  1. Feb 13, 2024 at 10:06 AM
    rock climber
    rock climber New Member
    2001 Sequoia 4X4, 2000 AC 4X4
    Does anyone know if the grease "boot" on the slip yoke is replaceable? I looked all over the parts site and don't see a part number for it.
  2. Feb 13, 2024 at 10:14 AM
    I think the seal is not replaceable. Mine has been leaking for years. I regrease and it throws it back out over time. It’s my corrosion prevention strategy.
  3. Feb 13, 2024 at 11:06 AM
    VR6T
    Texan.... Big suprise
    00 Tundra Limited 2WD AC
    Here's the cut off line.
    Before anyone says it; yes, its as close to level as I can get it currently. I need an 00 to 04 subframe for the front as sone one did an 05/6 conversion shittaly.
    I'll do a night time photo when i get home at 1230
  4. Feb 13, 2024 at 11:31 AM
    FishNinja
    FishNinja HIDE YOUR DAUGHTERS
    Lee
    TEXAN....big surprise
    06DC2wd
    Impressive for it being in broad daylight. You’re gonna be fucking up some Retinas until you can get them lower lol
  5. Feb 13, 2024 at 11:47 AM
    VR6T
    I'd feel bad but the amount of people who drive with their high beams on, im over it already.
    NUDRAT likes this.
  6. Feb 13, 2024 at 11:50 AM
    metalpete
    metalpete New Member
    ID
    2001 Tundra 4.7 4x4 SR5
    Toytech 2.0 Coilovers Camburg UCA's JBA headers Dynomax cat-back exhaust 90-221HD Leafs
    Same. It's more like a weep hole.
    "if there ain't grease on my gas tank, their ain't grease in the slip yoke"
  7. Feb 13, 2024 at 12:21 PM
    The Black Mamba
    DFW
    Black 00 SR5 AC 5VZ PreRunner
    Imma keep it stock
    That's how I look at my oil leaks. If there ain't no oil coming out of it, there ain't no oil in it.
    BroHon, VR6T, Jack McCarthy and 2 others like this.
  8. Feb 13, 2024 at 1:05 PM
    Maybe you can plug it? Something with a small neck and flared base?
  9. Feb 13, 2024 at 1:44 PM
    FishNinja
    Lee
    06DC2wd
    I would suggest silicone, not glass
  10. Feb 13, 2024 at 1:51 PM
    metalpete
    ID
    Now that would probably make someone's hole weep, indeed.
    bmf4069, VR6T and shifty`[QUOTED] like this.
  11. Feb 13, 2024 at 2:36 PM
    notlikejohnny
    notlikejohnny New Member
    Shenandoah Valley, VA
    2005 4WD DC Limited, Phantom Grey
    Been awhile since I've commented (like 2 years?)
    Took the truck in this morning for its now annual rust treatment/coating. After leaving heard some clunks happening in the front end at slow speed turns. Didn't happen this morning on the way in. Figured it was caused from the coil overs getting coated and sticking or popping in the cup. Let the shop owner know and he said since its lanolin based, it should actually quiet down suspension parts and not cause resistance anywhere. Can't replicate it regularly, did donuts in the parking lot, seems to be driver side only, and only a single clunk like something is popping into or out of position.
    As a part of diving into it, I now am paranoid I need to replace the LBJ bolts from when I installed new LBJs and reused the bolts. Anyone confirm the part number and torque for a 2005?
    Also after climbing under the truck to look around, found the transmission side CV boot on the passenger side is completely torn at the clamp, and the driver side is cracking. So I wonder if it is the CVs starting to click and pop. Going to get in there and finally install the high angle boots I bought a year ago and repack them. Also looks like the LCA bushings are cracking pretty pad. So down the clunk path I go.
    On the list this week is oil/filter change, lubing the drive shaft and UCAs, power steering drain/fill, wipers, and going to try the camry door check modification on the rear passenger door.
    bmf4069, txagg, oscardog86 and 4 others like this.
  12. Feb 13, 2024 at 4:50 PM
    metalpete
    ID
    Ah yes, I am familiar with the mysterious, "front end clunk". Tis a pink dragon, my friend. One must chase it, but ye will never catch it.
    The pop when turning could definitely be a cv, especially if you've lost a lot of grease. How old are the lbjs do you reckon? New parts rarely hurt...well, just your wallet, anyway.
    https://www.toyotapartsdeal.com/oem/toyota~bolt~for~front~lower~ball~joint~rh~90105-12316.html
    I think this is the lbj bolt for your year. Not sure on the torque spec though...sorry, reread your post and you're just worried about the bolts, not the lbj itself.
