Ay @Shifty . . . What's Your Take on Seafoam ?
Discussion in '1st Gen Tundras (2000-2006)' started by HBTundra, Feb 13, 2024.
  1. Feb 13, 2024 at 12:10 PM
    HBTundra
    HBTundra [OP] New Member
    2006 DC 2wd
    My Pops has a 2003 Chevy 1500 w/ the 4.8 motor & 110K miles. (Paw-Paw Miles) LOL
    That year(s) motor is kind of notorious for valve train noise.
    Highly contested what it actually is, or causes it.
    I did the spray can of Seafoam in the intake while running, then a 1 oz. per quart of the treatment to the oil.
    I ran it for a full tank of fuel (approx. 250 miles) then did an oil change.
    Oil came out dark as predicted, but nothing 'unusual'.
    Results seemed to get rid of 95% of the valve train noise . . . still a tiny bit right at start up, but mucho better.
    So what's your take on our trucks?
    I know you talk about sludge build up under the valve covers on low mileage, short interval driven 1st Gens.
    I'm not a Snake-Oil, or 'Genie-in-a-Bottle' kinda guy . . . but can't argue with what I saw in Pops ride.
    Just curious.
  2. Feb 13, 2024 at 12:24 PM
    FishNinja
    FishNinja HIDE YOUR DAUGHTERS
    Lee
    TEXAN....big surprise
    06DC2wd
    I guess you could have PM’d him? Lol but I’m also here to see what others have to say. I’ve personally seen some cool vids with cameras showing the top of the pistons before and after and Project Farm (everybodies favorite) has a some really in-depth videos on the subject
    JasonC. and HBTundra[OP] like this.
  3. Feb 13, 2024 at 12:27 PM
    The Black Mamba
    BlackSnek
    Flower Mound, TX
    Black 00 SR5 AC 5VZ PreRunner
    Imma keep it stock
    BG. put BG EPR in before an oil change, Run for 10 minutes (like do a few hot laps). Drain. Add BG MOA to you oil at every oil change (takes place of the additives found in "High Milage" labled oil). Use BG 44K in the fuel tank. If able and equipped to do so, perform a fuel induction cleaning through a vacuum line and clean the throttle body. @shifty` has posted many times about how to locate a retailer or how to order online.
    Engine – BG Products, Inc.
    Gasoline Fuel System – BG Products, Inc.
  4. Feb 13, 2024 at 12:36 PM
    The Black Mamba
    BlackSnek
    Flower Mound, TX
    Imma keep it stock
  5. Feb 13, 2024 at 12:54 PM
    I use it religiously. Wanna know more? Search with these three modifier tidbits set at the 1st Gen home forum area and find my 10 million comments about it.
    It doesn't matter whether you use Seafoam or BG products, but Seafoam is more readily available from what I see. Both make high quality products that'll do the job. For Seafoam, I prefer the High Mileage stuff. I have some in my crankcase now, in preparation for my upcoming oil change. I dumped the remainder of the bottle in my gas tank @ 1/8 tank, after pouring several ounces in the crankcase. I've done this with all of my vehicles since I can remember. MMO is another great product I use that's similarly effective.
    This video from PF speaks for itself.
    actundra01, Weagle, flyfisher and 8 others like this.
  6. Feb 13, 2024 at 2:47 PM
    evanhmn
    evanhmn mmm chicken pot pie
    State of Taxes
    2001 TRD Off-Road AC 4x4 Limited in Black
    5100/2885s, 1.5" Add-Leaf, BFF Front Bumper, 265/70/17 KO2s
    Love that we have people just straight up making posts @ing shifty for his genius
    Weagle, bmf4069, 1lowlife and 2 others like this.
  7. Feb 13, 2024 at 2:51 PM
    I think we should all pitch in and buy him a cape
  8. Feb 13, 2024 at 2:53 PM
    Meh. It's all opinion. Nothing superhero about sharing opinions.
    Weagle, 1lowlife and HBTundra[OP] like this.
  9. Feb 13, 2024 at 2:56 PM
    Thought the early LS engines had piston slap that everyone was hearing.
    HBTundra[OP] likes this.
  10. Feb 13, 2024 at 3:07 PM
    That Lucas stuff he used in the video worked for that. But I think the slapping was primarily in the earlier GenIIIs. I remember folks bitching about it on LS1tech when I was doing the LS1/T56 swap into my C10. I never experienced it personally.
  11. Feb 13, 2024 at 3:08 PM
    TRDFerguson
    Jake
    Southeast Greater Basin, AZ
    2018 MGM CrüeMax
  12. Feb 13, 2024 at 3:16 PM
    Body suit it is!!!
