  1. Feb 10, 2024 at 9:53 PM
    TRDFerguson
    Jake
    Southeast Greater Basin, AZ
    2018 MGM CrüeMax
    BlueRibbon4x4 and WFD473 like this.
  2. Feb 10, 2024 at 9:53 PM
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    Also. I’ll probably add a relay to mine.
  3. Feb 10, 2024 at 9:55 PM
    RainMan_PNW
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    Hell no
    I used the factory kit. If Toyota don’t think it needs a relay isolation, why should I?
    BlueRibbon4x4 and TRDFerguson like this.
  4. Feb 10, 2024 at 9:57 PM
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    I’ve got a 9v battery that might change your mind
    BiggHertz likes this.
  5. Feb 10, 2024 at 10:31 PM
    BiggHertz
    BiggHertz DZTLIMO
    Chandler, AZ
    IG: dztlimo
    Stuff and Things
  6. Feb 10, 2024 at 11:35 PM
    Mater
    Mater New Member
    SD
    2016 MGM Platinum
    You lick it to make sure it’s live?
  7. Feb 11, 2024 at 5:58 AM
    Gainer
    Gainer New Member
    Columbus, OH
    2018 SR w/8' Bed
    Leveling kit, TRD wheels, remote start, Hellwig helper springs, TRD Rear sway bar. TRD Rear shocks, Dirty Deed 10" exhaust, S&B Cold Air intake
    What topper do you have? How do you like it and have you had any issues with it?
  8. Feb 11, 2024 at 6:04 AM
    Looks like a ARE CX Topper.
    bulldog93 and AGTundra like this.
  9. Feb 11, 2024 at 6:24 AM
    AGTundra
    AGTundra New Member
    Miguel
    North Carolina
    21 CM TRD Off-road
    @Gainer ARE CX with windoors and the factory installed tracks up top.
    Hoping soon to get a rack system up there for work and play
    It has been great for us with kids and our pup.
    Minor leaking sometimes if it rains heavy but not a real big deal
    Overall very happy with it
    Junior 88, Gainer and bulldog93 like this.
  10. Feb 11, 2024 at 6:24 AM
    Tundar the Barbarian
    Tundar the Barbarian New Member
    2020 MGM TRD OffRoad
    Speakers, amp, subs, floorboard lights...and the little step thing under the bumper
    Finished too late for a photo...High-speed Magsafe charger installed! Ugh, need to clean it, inside and out... PXL_20240211_142252517.jpg
  11. Feb 11, 2024 at 7:23 AM
    RainMan_PNW
    Casey
    Clark County, WA
    If you’re going through that much effort to open my tailgate, you can have the old shovel and axe I keep in there…
    grant.ducckk, Mater, Henry1jg and 2 others like this.
  12. Feb 11, 2024 at 1:00 PM
    doughboysigep
    doughboysigep New Member
    Delhi, NY
    '20 SR5 CM 4x4
    Installed my step bars yesterday. Fairly easy (hardest part was understanding directions) and pretty happy how they look. Only I don't like is that you can see the mounting brackets a bit more than I remember on my OEM ones on my old '17.
  13. Feb 11, 2024 at 1:02 PM
    doughboysigep
    Delhi, NY
    '20 SR5 CM 4x4
  14. Feb 11, 2024 at 1:04 PM
    doughboysigep
    Delhi, NY
    '20 SR5 CM 4x4
  15. Feb 11, 2024 at 1:50 PM
    dan8906
    dan8906 New Member
    Daniel
    2017 MGM Tundra SR5 TRD OR, 2011 Tacoma TRD OR & 2004 Tacoma TRD OR
    Finished the lift(2.5”/1.25”) Bilstein 6112s up front on setting #4, 5160s in the rear with a CB +2 shackle in the rear. Pretty impressed with the ride. Much better than stock, although I haven’t gave it a real test. Wheels and tires on Tuesday then an alignment. Then I’ll be able to really test it out.
  16. Feb 11, 2024 at 2:42 PM
    21GreenMachine
    21GreenMachine New Member
    21 Tundra TRD Limited
    Stock
    Tried to remove the first layer of winter. Detailed interior today and hand washed Friday night (it was cold). Got the wife's 4 Runner too!
    bulldog93 likes this.
  17. Feb 12, 2024 at 7:18 AM
    nobodyintexas
    nobodyintexas What?
    South of Houston
    S/C'd 2020 White 1794 Tundra
    this was my 1st oil change using the fumoto valve. 90k miles on truck
    I have been living wrong up until now.
    every grown-ass, God fearin' man should have a Fumoto valve.
    also - sending a sample to Blackstone.
    to check:
    Costco 5w-30
    TBN, too.
    full 5k usage of oil using the 77.5mm pulley on the Harrop S/C.
    I bet it's just as good as EVERY other oil out there.
    Costco 0w-20 was awesome when I tested it a couple years ago.
