used.
  11. Feb 14, 2024 at 8:51 PM
    ToyotaDude
    ToyotaDude Member
    2003 Tundra AC V8 4x4
    sir txagg scouted the pink dragon thou has slain with sir metalpete's sword
  12. Feb 14, 2024 at 9:26 PM
    KTM_AJ421
    AJ
    2006 SR5 DC 2WD 4.7
    my DC has 16” stock wheels I’m not sure what was stock or if these were stock they are mentioned as stock tundra wheels on google
  13. Feb 15, 2024 at 4:39 AM
    bmf4069 Captain wtf
    Ordered some parts.
    New clear headlights
    New foglights
    Rear window pins(again)
    A rear breather to finish the mod
    More HVAC knobs as fine keep falling off the fan speed one
    A tire deflator kit
    A new 3k watt sub amp
    @daveeasa is gonna sell me a new mids/highs amp
  14. Feb 15, 2024 at 6:33 AM
    artsr2002
    artsr2002 2005 Tundra DC SR5
    'Yonder
    On those HVAC knobs, the small metal U clip inside is what keeps them on nice and tight. Make sure you haven't lost those little buggers.
  15. Feb 15, 2024 at 6:34 AM
    The plastic splits on mine and then the tab can’t hold pressure any longer. I’ve replaced 2 of them already
  16. Feb 15, 2024 at 6:35 AM
    The Black Mamba
    BlackSnek
    Flower Mound, TX
    Imma keep it stock
    I bought several a few years back and keep them in the glove box as spares.
    455h0le_dachshund likes this.
  17. Feb 15, 2024 at 9:02 AM
    Dakillacore
    Georgia
    Went ahead and put in the order to get my belt squeak TSB taken care of. Parts should be in tomorrow. I'm replacing the belt as well, better safe than sorry. I attached a PDF of the actual TSB if anyone needs it.
    Tensioner Assembly, V-Ribbed belt: Part# 16620-0W100
    Mount Bracket: Part# 88431-0C012
    Serpentine Belt: Part# 90916-02791
    txagg and The Black Mamba like this.
  18. Feb 15, 2024 at 9:45 AM
    BroHon
    BroHon Bitch in the Mitten
    Bro
    2000 SR5 AC 4x4 4.7
    Sketchy street barnacle
    :rofl::rofl::rofl: Video, or it didn't happen right?
  19. Feb 15, 2024 at 9:48 AM
    BroHon
    Bro
    2000 SR5 AC 4x4 4.7
    I've had great luck with Napa beams, but I treat them with aerospace 303 a couple times a year. Well, and the fact that I can get them for around $9 apiece helps.
    NUDRAT and 455h0le_dachshund like this.
  20. Feb 15, 2024 at 9:59 AM
    Dakillacore
    Georgia
    I just go with OEM Toyota wipers. I use the Rain-X washer fluid and it makes it to where I barely need to use my wipers anyway. I highly suggest using the Rain-X washer fluid.
  21. Feb 15, 2024 at 10:23 AM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    They didn't tase me today either. Maybe tomorrow...
  22. Feb 15, 2024 at 10:27 AM
    metalpete
    metalpete New Member
    ID
    2001 Tundra 4.7 4x4 SR5
    Toytech 2.0 Coilovers Camburg UCA's JBA headers Dynomax cat-back exhaust 90-221HD Leafs
    Interesting. I didn't know those models had a ribbed pully.
    Is the removal process similar to the earlier V8? As in, a rite of passage that all shade tree mechanics must take on their way to enlightenment? Come back with your shield, or on it.
    jerryallday likes this.
  23. Feb 15, 2024 at 10:33 AM
    BroHon
    Bro
    2000 SR5 AC 4x4 4.7
  24. Feb 15, 2024 at 10:46 AM
    Dakillacore
    Georgia
    The TSB says that this process is similar for all models 00-06. It also says that it's "An improved accessory drive belt tensioner". It's probably a newer design. I will try to remember to get pics of the two parts for comparison.
    metalpete[QUOTED] and VR6T like this.
  25. Feb 15, 2024 at 11:54 AM
    jerryallday
    jerryallday New Member
    Jerry
    Pasadena, Ca
    2006 DC SR5 V8 Grey
    The part Toyota sold me Feb 2022 was 16620-0W101. The tension on the old one was awful, fixed my issue of cold start squeaking
    Part Number
    16620-0W101 Tensioner Assembly, V-Ribbed Belt $90.09
  26. Feb 15, 2024 at 11:54 AM
    metalpete
    ID
    Never mind, it's just part of the description. The pulley itself is unchanged. My bad.[​IMG]
    I bought a gates or ac Delco when I replaced my assembly. Though, my reason for replacing was not because of any squealing. Maybe the enhanced design actually lets you get a belt on that fucker without the use of a flathead screwdriver and 1000 hail Mary's!
  27. Feb 15, 2024 at 12:27 PM
    Drove it as far as the optician today (20 miles out) and thought I saw gas dropping from the gas tank. :eek2:
    Cancelled my plans to take the folks out to Johnny Macaroni’s as I don’t want to endanger them. When I got home, I couldn’t find any leaks so it was probably water dripping through the bed holes combined with the smell of gas whenever I fill up. Will keep my eyes peeled to see if it leaks again.
    Just some bad mojo today. :oops:
  28. Feb 15, 2024 at 1:39 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    Do we need to start posting clean FGT adds from the South/South West to temp you to fly down and grab a clean one again?
  29. Feb 15, 2024 at 1:52 PM
    Can’t fly. Needs to be in driving distance.
  30. Feb 15, 2024 at 2:27 PM
    What up? Get up, sit up, you get lit up. A knife in his neck made of polar bear spit up
    VR6T likes this.
