Ect sencer location?
Discussion in '1st Gen Tundras (2000-2006)' started by Iamtrawk, Feb 14, 2024.
  1. Feb 14, 2024 at 4:25 PM
    Iamtrawk
    Iamtrawk [OP] New Member
    Trenton
    2000 toyota tundra sr5
    Hello I have a code on 2000 toyota tundra po115 for ect sencer. Does any one have a picture of were this sencer is located tha k you
  2. Feb 14, 2024 at 4:59 PM
    bfunke
    bfunke Tundra Curmudgeon
    Search is your friend on this site
  3. Feb 14, 2024 at 5:13 PM
    Worth noting, both of those are coolant sensors. The green one is for the ECU. The grey/black one is for the gauge cluster. I believe the code is tied to the green one either being unhooked or faulty.
    @Iamtrawk this is one of those parts where you really want to stick with Denso brand. Don't use any old sensor they carry at the local auto parts store. And DO NOT order it on scAmazon or fleaBay. You'll likely get a fake. Order from Summit Racing, Rock Auto, or similar reputable place.
  4. Feb 14, 2024 at 5:19 PM
    bfunke
    We should make a rule to post anything in the best gen section one has to read Shifty’s sticky and first use the search function
  5. Feb 14, 2024 at 6:47 PM
    The Black Mamba
    Snek
    DFW
    Black 00 SR5 AC 5VZ PreRunner
    Imma keep it stock
    Iamtrawk[OP] and FrenchToasty like this.
