Anyone running 17" rims on your 2.5 gen?
Discussion in 'Wheels & Tires' started by BuckWallace, Apr 2, 2018.
  1. Nov 11, 2023 at 9:16 AM
    #721
    Ponderosa_Pine
    Ponderosa_Pine
    Northwest
    315/70r17 on Rock Warriors (50mm offset). +2” lift all around.
  2. Nov 11, 2023 at 10:52 AM
    #722
    WFD473
    WFD473 Long Live The V8
    Northeast Illinois
    2014 MGM SR5 CM 4x4
    Are those powder coated a darker color than stock? It's hard to tell without the rings on there. Looks sweet either way!!
  3. Nov 11, 2023 at 4:56 PM
    #723
    Ponderosa_Pine
    Ponderosa_Pine
    Northwest
    Thanks! I stripped them then did primer/graphite duplicolor wheel paint/two part epoxy clear coat. Most I’ve gotten a hold of in the wild needed major refreshing, often the ring bolts won’t come out either so have to drill those.
    WFD473[QUOTED], Ryuu, equin and 3 others like this.
  4. Jan 23, 2024 at 1:20 PM
    #724
    Kelley2727
    Kelley2727 New Member
    Just had a Bilstein 5100 2.5” lift with 35” Toyo R/T trails and 17” 703 Methods. 35X12.50R17 0 offset. Love it so far.
  5. Feb 11, 2024 at 8:31 AM
    #725
    Ohannon7
    Ohannon7 New Member
    Central Fl
    2013 5.7 4WD CM Bench-Seat Silver
    6” Pro Comp 37’s Custom audio and interior Off road capability is current focus
    17" wheel on 37" tire
  6. Feb 11, 2024 at 9:32 AM
    #726
    Jman245
    Jman245 Just moving about my way.
    Jay
    R.CUCAMOMGA,CA
    '19 Tundra TRD SPORT, ‘21 Trail Edition
    Trd pro suspension
  7. Feb 11, 2024 at 9:33 AM
    #727
    COTundra23
    COTundra23 New Member
    never seen those wheels before. Good lookin
    Jman245[QUOTED] and AGTundra like this.
  8. Feb 11, 2024 at 10:43 AM
    #728
    JMGmanAZ
    JMGmanAZ New Member
    Jerry
    Belly of the Beast
    FUEL Vectors with 285/75/17
  9. Feb 11, 2024 at 10:52 AM
    #729
    COTundra23
    where did you get those center caps tho…. Those things are clean!!
    NewImprovedRon likes this.
  10. Feb 11, 2024 at 2:49 PM
    #730
    Jman245
    Jay
    R.CUCAMOMGA,CA
    Trd pro suspension
  11. Feb 12, 2024 at 12:44 AM
    #731
    Ponderosa_Pine
    Ponderosa_Pine
    Northwest
    Haha these ones I got from ebay from a guy in Florida. He seemed to have removed them early on in their life and kept them inside, they are time stamped as originals which was surprising. I ended up getting 3 sets of rock warriors over the years and refurbing them. Only 10 were salvageable and only 4 of those were “good” quality, the rest needed bolts drilled or significant corrosion etc.
    COTundra23[QUOTED] likes this.
  12. Feb 12, 2024 at 5:16 AM
    #732
    DirtyMike5
    DirtyMike5 New Member
    Baton Rouge
  13. Feb 12, 2024 at 7:16 AM
    #733
    COTundra23
    Right on. If you have any extra center caps laying around.... let me know!!
  14. Feb 14, 2024 at 11:02 AM
    #734
    stevesgraytundra
    stevesgraytundra New Member
    Stephen
    2021 MGM SR5 CM 4x4
    I had these installed today. 255/75 R17 Cooper Discoverer Road +Trail AT on Method 314s. 17x7.5 +25 offset wheels so they stick out just a touch past the flares. I wanted to stick with OE overall diameter and tire width and these worked out perfectly IMG_4982.jpg IMG_4983.jpg IMG_4984.jpg
  15. Feb 29, 2024 at 8:17 AM
    #735
    MGMTunny14
    MGMTunny14 New Member
    Maryland
    2014 DCSB MGM Limited Tundra 5.7L
    Dirty Deed’s 6” Aluminum Standard Exhaust System Morimoto 4Banger HXB Fog Lights K&N Wet Oil Cold Air Intake JBA UCA’s Toytec BOSS Level Kit Tech12Volt Remote Start Module/Kit
    So my general takeaway from this thread is that yes you can run 17” wheels on the 2.5. But my gut is still looking for a little extra confirmation on my own particular case before I pull the trigger. I got a 2014 Limited Crewmax with the 5.5ft bed, running 18” wheels right now and 17” is the goal but I have upgraded drilled rotors. So in general I’m just unsure if the brakes would conflict with the 17s or if they would clear?
    stevesgraytundra likes this.
  16. Feb 29, 2024 at 8:27 AM
    #736
    stevesgraytundra
    Stephen
    2021 MGM SR5 CM 4x4
    A local tire highly rated shop said 2.5 Gen Tundras are very difficult to fit in stock form and many wheels, whether 17” or 18”, will not work (partially due to the huge +60mm offset with the stock wheels) and told me my best bet was to check with tirerack.com what would fit. I did that and they claimed my Method 314s were the only 17’s they had in stock that would work on my truck in stock form. Good thing is I love those wheels so it was an easy decision.
    MGMTunny14[QUOTED] likes this.
  17. Feb 29, 2024 at 9:34 AM
    #737
    MGMTunny14
    Maryland
    That whole thing with the offset was exactly what people were telling me about and had me worrying about. But if it worked for you then I guess I’ll give it a try. Can always just resell the wheels back on FB marketplace if it won’t work lol.
