Huge shout out to the forum - thanks all
Discussion in '1st Gen Tundras (2000-2006)' started by Weagle, Feb 12, 2024.
  1. Feb 12, 2024 at 1:20 PM
    Weagle
    Weagle [OP] I survived my timing belt change
    Prattville, AL
    2006 Tundra SR5 DC 4.7 2WD LSD towing pkg
    Bilstein 5100's with 2883's - close to 2" Replacing the 2883's and going back to the bottom perch ASAP -mobile/apple play stereo with sub and backup cam -Power stop HD front calipers and rotors for towing -20" wheels with 32" tires (305/50's) Toyo AT 3's with no rubbing -Westin nerf bars -Detroit axle new (not rebuilt) steering rack with poly bushings, inner and outer TRE's -Suspension Maxx extended front sway bar links -Overland tuning - medium level -Power front leather seats and steering wheel from 06 Sequoia -fully de-chromed/blacked out trim -all light housings incl 3rd brake light and tag lights replaced with smoked lenses, LED where appropriate -mini projector headlights -fully rebuilt trans and new torque converter -new complete drive shaft with spicer u-joints and carrier bearing -all LED interior lights including backlighting -new lower window seals for all 4 doors -all new hardware and clips for tailgate Next: Dirty Deeds racing exhaust with LT headers, yellow box, 12 hole DD fuel injectors, redo or replace door panels
    Great big shout out to this forum and quite a few people that have offered knowledgeable help and given feedback, particularly @shifty. I'm getting a little better at finding existing how to's in the forum although it's still a bit confusing because there are so many threads on the same topics and not all of them are accurate, complete, or in agreement
    So far I've changed out, upgraded, repaired, modified, etc:
    1" lift including
    replaced my front coil over springs/shocks
    Rear shocks
    lower ball joints
    Could NOT be more pleased with the ride and handling
    Numerous weatherstrips and clips
    Tailgate latches
    Driver door latch
    Driver door window regulator, and motor
    Climate control lighting - honestly, had not noticed this because they had each burned out over a period of time until I couldn't find the dang hazard light switch one night. What a difference at night now
    Fixed rattling mirrors and rattling tailgate latch rods that had been annoying for quite some time
    Replaced old stock worn out vinyl/plastic/? steering wheel that had a big lengthy split with a leather steering wheel from a sequoia in great shape. Really nice upgrade. And can also possibly upgrade to radio controls one day in the future
    Very quickly resolved an issue with the wrong differential fluid after hassling with the shop for weeks. Ultimately had to tell them what the issue was thanks to this forum's help.
    Fixed seatbelts that had not been fully retracting for over a decade
    I'm sure i've missed a few things and I have quite a few things to still accomplish over the next few months.
    I was ready to just relegate my truck to occasional hauling of dirt and building supplies and such. Just felt like it was getting old and worn out. And if I would've had to pay for all of this in the shop, it would've most certainly been cost prohibitive not to mention annoying because the job is often not done right the first time or at least to my standards
    Now I've got the old reliable truck that I've loved for 18 years and over 306,000 miles that has NEVER put me down or once required adding oil, back in great shape where I once again trust it traveling anywhere in the US
    could never have done all of this, or even thought of tackling it without the support of you guys
  2. Feb 12, 2024 at 1:39 PM
    We've all been there, that's why we're here. I've owned my FGT for almost 20 years now. Originally found this site and this group looking for answers about carrier bearings. I've gained a ton of knowledge about how my truck works and how to keep it in great shape from here. I share when I can, but still enjoy learning from others experiences here.
  3. Feb 12, 2024 at 2:03 PM
    Ghost Rider
    Ian
    Cypress, Texas
    2021 White Tundra CM SR5
    @shifty` you really need to start handing out that "Approved by @shifty` sign....
    bmf4069 and Weagle[OP] like this.
  4. Feb 12, 2024 at 2:20 PM
    bmf4069 likes this.
  5. Feb 12, 2024 at 3:37 PM
    You mean these?
    I got those made.
    batman900, tvpierce, DJC94 and 4 others like this.
  6. Feb 12, 2024 at 3:46 PM
    Ghost Rider
    Ian
    Cypress, Texas
    Correct.
