so glad I found u
Discussion in 'New Member Introductions' started by IamLa11, Feb 8, 2024.
  1. Feb 8, 2024 at 11:35 AM
    IamLa11
    IamLa11 [OP] New Member
    2021 Limited and Loving it
    6"lift, changing to 4", 37's on 20's changing to 35's on 17's, front bumber, and blackin' out all crome.
    Hey guys,
    Long story short, my wife and I wanted to do some overlanding (camping) and after going thru all the options (Jeep, 4runner, Tacoma) because of the overland trailer we got (4900ish dry) we decided the TUNDRA was the perfect option and really the only choice. Thus we went looking. For us, me really, the only option was the 2021 year, with the V8. So we got one. She came with a bunch of upgrades, some more useful then others and I am in the process of swapping out the items that don't fit our needs. Thus, getting rid of the 37's sitting on 20's for 35's sitting on 17's (rims already ordered and either going with the Toyos Open Country or the Falkens). Also, today, as a matter of fact, I am lowering the front to about 4" with some Old man Emu BP51s and removing the Rough Country's and dropping the rear 2". Here are some pics, if I can figure this out.
  2. Feb 8, 2024 at 11:42 AM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    2017 Tundra Platnium
    Too many mods to come
    Nice rig, and welcome!
    2mchfun and IamLa11[OP] like this.
  3. Feb 8, 2024 at 11:47 AM
    IamLa11
    Thank you Boss. We drove it to Utah, from Cali, to pick up the trailer and it was perfect, except the 37's bogged her down a bit...thus the move to 35's.
    bulldog93, 2mchfun and reywcms like this.
  4. Feb 8, 2024 at 11:54 AM
    JMGmanAZ
    JMGmanAZ New Member
    Jerry
    Belly of the Beast
    Nice set up :thumbsup:
    IamLa11[OP] and 2mchfun like this.
  5. Feb 8, 2024 at 12:10 PM
    IamLa11
    Hey bro, I was just reading thru your other thread, on the travel trailer. I know you have the newer gen that can tow a bit more cuz it has a little more power and torque, but here is my two cents, not worth more then one and two 1/2 pennies. Our V8, again I know you have the V6 Turbo, struggled with our new trailer, that weighted about 5800lbs wet (guessing), up hill with the 37" tires. The prior owner did not re-gear her, thus I am dropping to 35's and still might need to re-gear the rear. Also, you might consider looking at overland trailers that get you off grid and away from the public crazies. Your truck is made for dirt roads, you might as well get a trailer that is designed for the same. Good luck bro.
    RobertD and 2mchfun like this.
  6. Feb 8, 2024 at 12:17 PM
    Rodtheviking
    Rodtheviking New Member
    Vancouver, WA
    Sequoia
    As long as the subframe wasn't cut you can easily go to the OME suspension, it will be a huge improvement. From the side picture it's hard to tell, the 4-6 inch Rough Country kit does require cutting.
    IamLa11[OP] likes this.
  7. Feb 8, 2024 at 12:19 PM
    2mchfun
    Gears are the way! Also pop in an auxiliary tranny cooler. You can easily get the OEM thermostat and lines from a dealer and add a decent aftermarket oil cooler with a few fittings for a cost far below that of a tranny. Happy camping!!
  8. Feb 8, 2024 at 12:26 PM
    Gainer
    Gainer New Member
    Columbus, OH
    2018 SR w/8' Bed
    Leveling kit, TRD wheels, remote start, Hellwig helper springs, TRD Rear sway bar. TRD Rear shocks, Dirty Deed 10" exhaust, S&B Cold Air intake
    Welcome to the forum! You can't go wrong getting rid of Rough Country and going with Old Man Emu.
    If you don't want to regear, maybe consider going with a 33x12.5x17 Tire and wheel combo. I'm running 275/70/18 that equate to 33 1/4 tall tires.
    I tow a Jeep on a car hauler behind mine with little to no problem. It will drop into a lower gear when climbing steeper grades.
    You will be glad you got the TRD Pro. I'm pretty sure it will have the 38 gallon tank. At 10 MPG when towing, gas stops became to frequent. I ended up buying a 46 gallon Transfer Flow fuel tank.
    One of the ABSOLUTE worst things you can do here is look at the "What have you done to your 2.5 Tundra today?" thread.... it will cost you lots of $$$$.$$
    bulldog93 and IamLa11[OP] like this.
  9. Feb 8, 2024 at 12:39 PM
    The Black Mamba
    BlackSnek
    Flower Mound, TX
    Black 00 SR5 AC 5VZ PreRunner
    Imma keep it stock
    Welcome from the Great State of Texas!
  10. Feb 8, 2024 at 12:43 PM
    IamLa11
    Not sure what you mean, she already has the Rough Country and the sub has already been cut. Dropping her down a little with the Old mans should be fine. Am I missing something??
  11. Feb 8, 2024 at 12:45 PM
    IamLa11
    God blesses Texas everyday and twice on Sunday.
  12. Feb 8, 2024 at 12:48 PM
    IamLa11
    Hahaha...there is no doubt that thread will be dangerous. Yes she has the bigger tank and yes MPG suck balls with 37's towing a trailer. Haha. Not too worried about the MPG but would like to help my engine out a little. Thanks for your reply.
  13. Feb 8, 2024 at 1:18 PM
    Musicmasterd12
    Musicmasterd12 New Member
    Southern Louisiana
    2011 4.6 Silver Sky Metallic DC
    if that’s the case, you should throw a supercharger by on her!!
    :burnrubber:
    IamLa11[QUOTED][OP] likes this.
  14. Feb 8, 2024 at 1:42 PM
    IamLa11
    LOL, that is actually something I am considering. She already has straight pipes and sounds beastly like only a v8 can...so...
  15. Feb 8, 2024 at 8:01 PM
    Welcome from NY.
  16. Feb 8, 2024 at 9:36 PM
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
  17. Feb 9, 2024 at 3:52 AM
    Bayou Spartan
    Bayou Spartan New Member
    Black 2019 TRD PRo
    None
    Welcome from Jacksonville, Florida
  18. Feb 9, 2024 at 5:57 AM
    Bprose
    Bprose Old member
    VA
    17 Tundra CM TRD
    Welcome from VA.
  19. Feb 9, 2024 at 12:15 PM
    RealTruck
    RealTruck New Member Vendor
    Welcome to the Forum!
  20. Feb 9, 2024 at 12:23 PM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    Supercharges help with towing
  21. Feb 9, 2024 at 12:30 PM
    Ebrperk
    Ebrperk Old member
    South Central Kansas
    2018 1794 MGM
    Tinted windows, go rhino D6 side steps and shorty antenna, Bilstein 5100's rears, 6112's fonts set to 2.5" Rocktrix RT111 18x9 -12offset NItto Terra Grapplers G3's 275/70 R18's. Amp from James @ Tech12volts FRAC Harness
    Great Looking Rig, And, of course, you got the best color
  22. Feb 9, 2024 at 1:34 PM
    IamLa11
    Wait, do you get that rig in Utah...sick set up. I am a fan.
  23. Feb 9, 2024 at 1:36 PM
    IamLa11
    For sure. In the process of blacking everything out, in case the shit goes sideways. Dark is good to stay under the radar at night.
  24. Feb 9, 2024 at 1:40 PM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    Yea the rents picked it up in Utah.
  25. Feb 12, 2024 at 6:54 AM
    RitcheyRch
    RitcheyRch New Member
    Richard
    Star, Idaho
    TRD Lowered and Supercharged
    Welcome from So Cal