  18. Feb 12, 2024 at 7:22 AM
    Terndrerrr
    Terndrerrr 923000 miles to go
    Music City
    6UR-FE
    Just got through my last box of 0w20. Kirkland 5w30 here I come!
  19. Feb 12, 2024 at 9:02 AM
    Damie Street
    Damie Street New Member
    Edsel
    2016 MGM CrewMax SR5 TRD OffRoad
    THose look great! what size bed bars did you go with? And are they staying on the truck or will you be taking them off and on? I'm asking because I see the bed cover rolled up.
    Tan-dra[QUOTED] likes this.
  20. Feb 12, 2024 at 9:15 AM
    Damie Street
    Edsel
    You have motivated me to get a pole saw and do the same! Which saw did you end up with?
  21. Feb 12, 2024 at 9:50 AM
    Gecko.
    Gecko. New Member
    CT
    2014 Tundra DC
    Finally installed the Revesol "All Black" (i.e., Black Ring) steering wheel I ordered back in January (https://www.tundras.com/threads/we-...ack-steering-wheel.112984/page-6#post-3473795). Its a really nice, quality piece.
    Also did my first oil & filter change yesterday. Installed a Fumoto valve while I was at it.
    Regarding the oil change ... I have to say, that OEM skid-plate/deflector-shield was a huge pain in the ass. Out of the 5 bolts holding it up: the rearward middle bolt was missing; the other four were badly rusted; the front passenger side bolt snapped off flush with the bar. With the bolt that snapped, I drilled a hole and attempted to use an extractor bit to loosen it up ... which then snapped inside the hole I drilled. FML No time to play around, so I just installed the plate with three bolts (two rear and one front with a liberal abs of anti-seize) and some zip ties.
    Oh, and while I was pouring in the oil I notice these upper coolant lines that are pretty rusty. Anybody have occasion to replace these? Have a Part No. (2014)?
    mgm16trdpro, bulldog93 and RobertD like this.
  22. Feb 12, 2024 at 10:04 AM
    Tan-dra
    Tan-dra MUD GANG 2006
    2020 Quicksand SR5
    Bilstein 5100, 35’s on 17” wheels
    These are their low rise ones, I think they’re like 9” tall if I remember correctly. I bought these because I’m like 95% sure I can get them to work with my bed cover, I just need to cut some of the rubber stripping on the rails where the bars are going to be. Hopefully it will work, I’ll report back here whenever I get them back from powdercoating
  23. Feb 12, 2024 at 11:28 AM
    TacomaTRD4x402
    TacomaTRD4x402 New Member
    Southern California
    Eibach Pro 2R, Dirt King UCA, 285/70/18 Toyo ATIII, Stillen TruPower CAI, OTT
    Found the ultimate cheat code today
  24. Feb 12, 2024 at 2:32 PM
    InfernoTundra15
    InfernoTundra15 2015 TRD Pro
    It’s Ego multi attachment tool. Have pole saw attachment and edger.
  25. Feb 12, 2024 at 3:14 PM
    SRQRUSTY
    SRQRUSTY New Member
    Bone stock 2018 Tundra 4X4
    A much needed upgrade for my truck. The under seat storage is basically nonexistent under the rear seat of my 2018 Crewmax. Now I have a little more lol
    Tundra-XP, RobD1, TS1794 and 12 others like this.
  26. Feb 12, 2024 at 3:58 PM
    Ryuu
    Ryuu Hwat!?
    Oz
    SouthEast, TX
    2017 TRD PRO Barcelona Red
    a few
    Greased uca ball joints and tie rod ball joints.
    Also all the zerks on the driveshaft, man the front 2 were a pain.
    bulldog93 and WFD473 like this.
  27. Feb 12, 2024 at 4:40 PM
    singletrack_dad
    singletrack_dad New Member
    Ty
    2014 TRD OR CM
    Truck is at 160k miles & has an “unknown” age on the diffs fluid & transfer case. So I pumped some fresh 75w90 in there & did a purple power scrub on the totally grimey rear axle. Torqued everything to spec with fresh OEM washers & witness marked it all. Front diff was quite gross but the other 2 looked pretty dang good.
  28. Feb 12, 2024 at 4:41 PM
    singletrack_dad
    Ty
    2014 TRD OR CM
    Can you link a brother to those cubbies? Or is that all DIY
  29. Feb 12, 2024 at 4:53 PM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    2017 Tundra Platnium
    Too many mods to come
  30. Feb 12, 2024 at 6:23 PM
    Henry1jg
    Henry1jg 2021 TRD Sport
    MI
    I just did my first oil change on my new to me truck. I debated getting the Fumoto and ultimately decided to see how it went, and then decide. Thx to this site, I was prepared and didn't make a mess, but I think a Fumoto will be in my future anyway. Don't wna have to clean out my old 5 gal bucket after every oil change.
    Yes! The skid plate was def an annoyance for the oil change. I fully understand now why ppl buy a plate w the door in it now. I will be on the prowl for one now for sure.
    Also, the MotivX kit is A+!
