Stupid Grease Gun Question
Discussion in '2nd Gen Tundras (2007-2013)' started by myt1, Feb 6, 2024.
  1. Feb 6, 2024 at 4:40 AM
    myt1
    myt1 [OP] New Member
    Richard
    Scottsdale, AZ
    2010 Tundra DC TRD SR5 Desert Sand Mica
    OME Lift, 275/70R 18
    I recently installed JBA upper control arms. Surprisingly, it went pretty well.
    The biggest problem I'm having is adding grease to the zerk fittings.
    More grease squirts out of the fittings than actually goes into the bushings and joint. Although I was eventually able to get it done, it was a huge mess.
    I contacted JBA, great customer service, and they thought I might have a 7mm fitting on my gun and not a 1/4" fitting.
    Does anyone else have this problem?
    I would love to know what brand grease gun most of you are using.
    I thought I bought I nice grease gun on Amazon, but I can't see where it is labeled either as a 7mm or 1/4 inch.
    I can't believe this is the hardest part of the install.
    Thanks so much.
  2. Feb 6, 2024 at 5:06 AM
    Doxiedad
    Doxiedad Distinguished Member
    James
    Charleston, SC
    2020 Tundra SR5 TRD Off Road Cavalry Blue
    C.I., NOEYEZ and KNABORES like this.
  3. Feb 6, 2024 at 6:15 AM
    Occasionally I have to loosen a new zerk a 1/4 turn to get it to take grease. No idea why.
    myt1[OP] likes this.
  4. Feb 14, 2024 at 5:23 AM
    myt1
    Richard
    Scottsdale, AZ
    I ended up taking the fitting off my older cheap grease gun that I use to lubricate my drive shaft and put it on my new, more expensive, grease gun.
    The older fitting seemed to work fine, go figure.
    Thanks for the help.
  5. Feb 14, 2024 at 8:23 AM
    C.I.
    C.I. Surf, off road, sleep, repeat
    Cesar Pedrin
    Cabo, Mx
    2016 5.7 4x4 Bronze Crewmax
    Mods: Ongoing... probably never ending
    Doxiedad[QUOTED] and myt1[OP] like this.