  18. Feb 29, 2024 at 9:56 AM
    #738
    equin
    equin Texarican Tundra
    Ed
    DFW, TX
    There are 25 pages worth of posts and pics on this thread documenting that certain 17s will fit on 2007-2021 Tundras. The main challenge in fitting 17s is being able to clear the large OEM brake calipers. A few 17s do, while many don’t. Icon developed 17s specifically to clear the large Tundra OEM brake calipers, but there are a few others, like Method wheels, for instance, that also clear the calipers.
    As for offset, the right offset helps to clear larger than stock tires without rubbing or with lift and cutting of plastic surrounding the inner wheel well. Less offset means more rubbing and cutting with bigger tires, and stock offset can cause rubbing on the upper control arm or skid plate with bigger tires. I believe +25 to +35 offset may be the sweet spot, but if you’re willing to push in or cut/remove more plastic than less offset will work as well.
    FWIW, I’m currently running 17” Icon Rebound wheels on 315/70/17 BFG ATs with 1.9” lift on Bilstein 6112s up front on stock upper control arms. The wheels easily clear the calipers. I had some minimal rubbing on the front plastic piece and rearward mud flaps, both of which I removed.
  19. Feb 29, 2024 at 10:08 AM
    #739
    equin
    Ed
    DFW, TX
    Forgot to add. There’s a big brake kit available for the 2-2.5 gen Tundras with a larger brake caliper that will not allow fitment of 17s. In fact, it may not even allow fitment of 18s, but I could be wrong about that. So if you’re thinking of ever upgrading to the big brake kit, then that’s something to consider when choosing wheel size.
  20. Mar 1, 2024 at 5:21 AM
    #740
    MGMTunny14
    Maryland
    That’s what I was worried about, my tundra has upgraded brakes, new calipers and drilled rotors so I’m worried as to whether it would clear a set of 17s
  21. Mar 1, 2024 at 8:45 AM
    #741
    equin
    Ed
    DFW, TX
    I could be wrong, but I don’t think replacement aftermarket rotors would affect fitment. Aftermarket calipers might not fit if they’re not the same size as OEM, though. Do you know what brand and kind of calipers you have?
    As for the Tundra TRD big brake kit, I’ve never seen it in person, but when I looked at it online years ago out of curiousity, I noticed the kit was fairly expensive, in the thousands of dollars:
    https://autoparts.toyota.com/products/product/trd-high-performance-big-brake-kit-ptr0900150
    Is that what you have? If so, then it doesn’t appear 17s will fit. As I said earlier, a few 17s fit over the OEM brake calipers. However, I’ve read on here how one or two folks shaved some metal off the OEM caliper to get whatever other 17” wheel to fit. Not sure if that’s a good idea, but with 17” wheels on the market that already do fit over the calipers (like my Icon Rebounds), I’d suggest getting one of those wheels instead, assuming your aftermarket calipers are the same size as OEM.
  22. Mar 1, 2024 at 9:05 AM
    #742
    jeffw6236
    jeffw6236 New Member
    Jeff
    San Antonio
    2019 MGM CrewMax 4x4
    I don’t see many of these but I like them!!
    295/70/17
  23. Mar 1, 2024 at 9:21 AM
    #743
    TundraLvr
    TundraLvr New Member
    2016 Radiant Red
    I'm running Alpha Echo 17" X 8.5" with +25mm offset. I removed the little front mudflap, and have a 2" leveling kit in the front. No rub and looks like I 'll be able to increase the size of the tire when it comes time for new. Tires are BFGoodrich 275/70/17. I'm not a huge fan of the tires, but they are what came on the wheels when I bought them.
    ETexTundra, equin and Ryuu like this.
  24. Mar 1, 2024 at 6:50 PM
    #744
    ETexTundra
    ETexTundra New Member
    Glenn
    2021 Silver Tundra SR5 4x4
    Duratrac RT 285/75R17 2.5” lift upfront with 1” rear shackles. Method 703 +35
  25. Mar 3, 2024 at 6:54 PM
    #745
    COTundra23
    love those wheels. Looks great!
  26. Mar 3, 2024 at 8:27 PM
    #746
    ETexTundra
    Glenn
    Thank you sir loving this simple setup!
  27. Mar 28, 2024 at 10:52 AM
    #747
    PickupMan2008
    PickupMan2008 Gladys Knight Industries Two Thousand
    Quentin
    Orange City, FL
    2008 Black Double Cab 4x4 5.7
    Cover King seat covers, weathertech rain guards and floor mats NFab Light Bar w/ KC Lights 2010 Limited Grill mod topper bedrug Amazon tailgate handle with rear backup camera still working on mods
    HOLY crap a simple 5 lug wheel looks amazing, I gotta get me a set when they are back in stock, they look friggin great!
  28. Jun 1, 2024 at 2:24 PM
    #748
    redryder
    redryder New Member
    Ryder
    Louisiana
    2018 Limited Cement CM
    So from my understanding going through this thread, I should be good on my stock height 2.5 gen with 305/70r17 with a wheel around a +20 offset with only minor trimming in the wheel liner?
  29. Jun 1, 2024 at 3:17 PM
    #749
    BreyTundy
    BreyTundy Big 4Lo Guy
    Andrew
    Colorado Springs
    2016 White DC TRD
    Yup, that should be a great setup
  30. Jun 7, 2024 at 12:05 PM
    #750
    sweatypowderpig
    sweatypowderpig New Member
    sierra nevada
    2019 Cement Limited DC TRD Off Road
    it's wheel and tire upgrade time. 2019 limited with TRD off road package, stock height.
    how big can I go with keeping the trimming to a minimum with 0 offset method 701s in 17"?
