Kings suspension question
Discussion in 'Suspension' started by lowrider2000, Feb 12, 2024.
  1. Feb 12, 2024 at 2:38 PM
    lowrider2000
    lowrider2000 [OP] New Member
    I'm looking at upgrading to the 2.5 Kings adjustable coilovers and shocks, 2016 double cab. I was wondering if it's a bad idea to get adjustable ones for only the front. Doing both front coilovers and rear shocks adjustable is 3800+ and is gonna be too much for me. I could manage front adjustable and rear standard, though. Would the rear shocks benefit more from being able to change compression settings?
  2. Feb 12, 2024 at 2:44 PM
    b6graham
    b6graham New Member
    2020 Voodoo 1794 RW Wheels 315/70
    AccuTune Offroad and reywcms like this.
  3. Feb 12, 2024 at 3:17 PM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    2017 Tundra Platnium
    Too many mods to come
    I would ask how do you use the truck? Are using it heavily offroad etc?
  4. Feb 13, 2024 at 6:39 AM
    pursuit2550
    pursuit2550 New Member
    I ordered Fox 2.5 Performance Elite DSC Front and Rear for $2900. They are dual adjustment. Kings are single adjustment. The ones I got where the 2" max lift. They make a 3" but needs UCA.
  5. Feb 13, 2024 at 10:51 AM
    AccuTune Offroad
    AccuTune Offroad New Member Vendor
    El Cajon, CA
    Good question. I would almost steer you in the reverse direction. Getting adjusters for the rear only vs front if you had to pick one. Adjusters can be a great way to compensate for added weight. If you load up with a lot of gear and go off-road, towing etc those would be good scenarios to make compression changes. However, if you do not see yourself making adjustments, its not essential to have them just an added value/feature. Just keep in mind its very very $$$ to add them later.
    The new style Kings are pretty slick. Not sure if you were aware the new style comes with finned reservoirs now:
    https://accutuneoffroad.com/product/kit-07-21-tundra-king-2-5-shocks-0-3-lift/
    reywcms likes this.
  6. Feb 13, 2024 at 10:56 AM
    WinterWarlock21
    WinterWarlock21 New Member
    South Jersey
    2016 Quicksand TRD Pro CrewMax
    https://gearproject.co/profile/SandShark21
    do you happen to sell king 3.0's as well? didnt see them on your website. Thank you!
  7. Feb 13, 2024 at 10:57 AM
    AccuTune Offroad
    El Cajon, CA
    no need to hijack. I will send you a PM
  8. Feb 14, 2024 at 8:16 AM
    lowrider2000
    Thanks for the input- ended up finding a good deal on front and rear adjustable.
