Real-world experience with LT Tires on 3rg gen tundra
Discussion in '3rd Gen Tundras (2022+)' started by cvd2312, Feb 13, 2024.
  1. Feb 13, 2024 at 7:35 AM
    cvd2312
    cvd2312 [OP] New Member
    2023 CrewMax SR5 TRD OR
    Replacing tires on my ‘23 SR5 off-road soon, and planning to size up from the stock 18’s to 275/65/R20 on a set of the black TRD 20” wheels I bought.
    I’ve read way too much on this deciding between SL or E so I’m aware of the trade offs- ride quality is very subjective, but I’m trying to figure out how big of a difference it actually is on these trucks between SL and E. I don’t expect a Cadillac but I do appreciate the nice ride my truck currently has.
    I prefer Toyo AT3 but they don’t make SL in the size I want. Nitto makes the recon grappler in an SL, I’d be ok with that but it wouldn’t be my first tire choice.
    I tow a 5,500# travel trailer a handful of times each year, otherwise it’s my daily driver on mostly paved roads.
    Anyone that could pass along their experience with this issue would be appreciated!
  2. Feb 13, 2024 at 7:43 AM
    vtl
    vtl New Member
    Boston 'burbs
    2019 Red SR5 DC 4x4
    I had LT KO2 on my other vehicle, now it rolls on SL AT with less aggressive tread. Day and night in terms of comfort.
    cvd2312[OP] likes this.
  3. Feb 13, 2024 at 8:02 AM
    jeffcoseo
    jeffcoseo New Member
    Jeff
    Where do you live? There must be a Tundra owner in your town that will invite you for a cruise?
  4. Feb 13, 2024 at 8:10 AM
    Danman34
    Danman34 New Member
    Danny
    2018 White Tundra TRD Sport
    Been riding on LT tires with a 20” wheel for over 200k miles. As long as you’re running the proper pressure in the tires, the ride is great. A 33” tire on a 20” wheel still has a 6.5” sidewall, which is no where near “being so short”
  5. Feb 13, 2024 at 8:13 AM
    frichco228
    frichco228 Valued Member
    Frank
    Virginia
    2016 Crewmax 4WD, TRD Offroad
    LT tires are stiffer and heavier so impact both ride, performance and MPG. Depending on the size you want to run, LT may be the only option however.
    For LT tires- Between the weight, more aggressive tread, expect to see a 1-2 MPG drop and some ride degradation. Thats normal and part of the game typically when installing larger tires.
  6. Feb 13, 2024 at 8:14 AM
    Alex261
    Alex261 New Member
    Alex
    Boston, Ma
    2024 Tundra Platinum LR
    I run that size on my truck and love the ride. I have SL rated Falken Wildpeaks. Look great and still have stock ride for the most part. Gas didn’t change either
  7. Feb 13, 2024 at 8:18 AM
    cvd2312
    I haven't seen a SL rated Falken Wildpeak in 275/65/20. Where did you find that?
  8. Feb 13, 2024 at 8:19 AM
    cvd2312
    The sidewall on a 275/65/20 is about the same as the sidewall on my current 265/70/18. But yes I understand your point and i'm aware a 20" wheel will usually ride rougher. Honestly I just preferred the look, I'm not really a fan of the 18" TRD off-road wheels that came on my truck.
  9. Feb 13, 2024 at 8:35 AM
    Alex261
    Alex261 New Member
    Alex
    Boston, Ma
    My bad, I take that back. My tires are 275/60/20. A little bigger than stock height and width
  10. Feb 13, 2024 at 8:36 AM
    Matt2015Tundra
    Matt2015Tundra New Member
    2023 1794 CrewMax
    I went with the BFG KO2s in 275/60/R20 for their D load rating. They ride nice and I think the size is perfect for a non-lifted Tundra.
  11. Feb 13, 2024 at 8:47 AM
    Tom
    Tom New Member
    I don’t see any problem other than poor mpg because of the weight of the LT. Lower psi for soft ride and increase when you tow or haul heavy.
  12. Feb 13, 2024 at 10:15 AM
    jeffcoseo
    Jeff
    I have an extra set of Nitto Recon Grapplers on 20" TRD wheels. 295/65r20. Anyone is welcome to come test drive these on your truck.
    Aubrey, TX.
    Boerseun likes this.
  13. Feb 13, 2024 at 10:49 AM
    ThomperBeThompin
    ThomperBeThompin New Member
    I have 20in E rated Cooper Discoverer AT3XLTs in stock size. In my opinion, they are still pretty smooth and not too harsh. There was an MPG hit of about 1 - 1.5 MPG due to the extra weight. This tire is an all-terrain that was specifically designed and engineered for towing. I also tow about 6,000lbs (toy hauler) and they do great. Also fantastic wet weather and winter performance for an AT tire.
  14. Feb 13, 2024 at 11:03 AM
    cvd2312
    Thanks for the info, I appreciate it
