Sucker punched by a rodent
Discussion in '2nd Gen Tundras (2007-2013)' started by KeepOnTruckin, Feb 13, 2024.
  1. Feb 13, 2024 at 11:48 AM
    KeepOnTruckin
    KeepOnTruckin [OP] New Member
    Randy
    2010 4.6 4x4 Bare Bones
    Edit 2025-03-19
    Adding pictures showing how to block cabin access at post #13.
    Last month during an ice storm w temps below freezing, the truck sat for maybe 12 hours. I went to run errands and started it while standing at the door. 5 minutes later I hop in to leave and right as I sat down see the oil pressure gauge drop to zero. Engine sounds the same but instantly my heart sank! Shut it off, look for leaks, check the level and all is well. Knowing the valve train should be unhappy and noisy if it really had no pressure, I start it rev it a bit. All sounds good.
    Back under the hood for a better look and yep, rodent chewed off wires eating some 1" sections. :mad:
    So ya, in that connector is a wire to the oil pressure sender. I swear it was a calculated attack.
    It's always good to have crimp tools, bare crimps and shrink tubing. Sadly some ABS and brake fluid level wires were chewed too. F'g rodents!
    I depinned the chewed wires, added short sections to each, most were 22 gauge prepped in the house then finished under hood repairs. Glad it wasn't any worse.
    Final repairs.
    astrength22 and Tridom like this.
  2. Feb 13, 2024 at 12:01 PM
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
    Nice repair job. Did you add any rat poison or peppermint spray?
    KeepOnTruckin[OP] and Tridom like this.
  3. Feb 13, 2024 at 2:54 PM
    Tridom
    Tridom New Member
    Dominick
    Hampton Roads, VA
    2012 Tundra SR5 4.6L V8
    Definitely a nice looking repair. Glad it wasn't worse.
    KeepOnTruckin[OP] likes this.
  4. Feb 13, 2024 at 3:00 PM
    RichterScale
    Ron
    WNY
    2021 DCRB as base as it gets
    pin stripes (+5 hp)
    Little sonsabitches
  5. Feb 13, 2024 at 3:08 PM
    2mchfun
    Is your HVAC intake screened? Mice inside the truck is no bueno at all!
  6. Feb 13, 2024 at 3:10 PM
    2mchfun
    BTW, a few rags soaked with pine sol about every 10-15 days spread around the engine bay in conjunction with a few bars of pink Dove soap seems to work well for my truck.
  7. Feb 13, 2024 at 3:11 PM
    MadMaxCanon
    MadMaxCanon New Member
    '21 CM SR5 4x4 6 seater
    Too many, but not enough....
    Damn only 12 hours, that sucker works fast
  8. Feb 13, 2024 at 5:02 PM
    wauto
    wauto New Member
    mike
    Tree rats strike again.
  9. Feb 13, 2024 at 6:11 PM
    KeepOnTruckin
    Randy
    I've been using dryer sheets, pine tree air fresheners, and snap traps. 3 down, more to go but ya, it needs to last longer so I might try this.
    Thanks
    2mchfun[QUOTED] likes this.
  10. Feb 13, 2024 at 6:23 PM
    KeepOnTruckin
    Randy
    To add insult to injury...
    You know the foam strip between the core support and radiator? I noticed it disappeared and thought it odd I didn't find any of it anywhere.
    Well, I found it. Right on top the cabin filter next to the pine tree car scent. :eek2::eek2::fistbump:
    Upon this discovery I tried to remove wipers and do what you mentioned but found I need a puller I don't have. I tried rocking them but they held firm.
    If you have something, feel free to describe its source. Thanks
    Here are the basics needed for wire repair. These are not as good as strain releifed OEM crimps but each one got the yank test and held.
    Edit - those yellow blue wire strippers are the best investment ever. You don't pull on the wire, you just need to reach it and squeeze.
    Edit II - when you need to clean the blower cage, a foot long chunk of clear PVC tube into your vacuum cleaner reaches in there to grab the debris.
    Mr Badwrench, koditten and Tridom like this.
  11. Feb 13, 2024 at 6:59 PM
    2mchfun
    Beware another member here nearly died from a parasite infection/infestation inside him because of rodent droppings throughout the HVAC in his truck. Imagine that blowing right in your face, not good. Might want to file an insurance claim and have it all taken apart and sterilized thoroughly.
  12. Feb 14, 2024 at 2:28 PM
    Red&03Taco
    Red&03Taco YUT
    Jerad
    2018 Platinum Tundra, 1997 FZJ80, 2003 Tacoma SR5 V6 5Spd
    Honda makes a tape that is soaked in capsaicin (Genuine Honda Rodent Tape - 4019-2317). I've heard good things about it. Kinda pricey at nearly $50 a roll, but worth it if it keeps those suckers out of your engine bay
  13. Mar 19, 2025 at 10:46 AM
    KeepOnTruckin
    Randy
    I never followed up with rodent proofing the cabin from engine bay cowling entrance. Suffice to say when you see what Toyota did you will be dumbfounded by access point.
    First off, my wipers were fused to the shafts and I thought the puller would break before the bond broke, by this tool fits in there with a bit of force.
    Once those are off, remove the two plastic rivets at each side and start lifting. I had to pry a little to get a few sections of the grill cover.
    After seeing 4 access points I grabbed some galvanized screen I had laying around and starting cutting, went to the hardware store for some 1/2" barbed rivets.
    Then I came up with these ideas....
    No hole drilling needed.
    Actually did each on my first attempt. For the large hole, I used a pick to pull the mesh back towards me and manipulate it. Overall I think it was a success.
    Mr Badwrench, Tunrod and OldGuy03 like this.
  14. Mar 21, 2025 at 1:48 PM
    KeepOnTruckin
    Randy
    It seems the AI Bot is listening. Check out this ad!
