Complete COLight Mini Upgrade
Discussion in 'General Sequoia Discussion' started by VR6T, Feb 14, 2024.
  1. Feb 14, 2024 at 4:40 PM
    VR6T
    VR6T [OP] In fealty to the God-Emperor I serve the Imperium
    Texan.... Big suprise
    00 Tundra Limited 2WD AC
    If you're looking at updating your night time visual presence and ability to see I did this Tuesday, 02/13/24. Below you will find the link, 2 videos and my first hand pictures of the mod process.
    CO LIGHT Anti-glare 9003/H4 LED... https://www.amazon.com/dp/B0CN72DSBT?ref=ppx_pop_mob_ap_share
    https://youtu.be/vDi-fIp0jkw?si=spFaTUyeliPW7MkY
    https://youtu.be/5QAYWycrOyU?si=RvJ7SSnP50Ua6bsz
    Step 1 tear out you brand new refractor housing from your headlight, should look like this.
    Step 2, remount spring and break your latching lug (optional, not reccomended)
    Step 2a. (Optional) Using a hole saw drill bit and a step bit, cut you out big circle of plastic, step out the center hole to 3/4". Cut in half, drill pilot holes with small drill bit. Install the now "better" retention lock. (Also not reccomended if you dont finger fuck your housings up.)
    Step 3 Install blub into housing secure in place
    Step 4 Install vented rubber housing cover
    Step 5 Thread back on the heat sink over the rubber boot. Optional, trim rubber boot to fit over heat sink for easier access in the future. Not mandatory.
    Step 6 reconnect/ pin together voltage/ relay box
    Step 7 Thread on pin connector/ weather nut to seal the power connection.
    Step 8 Install and enjoy. I mean blind everyone, I mean calibrate
    Well I am a fan. And not such a bad job on the sketchy day time alignment.
    Building is about 100 110 feet away from me.
    Lows
    Highs
  2. Feb 14, 2024 at 4:49 PM
    These look good too, can’t decide if these look better than your others.
