  1. Feb 12, 2024 at 4:05 PM
    Jenkem is a purported inhalant and hallucinogencreated from fermented human waste. In the mid-1990s, it was reported to be a popular street drugamong Zambian youth, created by placing feces and urine in a jar or a bucket, sealing it with a balloon or lid respectively and leaving it to ferment in the sun; afterwards they would inhale the fumes created. :eek:
  2. Feb 12, 2024 at 4:07 PM
    The Black Mamba
    DFW
    Black 00 SR5 AC 5VZ PreRunner
    Imma keep it stock
    That’s fucking disgusting
    oscardog86, BroHon, 87warrior and 3 others like this.
  3. Feb 12, 2024 at 4:07 PM
    Yep, it made its way to America as well.
    South Park as always on point; released a episode about “cheesin” “I’m cheesin my balls off!!” Which is actually a really good episode, and in my eyes, a response/spoof to this strange behavior
  4. Feb 12, 2024 at 4:13 PM
    JasonC.
    JasonC. ¯\_(ツ)_/¯
    2001 4x4 4.7L “Best Cab”/AC Limited 52k mi
    That’s possibly useful info if you’re ever stuck on a desert island and want to celebrate.
    oscardog86 and bmf4069 like this.
  5. Feb 12, 2024 at 4:18 PM
    NUDRAT
    NUDRAT 6 lug life
    SW CT
    Between 'Ridgelines'
    @shifty` started his next career. Remote Worker - "Influencer". Getting set up for those hundred acres 20 miles from anywhere. o_O
    VR6T, FrenchToasty, Festerw and 2 others like this.
  6. Feb 12, 2024 at 4:28 PM
    That can’t be healthy.
  7. Feb 12, 2024 at 4:30 PM
    Is that the one where they inhale cat piss?
  8. Feb 12, 2024 at 4:30 PM
    Mr.bee
    Mr.bee King Turdra
    '02 AC TRD
    Put it in a fancy container, and charge alot. The next best thing since fentanyl. Buy 2 get 1 free, $100 ea.
    Voss, bmf4069 and FrenchToasty like this.
  9. Feb 12, 2024 at 4:33 PM
    I have a 100% good vent in mine, I replaced it when I drain-filled my rear diff for the 1st time (under my ownership).
    It hissed when I removed it so I assumed the old one wasn't working. Then I had to install slip additive, which I installed via the vent port. Removed the brand new valve, same PSSSSSSssssssss.
    That 1-2oz wasn't enough so I needed to add more. Removed the brand new valve, PSSSSSsssssssssss...
    That extra 1-2oz wasn't enough, so I went in and added more, PSSSSSsssssss...
    I think either some pressure or some vacuum is normal in there, and the valve doesn't kick in until things reach a certain point, or it allows offgas, but not intake like @FrenchyNuggets said.
  10. Feb 12, 2024 at 4:36 PM
    assassin10000
    assassin10000 New Member
    Andrew
    Northern CA
    '05 SR5 AC
    Correct. It's a simple spring and rubber flap inside the cap. Allows out, not in.
  11. Feb 12, 2024 at 4:37 PM
    Festerw
    Festerw New Member
    Cambridge Springs, PA
    04 Tundra DC
    I actually know someone for this lol.
    My wife works for an influencer marketing company.
    NUDRAT[QUOTED] likes this.
  12. Feb 12, 2024 at 4:56 PM
    I have a friend who got laid off from IBM 8-10 years ago after being there 15, 20 years? They sent him out the door with a handsome check, he took the money and invested it, sounds like he made a shitload of money on a few investments, used that to angel invest in some promising startups, hit gold on at least one, with a couple others that didn't which fail looking promising, and has a couple of other investments about to blow up that'll set him for life. He's done well, and always has wild ideas, he was pushing me to do the same recently.
    "Think back on your career. Make a list of 10, 20 things that were turning points or 'aha!' moments for you, or things you learned too late, things you wish someone had told you early on. Do a 5-10 minute write-up/short blurb on it. Make a quick YouTube video on it. Put it out there, monetize your channel. Drop it on LinkedIn as a series. Use a controversial title, and you're a big f'n smartass, use a lot of humor. People will eat it up. I know someone with 200k-300k followers who essentially used the same formula and makes $70k/yr passive income on his channel, he's only got 25 videos..."
    I dunno, it's not for me. Same reason I'm not a rockstar. I'm far better 1-on-1, otherwise not one for stages. I don't like attention, attention produced nothing but trouble for me in my adolescent/teen/early adult years.
    PS - Scotty Kilmer is a fucking annoying douchenozzle. I don't want to be a Scotty Kilmer for a living.
  13. Feb 12, 2024 at 4:57 PM
    BluegrapeVr6
    BluegrapeVr6 New Member
    J
    Out with old, in with new. Just need to finish wiring.