  13. Feb 13, 2024 at 3:26 PM
    I’m reluctant to apply it directly to the engine. All that carbon coming out of the engine is liable to take a few years off my cats. If I took my cats off I’d have no problem using it.
    I just add it to gas. Oil application, I’m unsure about. Guess I’d have to read up on that.
  14. Feb 13, 2024 at 3:26 PM
    If it doesn't have a stripper sock attached, I don't want it. Need an airy place to stuff my junk.
  15. Feb 13, 2024 at 3:28 PM
    My cats went missing a few years ago, and my blinky light came on the other day, im gonna give it a whirl in the engine oil
  16. Feb 13, 2024 at 3:32 PM
    Just cut a hole in it and a stick one on I guess.
    shifty`[QUOTED] and HBTundra[OP] like this.
  17. Feb 13, 2024 at 4:58 PM
    HBTundra
    2006 DC 2wd
    Cool Cool, thanks. ... I seen that vid. prior to treating my Pops truck.
    And it's weird . . . I must've spelled 'Seafoam' wrong the search window or something. . . cause I didn't see 'S' pop up. Should've known better.
    Oh well . . . glad I was able to provide a little comedy hour for the monkeys . . .LOL.
    That seems to be the overall consensus . . . but everyone chimes in with valve / tappet / lifter knock etc. etc. etc.
    Oil pressure 'seemed' to bump up a bit too after treatment.
  18. Feb 13, 2024 at 5:25 PM
    1lowlife and KNABORES like this.
  19. Feb 13, 2024 at 5:26 PM
    The green body suit would accentuate it even more.
  20. Feb 13, 2024 at 6:40 PM
    PomDad
    PomDad we having snacks?
    Conrad
    Atlanta
    2021 Cement Limited
    @ shifty, what is your favorite local brewery?
    Mine's red hare :cheers:
  21. Feb 13, 2024 at 6:53 PM
    bfunke
    bfunke Tundra Curmudgeon
    Wife 2005 Burb has 320K and has that annoying Vortec tick since about 200K. Couple things. First GM uses shitanium hydraulic lifters prone to collapse that cause this. Second o-ring on oil pickup can get pinched on install or deteriorate and shrink. Problem is you have to remove cross member and drop diff the remove pan.
  22. Feb 13, 2024 at 6:55 PM
    Or pull the motor
    said shitanium lifter
  23. Feb 13, 2024 at 7:16 PM
    It was Biggerstaff, but they closed :(
    PomDad[QUOTED] and 1lowlife like this.
  24. Feb 13, 2024 at 9:53 PM
    1lowlife
    1lowlife New Member
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    What kind of shop runs on a pancake compressor?:confused::boink::cool:
  25. Feb 13, 2024 at 10:00 PM
    Needed the psi up over 145 to get the crank bolt off. The main shop compressor is an old and tired 110v piston compressor from the 60s. Pops just swapped it out for a 220v compressor motor and plumbed it into the old larger tank. Hasn’t finished fixing some leaks, so pancake it was.
    1lowlife likes this.
  26. Feb 13, 2024 at 10:45 PM
    1lowlife
    1lowlife New Member
    DADA
    2014 MGM DC SR5
    I'm just messing with you.
    A pancake compressor is all I had for years, still use it for in-house and backyard stuff.
    I use my 35 gal Husky several times a week for just blowing stuff off other stuff and cleaning out vacuum cleaner filters.:eek2::rolleyes:
    It's just a 120V.....:cool:
    KNABORES[QUOTED] likes this.
  27. Feb 13, 2024 at 11:07 PM
    Mmmm, revolver blood honey
  28. Feb 14, 2024 at 4:02 AM
    I’ll admit it. Mine does. I ditched both my larger compressors 6-8yrs ago when I offloaded my Lincoln and plasma. I haven’t yet found a time when I said to myself, “man I wish I had more air”. Maybe if I painted I’d be there but for everything else? Electric does it.
    1lowlife[QUOTED] likes this.
  29. Sep 14, 2024 at 5:56 AM
    Damie Street
    Damie Street New Member
    Edsel
    2016 MGM CrewMax SR5 TRD OffRoad
    So with adding the BG MOA to the oil can you just get regular synthetic oil, instead of high milage? Hope that makes sense?
  30. Sep 16, 2024 at 4:59 PM
    The Black Mamba
    BlackSnek
    Flower Mound, TX
    Imma keep it stock
    Yes, that’s exactly what I do!