  13. Feb 13, 2024 at 4:56 PM
    VR6T
    This is how we should all still talk
  14. Feb 13, 2024 at 4:57 PM
    We all did one day here. Shenanigans were afoot that day.
    bmf4069, Tundra2, oscardog86 and 4 others like this.
  15. Feb 13, 2024 at 5:00 PM
    VR6T
    Im a big fan of the Shenanigans
  16. Feb 13, 2024 at 5:01 PM
  17. Feb 13, 2024 at 5:16 PM
    notlikejohnny
    Yea they are about 2 years old. Got them from Roman at Cool Springs. Just tracked down my old receipt to confirm if I added the bolts to the order and surely I did not. Thanks for that link, I'll just add them to my already growing order and try and confirm torque specs.
    When I added the OME lift and diff drop (also about 2 years ago) they flung grease pretty much immediately. I pulled them back and repacked the best I could from under the truck and replaced the clamps. Haven't seen any since then. On the torn one I found today I pulled it back and it still has alot of grease in there. Just hoping they aren't done for. Also caught up on toyota discontinuing the reman CVs and that really bums me out and increases my cost if I do have to replace the whole assy.
    Any good tips on how to tell if they are toast when I pull them out? Just lots of slop and play?
    oscardog86 and metalpete[QUOTED] like this.
  18. Feb 13, 2024 at 5:18 PM
    VR6T
    Well I am a fan. And not such a bad job on the sketchy alignment.
    Building is about 100 110 feet away from me.0213241908a.jpg 0213241908b.jpg 0213241908c.jpg
  19. Feb 13, 2024 at 5:33 PM
    bfunke
    bfunke Tundra Curmudgeon
    That would be years of service left on my truck
    oscardog86, BroHon and VR6T[QUOTED] like this.
  20. Feb 13, 2024 at 5:37 PM
    VR6T
    It should be in mine as well, but someone's 400 hp daily decided it "needs" a so called "new clutch" and a watwr punp. And at 1600 for the clutch and 400 for the pump, well tundra had to nut up for daily shit. Lol
  21. Feb 13, 2024 at 6:08 PM
    metalpete
    ID
    VR6T likes this.
  22. Feb 13, 2024 at 6:26 PM
    metalpete
    ID
    Yeah the loss of remans really sucks. Clicking and popping have always been the tell for me, at least that it's time to prepare for a replacement, anyway. Excess vibration can be a symptom if it's the inner joint.
    I ended up taking my diff drop out. Seemed like whatever "help" it was giving the axles, came at the cost of the angle of the front driveline. It was growling at me pretty quickly after installing. Just my opinion.
    shifty` likes this.
  23. Feb 13, 2024 at 7:30 PM
    BluegrapeVr6
    BluegrapeVr6 New Member
    J
    Don't tell me you daiky a VRT . You are the 5th previous VR6 Owner ive seen on this Forum
    bmf4069 likes this.
  24. Feb 13, 2024 at 7:32 PM
    VR6T
    Naw I like an idiot sold my 03 GLI VRT. Got an 13 GLI non MQB with all the APR bolt on shit and stage 2+ software. Getting ready to go big turbsksi on that. And I have a project Corrado. Working on an 800hp and R32 swap in that.
    But iused to daily my 03 GLI, 435whp 444wtq. Kit was capible of 500 plus. But factory internals are only rated to 500, so detuned it a little. Still stupid fucking fast
  25. Feb 13, 2024 at 7:39 PM
    Guilty
  26. Feb 13, 2024 at 8:10 PM
    VR6T
    I feel like you're guilty of alot more than we know of
    shifty`[QUOTED] likes this.
  27. Feb 14, 2024 at 6:46 AM
    txagg
    txagg New Member
    Central Texas
    Stone cold stock
    Sway bar bushings and end links perhaps?
    notlikejohnny[QUOTED] likes this.
  28. Feb 14, 2024 at 7:02 AM
    ToyotaDude
    ToyotaDude Member
    2003 Tundra AC V8 4x4
    As thy boot nigh the foul sound be intact, the dragon a misleading trail might lead. Whilst -84s escape thee, donning thine expanded boots may heal the discovered wounds, yielding hunt for the dragon in yonder lair.
  29. Feb 14, 2024 at 11:45 AM
    805Tundra
    805Tundra New Member
    Ben
    Central Coast
    2004 White 4x4 Double Cab
    Excited to get started on this project
    Voss, metalpete, bmf4069 and 9 others like this.
  30. Feb 14, 2024 at 12:23 PM
    ToyotaDude
    ToyotaDude Member
    Looking good. Happy with the output, color, and CA? What LEDs did you use?
    VR6T[QUOTED] likes this.