  14. Feb 12, 2024 at 4:58 PM
    VR6T
    Texan.... Big suprise
    00 Tundra Limited 2WD AC
  15. Feb 12, 2024 at 5:06 PM
    VR6T
    He could dethrone ChrisFix
    oscardog86 and FrenchToasty like this.
  16. Feb 12, 2024 at 5:34 PM
    Azblue
    The Dirty T ( ^_^)_且
    I wouldn't fix it. I've seen pics of the rust on your truck. A steady supply of oil flowing down to coat stuff couldn't hurt.
  17. Feb 12, 2024 at 5:35 PM
    HAY GUUUUYS, SHIFTYFIX HEEEEEERE.
    BroHon, oscardog86, artsr2002 and 6 others like this.
  18. Feb 12, 2024 at 5:42 PM
    Yeh, no. Not at the rate of 1 quart a month. Less if I don’t drive like I have over the last couple of weeks.
    Azblue[QUOTED] likes this.
  19. Feb 12, 2024 at 5:45 PM
    I would change the name shiftyfix to something a little less questionable and more trustworthy for those who don’t know you.
  20. Feb 12, 2024 at 6:10 PM
    805Tundra
    805Tundra New Member
    Ben
    Central Coast
    2004 White 4x4 Double Cab
    I know I’m a little late on this post and haven’t caught up so maybe it’s been figured out, but no clunks for me. Coilovers don’t feel stiff for me but maybe because the DC has more weight up front
    shifty`[QUOTED] likes this.
  21. Feb 12, 2024 at 6:39 PM
    VR6T
    No no the shiftyfix stays, jt jas just the right smount of sketch to it
    NUDRAT and Jack McCarthy[QUOTED] like this.
  22. Feb 12, 2024 at 6:42 PM
    NUDRAT, Mr.bee and VR6T[QUOTED] like this.
  23. Feb 12, 2024 at 6:44 PM
    VR6T
    Ok The CoLight minis shoeed up today, a out 4pmish well well well after the mail route has stopped. They were littersly just thrown at my porch/ entryway. Like i heard it hit the wall. So I ran to the door, and no one was there, i didnt see any unknown cars or persons leaving. 4 days late and shows up afyer hours of USPS delivery and my post office doesnt do door to door delivery unless it large item 50 to 200lbs, anything greater is a show up in person thing. I thibk someone was tryi g to steal my headlight bulbs. Package was sealed shut with packing tape, not the adhesive strip those style if envelopes usually have. Fuckinf theiving cunts man.0212241818.jpg
  24. Feb 12, 2024 at 6:45 PM
    VR6T
    :rofl::rofl::rofl:
  25. Feb 12, 2024 at 6:53 PM
    metalpete
    metalpete New Member
    ID
    2001 Tundra 4.7 4x4 SR5
    Toytech 2.0 Coilovers Camburg UCA's JBA headers Dynomax cat-back exhaust 90-221HD Leafs
    "All right guys, let's get shifty with it"
    And then, make sure you encourage all subscribers to watch your first video; which already answers every question they could possibly ask in the comments.
    BroHon, oscardog86, bmf4069 and 2 others like this.
  26. Feb 12, 2024 at 7:01 PM
    Man, now you’ve got me thinking you might not be fun at parties. :rofl:
  27. Feb 12, 2024 at 7:03 PM
    VR6T
    Step 1 tear out you brand new refractor housing from your headlight, should look like this.0212242004.jpg
    Step 2, remount spring and break your latching lug (optional, not reccomended)0212242005.jpg
    Step 2a. (Optional) Using a hole saw drill bit and a step bit, cut you out big circle of plastic, step out the center hole to 3/4". Cut in half, drill pilot holes with small drill bit. Install the now "better" retention lock. (Also not reccomended if you dont finger fuck your housings up.)
    Step 5 Thread back on the heat sink over the rubber boot. Optional, trim rubber boot to fit over heat sink for easier access in the future. Not mandatory.0212242037.jpg
    Step 6 reconnect/ pin together voltage/ relay box
    Step 7 Thread on pin connector/ weather nut to seal the power connection.
    Step 8 Install and enjoy. I mean blind everyone, i mean calibrate
    Voss, NUDRAT, BroHon and 4 others like this.
  28. Feb 12, 2024 at 7:16 PM
    I am when I’m drunk. Ask the 1987 freshman engineering class at Southeastern Mass University. People were yelling my name in Physics class from the back of the theater. I turned around not knowing who or what they were talking about, and then I heard the words nobody wants to hear, “He doesn’t remember!”.
  29. Feb 12, 2024 at 7:18 PM
    txagg
    txagg New Member
    Central Texas
    Stone cold stock
  30. Feb 12, 2024 at 7:38 PM
    Don't forget your soapy wooder.
